Momed80
150
35,046
Kubota Tractor KX080-5 Operator Manual RD858-8121-1
Model: Kubota KX080-5 Tractor
Part Number: RD858-8121-1
Number of Pages: 164 Pages
Contents
Safe Operation
Dealer Service
Warranty Policy
Scrapping The Product And Its Procedure
Technical Data
Excavator Parts
Instrument Panel And Controls
Instrument Panel And Switches
Handling The Instrument Panel And Switches
Horn Switch
Operating The Working Light Switch
Aux Port Enable Switch
Auto Idle Control Switch
Throttle Potentiometer
Travel Speed Switch
Inhibit Diesel Particulate Filter (Dpf) Regeneration Switch
Beacon Light Switch
Electrical Outlet And Usb Outlet
Rear View Camera
Control Pedals And Levers
Handling The Pilot Control Lock Lever
Cab Operation
Operating The Wiper And Washer
Interior Lamp
Opening And Closing The Cab Door
Opening And Closing The Front Window Door Of The Cab
Opening And Closing The Side Window Of The Cab
Removing The Front Window Base
Emergency Hammer
Air Conditioner
Pre-Operation Check
Daily Check
Operating The Engine
Starting The Engine
Starting The Engine Under Cold Conditions
Starting With An Auxiliary Battery
Check Points After Starting The Engine
Stopping The Engine
Dpf Regeneration
Operating The Excavator
Operation Of A New Machine
Preparations Before Starting The Machine
Driving
Turns
Up And Downhill Driving
Parking On A Slope
Operating The Dozer
Two Pattern Selection System (Tpss)
Operating The Boom
Operation Of The Arm
Operation Of The Bucket
Swivel And Boom Swing Operation
Auxiliary Port Operation
Releasing Pressure Trapped In The Hydraulic System
Angle Blade Operation
One-Way Or Two-Way Circuit Selection Valve Operation
Operating The Boom Lowering Valve
Auto Idle (Ai) Operation
Important Information On Machine Operation
Transporting The Machine
Transporting On A Truck
Towing The Machine
Lifting The Excavator
Basic Points When Lifting With Cables Or Straps
Safety Aspects When Lifting With Cables Or Straps
Lifting The Machine
Maintenance
Precautions When Washing The Machine
Maintenance Intervals
Opening And Closing The Covers
Daily Checks
Regular Checks And Maintenance Work
Every 50 Service Hours
Every 100 Service Hours
Every 150 Service Hours
Every 200 Service Hours
Every 250 Service Hours
Every 500 Service Hours
Every 1000 Service Hours
Every 1000 Service Hours Or Once A Year
Every 1500 Service Hours
Every 2000 Service Hours
Every 3000 Service Hours
Annual Servicing
Biennial Servicing
Servicing As Required
Other Adjustments And Replacements
Purging The Fuel System
Adjusting The Tracks
Changing The Bucket
Fuses
Troubleshooting
Troubleshooting Of The Engine And Other Systems
Operation In Cold Weather
Preparation For Work In Cold Weather
After Working In Cold Weather
Long-Term Storage
Storing The Machine
Operating The Machine After Long-Term Storage
Periodic Replacement Of Parts
Recommended Oils And Fuels
Biodiesel Fuel (Bdf)
Request Regarding Fuel Use And Maintenance Of Crs Diesel Engines
Appendices
Main Dimensions
Lifting Capacity
Lifting Capacity With Rubber Tracks Or Steel Tracks (450 Width)
Lifting Capacity With Steel Tracks (600 Width)
List Of Screens
Navigation Screens
Automatic Diesel Particulate Filter (Dpf) Regeneration
Locking And Releasing The Diesel Particulate Filter (Dpf) Regeneration
Software Information
Index
