653
1,893,908
Kubota Tractor L1-522DCN Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1-522DCN Tractor
Number of Pages: 261 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Bomba Gasoleo / Fuel Pump
Veio / Fuel Camshaft
Injector E Vela Aquecimento / Injector And Glow P Lug
Common Rail / Common Rail
Bomba Agua / Water Pump
Linha De Óleo Hidráulico (Radiador Oleo) / Hydrau Lic Oil Line (Oil Cooler)
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo Aspiracao / Inlet Pipe
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Panela Escape Suporte Peças De Montagem / Muffler Bracket Mountingpart
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Ch Arger)
Suporte De Bomba Hidraulico / Hydraulic Pump Hold Er
Componentes Electricos Motor (Sensor) / Engine El Ectrical Parts (Sensor)
Componentes Electricos Motor (Panela Escape/Ecu) / Engine Electrical Parts (Muffler/Ecu)
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Tubo Do Combustível (Enchim Ento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Separador /Bomba Gasoleo) / Fuel Pipe (Separator/Fuel Pump)
Tubo Combustivel (Arrefeced Or Gasoleo) / Fuel Pipe (Fuel Cooler)
Tubo Combustivel (Deposito Combustivel) / Fuel Pipe (Fuel Tank)
Filtro Gasoleo / Fuel Filte R
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Separador / Separator
Separador [Peças Componente S] / Separator [Component Parts]
Arrefecedor Gasoleo / Fuel Cooler
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Sensor (Motor) / Sensor (E Ngine)
Sensor (Panela Escape/Ecu) / Sensor (Muffler/Ecu)
Interruptor/Sensor (Bloco Motor/Capot) / Switch/Sensor (Engine/Bonnet)
Interruptor/Sensor (Transm Issão Carter ) / Switch/Sensor (Transmission Case)
Interruptor (Painel) / Swi Tch (Panel)
Interruptor/Sensor (Estrut Ura Do Painel) / Switch/Sensor (Panel Frame)
Interruptor/Sensor (Degrau /Deposito Combustivel/Guarda Lamas/Travao Mao) / Sw Itch/Sensor (Step/Fuel Tank/Fender/Hand Brake)
Relé / Relay
Unidade Control Electrico / Electronic Control Unit
Painel / Panel
Luzes Frente / Head Light
Lampada / Winker Lamp
Farol Traseiro / Tail Ligh T
Ficha Reboque / Trailer So Cket
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica (Diante Iro) / Electrical Wiring (Front)
Cablagem Electrica (Trasei Ros) / Electrical Wiring (Rear)
Embraiagem / Clutch
Alavanca Da Embraia Gem / Clutch Lever
Caixa Intermedia / Mid Case
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Compone Nt Parts]
Caixa Da Transmissã O / Transmission Case
Veio Primario / Mai N Shaft
Veio Secundario / C Ountershaft
Veio Inversor / Shu Ttle Shaft
Inversor / Reverse Shaft
Veio Gamas Velocida Des / Range Gear Shaft
Pinhao Espiral / Sp Iral Bevel Pinion
Diferencial Traseir O / Rear Differential
Contraveio De Tdf / Pto Countershaft
Embraiagem Tdf / Pt O Clutch
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts]
Veio Principal Tdf / Pto Drive Shaft
Forquilh A Inversor / Shuttle Shift Fork
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Differential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Gama Ala Vanca De Velocidades / Range Gear Shift Lever
Eixo Traseiro Esq / Rear Axle Lh
Eixo Traseiro Drt / Rear Axle Rh
Travao Esq / Brake Lh
Travao Drt / Brake Rh
Tirante Do Travão (Pedal Do Travão) / Brake Rod (Brake Pedal)
Tirante Do Travão (Came Do Travão) / Brake Rod (Brake Cam)
Travao Mao (Suporte) / H And Brake (Support)
Travao Mao (Alavanca) / Hand Brake (Lever)
Veio Eixo / Front Whe El Drive Shaft
Caixa Do Diferencial Dianteiro / Front Differential Case
Engrenagem Cónica (Di Anteira) / Bevel Gear (Front)
Diferencial (Dianteir O) / Differential (Front)
Carter Eixo Frente Es Q / Front Axle Case Lh
Carter Eixo Frente Dr T / Front Axle Case Rh
Veio Grupo Conico / B Evel Gear Shaft
Pedal Inclinacao / Tilt Pedal
Junta Universal / Universal Joint
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / Regul Ater Valve
Linha De Óleo Hidráulico ( Entrada) / Hydraulic Oil Line (Inlet)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico ( Tdf) / Hydraulic Oil Line (Pto)
Bloco Saidas Hidraulico / Hydraulic Outlet Block
Tampa Da Transmissão / Tra Nsmission Case Cover
Braco Hidraulico / Lift Ar M
Alavanca / Feed Back Lever
Valvula Control [Peças Com Ponentes] / Control Valve [Component Parts]
Valvula Verificação/Valvul A Segurança / Check Valve/Safety Valve
3p Cilindro Drt / 3p Cylin Der Rh
3p Cilindro Esq / 3p Cylin Der Lh
3p Cilindro [Peças Compone Ntes] / 3p Cylinder [Component Parts]
Alavanca Da Válvula De Con Trolo Auxiliar (1ª) / Auxiliary Control Valve Lever (1st)
Válvula De Controlo Auxili Ar (Flutuante) [Peças Componentes] / Auxiliary Cont Rol Valve (Floating) [Component Parts]
Acoplamento Valvulas Servi Ços Externos / Auxiliary Control Valve Coupler
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Tiran Te / Lift Rod
Barra Reboque / Drawbar
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Suporte Dianteiro Capot / Hood (Bonnet) Fron T Support
Tapa Lateral Baixa / Side Cover Lower
Placa / Shutter Plate
Capot Superior Absorvedor Som E Isolador / H Ood (Bonnet) Sound Absorber And Insulator
Estrutura Do Painel / Panel Frame
Painel Inferior / Panel Cover
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Estrutura Cabine / Cab Frame
Painel Da Cabine/Tapete Do Piso / Cabin Panel/Floor Mat
Porta / Door
Tejadilho / Roof
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rear
Vidro Frente E Lado / Front Glass/Side Glass
Vidro Traseiro / Rear Glass
Pala Sol / Sunvisor
Cabina (Lâmpada Farol) / Cabin (Beacon Lamp)
Cabina (Luz De Trabalho) / Cabin (Working Light)
Cabina (Depósito De Lavagem) / Cabin (Washer Tank)
Condesador / Condenser
Compressor/Tubo Ar Condicionad O / Compressor/Air Conditioner Hose
Placa Compressora / Compressor Plate
Roda Frente (29*12.00-15) / Front Wheel (29*12.00-15)
Roda Frente (8-16) / Front Wheel ( 8-16)
Roda Frente (9.5-16) / Front Wheel (9.5-16)
Roda Traseira (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Roda Traseira (13.6-28) / Rear Whe El (13.6-28)
Roda Traseira (475/65-D20) / Rear Wheel (475/65-D20)
Etiqueta (Dianteiro) / Label (Front)
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseiros) / Label (Rear)
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Apoio Frente [Opção] / Front Bumper Kit [Option]
Kit De Controlo Da Conicidade (Alavanca De Contro Lo Da Posição) [Opção] / Draft Control Kit (Positio N Control Lever) [Option]
Kit De Controlo Da Conicidade (Ligação De Control O Da Posição) [Opção] / Draft Control Kit (Position Control Link) [Option]
Kit De Controlo Da Conicidade (Alavanca De Contro Lo Da Conicidade) [Opção] / Draft Control Kit (Draf T Control Lever) [Option]
Kit De Controlo Da Conicidade (Suporte Terceiro P Onto) [Opção] / Draft Control Kit (Top Link Holder) [Option]
Válvula De Controlo Auxiliar (Duplicado) [Opção] / Auxiliary Control Valve (Double) [Option]
Válvula De Controlo Auxiliar (Flutuante) [Opção] / Auxiliary Control Valve (Floating) [Option]
Válvula De Controlo Auxiliar (Singelo) [Opção] / Auxiliary Control Valve (Single) [Option]
Alavanca Da Válvula De Controlo Auxiliar (2ª) [Op Ção] / Auxiliary Control Valve Lever Kit (2nd) [Opt Ion]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 3ª) [Opção] / Auxiliary Control Valve Lever Kit (3r D) [Option]
Acoplador Da Válvula De Controlo Auxiliar (2º) [O Pção] / Auxiliary Control Valve Coupler (2nd) [Opti On]
Acoplador Da Válvula De Controlo Auxiliar (3º) [O Pção] / Auxiliary Control Valve Coupler (3rd) [Opti On]
