Kubota Tractor BX2360 Australia Parts Catalog
Model: Kubota BX2360 Tractor
Region: Australia
Number of Pages: 181 Pages
Frequently Used Items Frequently Used Items
Engine Air Cleaner
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head ## S.No. =4cxz999 S.No.; =4cxz999
Engine Cylinder Head ## S.No. =4cy0001 S.No.; =4cy0001
Engine Gear Case
Engine Head Cover
Engine Oil Filter
Engine Dipstick And Guide
Engine Oil Pump
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft ## S.No. =Bd0702 [Note Order By Fig.No.110202 Ref.No
Engine Piston And Crankshaft ## S.No. =Be0001 S.No.; =Be0001
Engine Flywheel
Engine Fuel Camshaft
Engine Idle Apparatus
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug ## S.No. =4cxz999 S.No.; =4cxz999
Engine Nozzle Holder And Glow Plug ## S.No. =4cy0001 S.No.; =4cy0001
Engine Nozzle Holder [Component Parts] ## S.No. =9g3338 S.No.; =9g3338
Engine Nozzle Holder [Component Parts] ## S.No. =9j0001 S.No.; =9j0001
Engine Cover
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Muffler
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Accelerator Lever
Fuel System Fuel Tank
Fuel System Fuel Pipe
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Oil Switch And Thermo Sensor
Electrical System Stop Solenoid
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Panel Board Switch
Electrical System Switch Sensor
Electrical System Head Light
Electrical System Hazard Light Tail Light
Electrical System Electrical Wiring
Front Axle Front Frame
Front Axle Sub Frame
Front Axle Engine Support
Front Axle Front Differential Case
Front Axle Bevel Gear Lh
Front Axle Bevel Gear Rh
Front Axle Front Axle Case Lh
Front Axle Front Axle Case Rh
Front Axle Front Axle Lh
Front Axle Front Axle Rh
Front Axle Front Drive Shaft
Transmission Transmission Case ## Note Order By Ref.No.010 New Part And Fig.No.J12000 Ref
Transmission Transmission Case Cover
Transmission Rear Axle Case
Transmission Clutch Shaft Output Shaft
Transmission Propeller Shaft
Region: Australia
Engine Air Cleaner
Engine Crankcase
Engine Oil Pan
Engine Gear Case
Engine Head Cover
Engine Oil Filter
Engine Oil Pump
Engine Flywheel
Engine Governor
Engine Cover
Engine Water Pump
Engine Muffler
