Kubota Tractor BX2350D Spare Parts Catalog EN FR
Language: French, English
Model: Kubota BX2350D Tractor
Number of Pages: 234 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Couvercle / Cover
Alternateur / Alternator And Pulley
Alternateur [Parties Composantes] / Alternator [Co Mponent Parts]
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compone Nt Parts]
Contact A Huile Thermometre Et Obturateur / Oil Sw Itch/Thermometer And Plug
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Ventilateur / Fan
Filter A Air / Air Cleaner
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Batterie / Battery
Tableau De Bord / Panel Bo Ard
Commutateur/Detector [Avan T] / Switch/Sensor [Front]
Commutateur/Detector [Arri Ere] / Switch/Sensor [Rear]
Phare / Head Light
Phare / Head Light
Lamp Et Plaque D'immatricu Lation / License Lamp
Reflecteur / Reflector
Prise De Remorque / Traile R Socket
Faisceau Electrique / Elec Trical Wiring
Chassis Avant / Front Frame
Chassis Second / Sub Frame
Avant Carter De Differentiel / Front Dif Ferential Case
Differentiel Avant / Front Differential
Demi Arbre De Pont Avant / Differential Gear Shaft
Pont Avant / Front Axle
Carter De Pont Arriere / Rear Axle Cas E
Arbre De Embrayage / Clutch Shaft/Outp Ut Shaft
Arbre De Transmission / Propeller Shaf T
Hst 1 (Bloc De Cylindre) / Hst 1 (Cyli Nder Block)
Hst 2 (Bras) / Hst 2 (Arm)
Hst 3 (Couvercle De Bloc D'orifice) / Hst 3 (Port Block Cover)
Hst 4 (Couvercle De Refroidisseur) / H St 4 (Oil Cooler Cover)
Arbre De Changement De Gamme / Range G Ear Shaft
Arbre De Prise De Force / Pto Shaft
Pdf Ventrale / Mid Pto
Differentiel Arriere / Rear Differenti Al
Arbre De Marche / Fwd Idle Shaft
Arbre De Marche / Gp Idle Shaft
Arbre D'entrainement Avant / Front Whe El Propeller Shaft
Fourchette De Changement De Ga Mme / Range Gear Shift Fork
Fourchette De Chengement De Vi Tesse Pdf / Pto Gear Shift Fork
Bras De Chengement De Vitesse Pdf / Pto Gear Shift Arm
Fourchette De Blocage Differen Tiel / Differential Lock Shift Fork
Levier De Controle De Croisier E / Cruise Control Lever
Pedale De Commande De Vittesse / Speed Control Pedal
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Levier De Selection De La Pdf / Pto Select Lever
Levier De Chengement De Vitess E Pdf / Pto Gear Shift Lever
Levier De Distributeur Auxilia Ire / Remote Control Lever
Pedale De Verrouillage Du Differentiel / Differential Lock Pedal
F Rein / Brake
T Ige De Frein / Brake Rod
L Evier De Frein De Stationnement / Parking Brake Lev Er
C Able De Frein De Stationnement / Parking Brake Wire
P Edale De Frien / Brake Pedal
Levier De Controle Hyd Raulique / Hydraulic Control Lever
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit C'huile Hydrau Lique (Retour) / Hydraulic Oil Line(Delivery)
Circuit D'huile Hydrau Lique(Direction) / Hydraulic Oil Line(Steering)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bra S De Relevage / Hydraulic Piston/Lift Arm
Distributeur Hydrauliq Ue / Control Valve
Distributer [Parties C Omposantes] / Control Valve [Component Parts]
Distributeur Auxiliair E / Remote Control Valve
Distributeur Auxiliair E [Parties Composantes] / Remote Control Valve [Com Ponent Parts]
Tuyau De Controle Des Valves Auxiliaire / Remote Control Valve Pipe
Timoner De Direction / Steering Linkage
Tirant Superieu R / Top Link
Tirant Inferieu R / Lower Link
Barre De Releva Ge / Lift Rod
Support Du Tira Nt Superieur / Top Link Bracket
Biellette Arrie Re De La Tondeuse D. / Mower Rear Link Rh
Biellette Arrie Re De La Tondeuse G. / Mower Rear Link Lh
Barre D'attelag E / Drawbar
Protection Pdf / Pto Protector
Support Calandre Avant / Front Glille Support
Capot / Bonnet
Capot Lateral / Bonnet Side
Piller Centre / Center Pillar
Cadre De Panneau / Panel Frame
Retroviseur [Fr] [G] / Rearview Mirror [Fr] [G ]
Retroviseur [Uk] / Rearview Mirror [Uk]
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Marchepied / Step
Marchepied / Step
Support De Marche-Pied / Step Stay
Cadre Anti-Renversement / Rops
Roue Avant (18*8,5-10) / Front Wheel (18*8 .5-10)
Roue Arriere (26*12,00-12) / Rear Wheel ( 26*12.00-12)
Roue Arriere (26*12-12) / Rear Wheel (26* 12-12)
Etiquette (Avant) [Anglais] / Label (Front) [E Nglish]
Etiquette (Avant) [Francais] / Label (Front) [ French]
Etiquette (Avant) [Allemagne] / Label (Front) [German]
Etiquette (Avant) [Espagnol] / Label (Front) [ Spanish]
Etiquette (Avant) [Italien] / Label (Front) [I Talian]
Etiquette (Arriere) [Anglais] / Label (Rear) [ English]
Etiquette (Arriere) [Francais] / Label (Rear) [French]
Etiquette (Arriere) [Allemagne] / Label (Rear) [German]
Etiquette (Arriere) [Espagnol] / Label (Rear) [Spanish]
Etiquette (Arriere) [Italien] / Label (Rear) [ Italian]
A Ccessories Et Piece De Service / Accessories And Se Rvice Parts
Adaptateur Cluster [Option] / Cluster Adapter Kit [Option]
Ens.Ajustement De Tondeuse [Option] / Mower Fit Ki T [Option]
Kit De Support Du Marche-Pied [Option] / Step Stay Kit [Option]
Couvercle De Vent. [Option] / Fan Cover [Option]
Attelage Avant [Option] / Front Hitch Kit [Option]
Plat De Panneau Inferieur [Option] / Lowerpanel Pl Ate Kit [Option]
Controle De La Valve Avant (Valve) [Option] / Fron T Control Valve Kit (Valve) [Option]
Controle De La Valve Avant (Valve) [Parties Comp.] [Option] / Front Control Valve Kit (Valve) [Comp.P Arts] [Option]
Controle De La Valve Avant (Tige) [Option] / Front Control Valve Kit (Rod) [Option]
Controle De La Valve Avant (Levier) [Option] / Fro Nt Control Valve Kit (Lever) [Option]
Controle De La Valve Avant (Circuit D'huile 1) [Op Tion] / Front Control Valve Kit (Oil Line 1) [Optio N]
Controle De La Valve Avant (Circuit D' Huile 2) [O Ption] / Front Control Valve Kit (Oil Line 2) [Opti On]
Controle De La Valve Avant (Couvercle) [Option] / Front Control Valve Kit (Cover) [Option]
Kit De L'orifice Hydraulique [Option] / Hydraulic Port Kit [Option]
