Kubota Tractor L1-522DT-EC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota L1-522DT-EC Tractor
Number of Pages: 413 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Medidor De Aceite / Dipstick
Culata Cubierta / Head Cover
Engranaje Caja / Gear Case
Compensador / Balancer
Volante / Flywheel
Combustible Bomba / Fuel Pump
Combustible Arbol De Levas / Fuel Camshaft
Carril Comun / Common Rail
Agua Tubo / Water Pipe
Bomba De Agua / Water Pump
Línea De Aceite Hidráulico (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Soporte Del Muflfer Pieza Demontaje / Muffler Bracket Mountingpart
Hidraulico Bomba Soporte / Hydraulic Pump Holder
Piezas Electricas Del Motor (Sensor) / Engine Electrical Parts (Sensor)
Piezas Electricas Del Motor (Silencioso/Ecu) / Engine Electrical Parts (Muffler/Ecu)
Palanca Del Acelerador / Accelerator Lever
Deposito De Combustible Derecho / Fuel Tank Rh
Deposito De Combustible Izquierdo / Fuel Tank Lh
Tubo De Combustible (Separador/Combustible Bomba) / Fuel Pipe (Separator/Fuel Pump)
Tubo De Combustible (Deposito Combustible) / Fuel Pipe (Fuel Tank)
Separador / Separator
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Sensor (Motor) / Sensor (Engine)
Sensor (Silencioso/Ecu) / Sensor (Muffler/Ecu)
Conmutador/Sensor (Motor/Capo) / Switch/Sensor (Engine/Bonnet)
Interruptor/Sensor (Transmisión Caja) / Switch/Sensor (Transmission Case)
Conmutador (Panel Tablero) / Switch (Panel)
Conmutador/Sensor (Panel Bastidor) / Switch/Sensor (Panel Frame)
Conmutador/Sensor (Peldano/Depósito Combustible/Guardabarros/Freno De Mano) / Switch/Sensor (Step/Fuel Tank/Fender/Hand Brake)
Rele / Relay
Ecu
Panel
Faro Delantero / Head Light
Intermitente Lampara / Winker Lamp
Cola Luz / Tail Light
Luz Matricula / License Lamp
Instalacion Electrica (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Adelante) / Electrical Wiring (Front)
Electrico Cableado (Trasero) / Electrical Wiring (Rear)
Embrague / Clutch
Embrague Palanca / Clutch Lever
Caja Intermedia / Mid Case
Tdf Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Principal / Main Shaft
Arbol Contrarrotante / Countershaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Arbol Contrarrotante De Tdf / Pto Countershaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Tdf Eje / Pto Shaft
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Palanca De La Cambio De Engranaje / Range Gear Shift Lever
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno (Pedal De Freno) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Freno De Mano (Soporte) / Hand Brake (Support)
Freno De Mano (Palanca) / Hand Brake (Lever)
Freno Pedal / Brake Pedal
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Diferencial (Anterior) / Differential (Front)
Eje De Engranaje Conico / Bevel Gear Shaft
Universal Junta / Universal Joint
Regulador Valvula / Regulater Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Tubería De Aceite Hidráulico (Impulsion/Bomba Hidráulica) / Hydraulic Oil Line (Delivery/Hydraulic Pump)
Tubería De Aceite Hidráulico (Impulsion/Válvula Del Cargador) / Hydraulic Oil Line (Delivery/Loader Valve)
Tubería De Aceite Hidráulico (Tdf) / Hydraulic Oil Line (Pto)
Válvula Del Cargador / Loader Valve
Válvula De Salida Hidráulica [Componente Piezas] / Hydraulic Outlet Valve [Component Parts]
Tubería Hidráulica Del Cargador / Loader Pipe
Ascenso Brazo / Lift Arm
Distribuidor / Control Valve
Comprobar Valvula/Seguridad Valvula / Check Valve/Safety Valve
3 Punto Cilindro Derecho / 3p Cylinder Rh
3 Punto Cilindro Izquierdo / 3p Cylinder Lh
3 Punto Cilindro [Componente Piezas] / 3p Cylinder [Component Parts]
Posicion Control Palanca / Position Control Lever
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Lever
Válvula De Control Auxiliar (Flotante) [Componente Piezas] / Auxiliary Control Valve (Floating) [Component Parts]
Auxiliar Control Valvula Acoplador / Auxiliary Control Valve Coupler
Bajar Vinculo / Lower Link
Ascenso Varilla / Lift Rod
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Tdf Protector / Pto Protector
Soporte Delantero De Capo / Hood (Bonnet) Front Support
Capo / Hood (Bonnet) Upper
Cubierta Lateral Inferior / Side Cover Lower
(Capo) Amortiguador Sonido Y Aislador / Hood (Bonnet) Sound Absorber And Insulator
Panel Bastidor / Panel Frame
Protector / Shield
Panel Inferior / Panel Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Peldano / Step
Herramienta Caja / Tool Box
Arco De Seguridad / Rops
Rueda Delantera (29*12.00-15) / Front Wheel (29*12.00-15)
Rueda Delantera (8-16) / Front Wheel (8-16)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Rueda Trasera (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Rueda Trasera (13.6-28) / Rear Wheel (13.6-28)
Rueda Trasera (475/65-D20) / Rear Wheel (475/65-D20)
Letrero (Panel) / Label (Panel)
Parachoques Delantero [Opcion] / Front Bumper Kit [Option]
Esfuerzo Control Kit (Palanca De Control De Posición) [Opcion] / Draft Control Kit (Position Control Lever) [Option]
Esfuerzo Control Kit (Acoplamiento De Control De Posición) [Opcion] / Draft Control Kit (Position Control Link) [Option]
Esfuerzo Control Kit (Palanca De Control De Esfuerzo) [Opcion] / Draft Control Kit (Draft Control Lever) [Option]
Esfuerzo Control Kit (Soporte De Tercer Punto) [Opcion] / Draft Control Kit (Top Link Holder) [Option]
Kit De Palanca Multifunción (Palanca) [Opcion] / Multifunction Lever Kit (Lever) [Option]
Controlador [Componente Piezas] [Opcion] / Controller [Component Parts] [Option]
Kit De Palanca Multifunción (Cable) [Opcion] / Multifunction Lever Kit (Cable) [Option]
Válvula De Control Auxiliar (Doble) [Opcion] / Auxiliary Control Valve (Double) [Option]
Válvula De Control Auxiliar (Flotante) [Opcion] / Auxiliary Control Valve (Floating) [Option]
Válvula De Control Auxiliar (Soltero) [Opcion] / Auxiliary Control Valve (Single) [Option]
Palanca De La Válvula De Control Auxiliar (Segunda) [Opcion] / Auxiliary Control Valve Lever Kit (2nd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Acoplador De La Válvula De Control Auxiliar (Segunda) [Opcion] / Auxiliary Control Valve Coupler (2nd) [Option]
Acoplador De La Válvula De Control Auxiliar (Tercera) [Opcion] / Auxiliary Control Valve Coupler (3rd) [Option]
