7,392
Kubota Tractor G21HD Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota G21HD Tractor
Number of Pages: 264 Pages
G21hd
G21hd Motor Engine Kurbelghaeuse Crankcase
G21hd Motor Engine Ol-Fanger Oil Pan
G21hd Motor Engine Zylinderkopf Cylinder Head
G21hd Motor Engine Getriebe Gehaeuse Gear Case
G21hd Motor Engine Ventildeckel Head Cover ## S.No.; =4x4026 S.No.; =4x4026
G21hd Motor Engine Ventildeckel Head Cover ## S.No.; =5a0001 S.No.; =5a0001
G21hd Motor Engine Oelfilter Oil Filter
G21hd Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
G21hd Motor Engine Oel Pumpe Oil Pump
G21hd Motor Engine Hauptlagergehäuse Main Bearing Case
G21hd Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
And Crankshaft ## Achtung Bestellen Sie Bitte Pos.010 Neue Teile Und Fig.No. Pos.010,020 Neue Teile
G21hd Motor Engine Schwungrad Flywheel
G21hd Motor Engine Fraftstoffnockenwelle Fuel Camshaft
G21hd Motor Engine Freilaufapparat Idle Apparatus
G21hd Motor Engine Abstellhubmagnet Stop Solenoid
G21hd Motor Engine Einspritzpumpe Injection Pump
G21hd Motor Engine Zylinderkopf Governor
G21hd Motor Engine Geschwindigkeitskontrolle Nockenhohn Speed Control Plate
G21hd Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug
G21hd Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component Parts]
G21hd Motor Engine Deckel, Kraftstoffpumpe Fuel Pump Cover
G21hd Motor Engine Oelschalter Thermometer Oil Switch Thermometer
G21hd Motor Engine Kuehlwasserflansch Water Flange And Thermostat
G21hd Motor Engine Loffel(Ohne Schnellkupplung) [Option] Water Pump
G21hd Motor Engine Wasserrohr Water Pipe
Motor Engine Loffel(Ohne Schnellkupplung) [Option] Valve And Rocker Arm ## S.No.; =
G21hd Motor Engine Ansaugrohr Inlet Manifold ## S.No.; =4x4026 S.No.; =4x4026
G21hd Motor Engine Ansaugrohr Inlet Manifold ## S.No.; =5a0001 S.No.; =5a0001
G21hd Motor Engine Auslasskruemmer Exhaust Manifold
G21hd Motor Engine Luftfilter Air Cleaner
G21hd Motor Engine Auspufftopf Muffler
G21hd Motor Engine Auspuff (Fr) Muffler [Fr]
Motor Engine Dichtungssatz Zylinderkopf [Option] Upper Gasket Kit [Option] ## S.No.; =
G21hd Motor Engine Dichtungssatz Motorblock [Option] Lower Gasket Kit [Option]
G21hd Kraftstoff System Fuel System Beschleunigerhebel Accelerator Lever
G21hd Kraftstoff System Fuel System Karroceair Fuel Tank
G21hd Kraftstoff System Fuel System Kraftstoffrohr Kraftstoffilter Fuel Pipe Fuel
G21hd Kuehlungs System Cooling Water System Ventilator Fan
G21hd Kuehlungs System Cooling Water System Wasserrohr Water Pipe
G21hd Kuehlungs System Cooling Water System Kuehler Radiator
G21hd Elektrisches System Electrical System Lichtmaschine Alternator
G21hd Elektrisches System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
G21hd Elektrisches System Electrical System Anlasser Starter
G21hd Elektrisches System Electrical System Anlasser [Einzel-Teil] Starter [Component
G21hd Elektrisches System Electrical System Batterie Battery
G21hd Elektrisches System Electrical System Elektrische Teile Electrical Parts
G21hd Elektrisches System Electrical System Scheinwerfer Head Light
G21hd Elektrisches System Electrical System Elektrische Ausrustung (Kabine) Electrical
G21hd Transmission Transmission Carcasa Caja Transferencia Transmission
G21hd Transmission Transmission Bremswelle Freilaufgetriebewelle Brake Gear-Shaft
G21hd Transmission Transmission Hst Hst
G21hd Transmission Transmission Hst (Gehaeuse) Hst (Housing)
G21hd Transmission Transmission Hst (Stopfen) Hst (Plug)
G21hd Transmission Transmission Hst (Zylinderblock, Motor) Hst (Cylinder Block,
G21hd Transmission Transmission Hst 4 (Zylinderblock, Pumpe) Hst 4 (Cylinder Block,
G21hd Transmission Transmission Kardangelenk Hst Ventilator Universal Joint Hst
G21hd Transmission Transmission Zapfwelle Pto Shaft
G21hd Transmission Transmission Spannrolle Pto Tension Pulley
G21hd Hinterradachse Rear Axle Hinterdifferential Rear Differential
G21hd Hinterradachse Rear Axle Welle, Differential Hinten Rear Differential
G21hd Hinterradachse Rear Axle Hinterradachsgehaeuse Rear Axle Case
G21hd Hinterradachse Rear Axle Abstuetzung Rechts Vorne Rear Axle
G21hd Hinter Reifen Rear Tire Hinterrad (230,50-12) Rear Wheel (230.50-12)
G21hd Bremse Brake P.T.O.-Bremse Pto Brake
G21hd Bremse Brake Brems Brake
G21hd Bremse Brake Bremspedal Brake Pedal
G21hd Bremse Brake Bremsstange Brake Rod
G21hd Getriebe System Speed Change Drehzahlaenderpedal Speed Change Pedal
G21hd Getriebe System Speed Change Geschwindigkeits Kontroll Arm Speed Control
G21hd Getriebe System Speed Change Hydraulik-Schalthebel Hydraulic Control
G21hd Getriebe System Speed Change P.T.O.-Schalthebel Zug Pto Clutch Control Lever
G21hd Getriebe System Speed Change P.T.O.-Zug Halter Pto Wire Bracket
G21hd Vorderachse Front Axle Loffel(Ohne Schnellkupplung) [Option] Front Axle
G21hd Vorderachse Front Axle Rahmen Lenkung-Staender Main Frame Steering
G21hd Vorderachse Front Axle Rahmen Lenkung-Staender [Fr] Main Frame Steering
G21hd Vorderachse Front Axle Motor Traeger Engine Support
G21hd Vorderachse Front Axle Motor Traeger [Fr] Engine Support [Fr]
G21hd Vorderrad Reifen Front Tire Vorderrad (16 6,5-8) Front Wheel (16 6.5-8)
G21hd Lenkung Steering Hilfskraftlenkung Lenkrad Power Steering Steering
G21hd Hydraulik System Hydraulic System Kontrollventil Control Valve
Hydraulik System Hydraulic System Kontrollventil [Einzel-Teil] Control Valve [Component Parts]
G21hd Hydraulik System Hydraulic System Hydraulik-Kreislauf (Ansaugrohr) Hydraulic Oil
G21hd Hydraulik System Hydraulic System Hydraulik-Kreislauf (Entluefter) Hydraulic Oil
G21hd Hydraulik System Hydraulic System Hydraulik-Kreislauf (Leitung) Hydraulic Oil
G21hd Hydraulik System Hydraulic System Hydraulik-Kraftheberzylinder Hydraulic Lift
G21hd Hydraulik System Hydraulic System Schubstange Lift Link
G21hd Motorhaube Hood Bonnet Motorhaube Hood (Bonnet)
G21hd Motorhaube Hood Bonnet Motorhaube (Fr) Hood(Bonnet) [Fr]
G21hd Motorhaube Hood Bonnet Elektrische Ausruestung Panel
G21hd Motorhaube Hood Bonnet Kotfluegel Fender
G21hd Motorhaube Hood Bonnet Sitz Seat ## S.No.; =11130 S.No.; =11130
G21hd Motorhaube Hood Bonnet Sitz Seat ## S.No.; =11131 S.No.; =11131
G21hd Motorhaube Hood Bonnet Sitz Federung Seat Suspension
G21hd Aufkleber Labels Aufkleber Label
G21hd Aufkleber Labels Aufkleber [Fr] Label [Fr]
G21hd Zubehoer Accessories Sontiges Zubehor Und Service-Teil Accessories And Service
Option Sicherheitsdeckel (Vorne) (Fr) (Option) Safety Cover Kit (Body Front) [Fr] [Option]
G21hd Option Option Sicherheitsdeckel (Vorne) (Fr) (Option) Safety Cover Kit (Body Rear)
