Kubota Tractor BX2350D 70001- Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota BX2350D Tractor
Serial Number: 70001-
Number of Pages: 385 Pages
Bx2350d(S.No.70001-)
Bx2350d(S.No.70001-) Motor Engine Kurbelghaeuse Crankcase
Bx2350d(S.No.70001-) Motor Engine Ol-Fanger Oil Pan
No.70001-) Motor Engine Zylinderkopf Cylinder Head ## S.Nr. =4cxz999 S.No.; =4cxz999 S.No. =
S.No.70001-) Motor Engine Zylinderkopf Cylinder Head ## S.Nr. =4cy0001 S.No.; =4cy0001 S.No. =
Bx2350d(S.No.70001-) Motor Engine Getriebe Gehaeuse Gear Case
Bx2350d(S.No.70001-) Motor Engine Ventildeckel Head Cover
Bx2350d(S.No.70001-) Motor Engine Oelfilter Oil Filter
Bx2350d(S.No.70001-) Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
Bx2350d(S.No.70001-) Motor Engine Oel Pumpe Oil Pump
Bx2350d(S.No.70001-) Motor Engine Hauptlagergehäuse Main Bearing Case
Bx2350d(S.No.70001-) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And
Bx2350d(S.No.70001-) Motor Engine Kolben Und Kurbelwelle Piston And Crankshaft
Bx2350d(S.No.70001-) Motor Engine Schwungrad Flywheel
Bx2350d(S.No.70001-) Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And
Bx2350d(S.No.70001-) Motor Engine Freilaufapparat Idle Apparatus
Bx2350d(S.No.70001-) Motor Engine Einspritzenpumpe Injection Pump
S.No.70001-) Motor Engine Regler Governor ## S.Nr. =4ekz999 S.No.; =4ekz999 S.No. =4ekz999
Bx2350d(S.No.70001-) Motor Engine Regler Governor ## S.Nr. =4el0001 S.No.; =4el0001 S.No. =4el0001
Bx2350d(S.No.70001-) Motor Engine Geschwindigkeits-Reglerplatte Speed Control
Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =4cxz999 S.No.; =
Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =4cy0001 S.No.; =
Bx2350d(S.No.70001-) Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component
Bx2350d(S.No.70001-) Motor Engine Deckel Cover
Bx2350d(S.No.70001-) Motor Engine Wasserflansch Und Thermostat Water Flange And
Bx2350d(S.No.70001-) Motor Engine Wasserpumpe Water Pump
Bx2350d(S.No.70001-) Motor Engine Ventil Und Kipphebel Valve And Rocker Arm
Bx2350d(S.No.70001-) Motor Engine Ansaugenleitung Inlet Manifold
Bx2350d(S.No.70001-) Motor Engine Auslasskruemmer Exhaust Manifold
Bx2350d(S.No.70001-) Motor Engine Luftfilter Air Cleaner
Bx2350d(S.No.70001-) Motor Engine Auspufftopf Muffler
Bx2350d(S.No.70001-) Motor Engine Obere Dichtung-Gerart Upper Gasket Kit
Bx2350d(S.No.70001-) Motor Engine Motorblockdichtsatz Lower Gasket Kit
Bx2350d(S.No.70001-) Motor Engine Grp.Nockenwelle [Option] Camshaft Kit [Option]
Bx2350d(S.No.70001-) Motor Engine Beschleunigungshebel Accelerator Lever
Bx2350d(S.No.70001-) Brennstoff System Fuel System Karroceair Fuel Tank
Bx2350d(S.No.70001-) Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
Bx2350d(S.No.70001-) Brennstoff System Fuel System Kraftstoffilter Fuel Filter
Bx2350d(S.No.70001-) Brennstoff System Fuel System Kraftstoffpumpe Fuel Pump
Bx2350d(S.No.70001-) Kuehlungs System Cooling Water System Ventilator Fan
Bx2350d(S.No.70001-) Kuehlungs System Cooling Water System Wasserrohr Water
Bx2350d(S.No.70001-) Kuehlungs System Cooling Water System Kuehler Radiator
Bx2350d(S.No.70001-) Kuehlungs System Cooling Water System Reservebehalter Reserve
S.No.70001-) Elektrisches System Electrical System Oelschalter Und Thermometer Oil Switch
Bx2350d(S.No.70001-) Elektrisches System Electrical System Abstellsolenoid Stop
Bx2350d(S.No.70001-) Elektrisches System Electrical System Lichtmaschine Alternator
S.No.70001-) Elektrisches System Electrical System Lichtmaschine [Einzel-Teil] Alternator
Bx2350d(S.No.70001-) Elektrisches System Electrical System Anlasser Starter
Bx2350d(S.No.70001-) Elektrisches System Electrical System Anlasser [Einzel-Teil] Starter [
Bx2350d(S.No.70001-) Elektrisches System Electrical System Batterie Battery
Bx2350d(S.No.70001-) Elektrisches System Electrical System Instrumentenbrett Verkleidung
Bx2350d(S.No.70001-) Elektrisches System Electrical System Sensor Und Relais Sensor
Bx2350d(S.No.70001-) Elektrisches System Electrical System Schalter Sensor Switch
Bx2350d(S.No.70001-) Elektrisches System Electrical System Scheinwerfer Head
Bx2350d(S.No.70001-) Elektrisches System Electrical System Warnblinklicht Ruecklicht Hazard
Bx2350d(S.No.70001-) Elektrisches System Electrical System Lizenzlampe License
Bx2350d(S.No.70001-) Elektrisches System Electrical System Reflektor Reflector
Bx2350d(S.No.70001-) Elektrisches System Electrical System Anhaengerkupplung Trailer
Elektrisches System Electrical System Elektrische Ausrustung Electrical Wiring ## S.Nr. =70923
Elektrische Ausrustung Electrical Wiring ## S.Nr.75001 To 75002 [Note Order By Fig.No. Ref.No.
Elektrisches System Electrical System Elektrische Ausrustung Electrical Wiring ## S.Nr. =75003
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderrahmen Front Frame
Bx2350d(S.No.70001-) Vorderachse Front Axle Rahmentragachse Frame Bracket
Bx2350d(S.No.70001-) Vorderachse Front Axle Motor Traeger Engine Support
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderachsen-Diff.Gehaeuse Front Differential
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderachsen-Differential Front
Bx2350d(S.No.70001-) Vorderachse Front Axle Antriebskegelrad Links Bevel Gear
Bx2350d(S.No.70001-) Vorderachse Front Axle Antriebskegelrad Rechts Bevel Gear
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderachse-Gehaeuse Links Front Axle
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderachse-Gehaeuse Rechs Front Axle
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderradachse Links Front Axle
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderradachse Rechts Front Axle
Bx2350d(S.No.70001-) Vorderachse Front Axle Vorderrad-Antriebswelle Front Wheel
Bx2350d(S.No.70001-) Transmission Transmission Getriebe-Gehaeuse Transmission
Bx2350d(S.No.70001-) Transmission Transmission Getriebe-Gehaeuse-Deckel Transmission
Bx2350d(S.No.70001-) Transmission Transmission Hiterradachsegehaeuse Rs Rear Axle
Bx2350d(S.No.70001-) Transmission Transmission Kupplungswelle Clutch Shaft
Bx2350d(S.No.70001-) Transmission Transmission Propellerwelle Propeller Shaft
Bx2350d(S.No.70001-) Transmission Transmission Hst (Zylinderblock) Hst (Cylinder
Bx2350d(S.No.70001-) Transmission Transmission Hst (Arm) Hst (Arm)
Bx2350d(S.No.70001-) Transmission Transmission Hst (Port Block Deckel) Hst (Port Block
Bx2350d(S.No.70001-) Transmission Transmission Hst 4 (Oelkuehler Deckel) Hst 4 (Oil Cooler
Bx2350d(S.No.70001-) Transmission Transmission Drehzahlbereichswelle Range Gear
Bx2350d(S.No.70001-) Transmission Transmission Zapfwelle Pto Shaft
Bx2350d(S.No.70001-) Transmission Transmission Zapfwellenkupplung Pto Clutch
Bx2350d(S.No.70001-) Transmission Transmission Mittlere Zapfwelle Mid Pto
Bx2350d(S.No.70001-) Transmission Transmission Hinterdifferential Rear Differential
Bx2350d(S.No.70001-) Transmission Transmission Zwischenradwelle Fwd Idle Shaft
Bx2350d(S.No.70001-) Transmission Transmission Zwischenradwelle Gp Idle Shaft
Bx2350d(S.No.70001-) Transmission Transmission Antriebswelle Vorne Front Wheel Propeller
Bx2350d(S.No.70001-) Getriebe System Speed Change Drehzahlbereichsschaltgabel Range
Bx2350d(S.No.70001-) Getriebe System Speed Change Zapfwellen-Schaltgabel Pto Gear
Bx2350d(S.No.70001-) Getriebe System Speed Change Zapfwellenarm Pto Gear Shift
Bx2350d(S.No.70001-) Getriebe System Speed Change Differentialsperre Schaltgabel Differential
Bx2350d(S.No.70001-) Getriebe System Speed Change Drehzahlaenderpedal Speed Control
Bx2350d(S.No.70001-) Getriebe System Speed Change Drehzahlreglerstange Speed Control
Bx2350d(S.No.70001-) Getriebe System Speed Change Tempomat-Schalthebel Cruise Control
Bx2350d(S.No.70001-) Getriebe System Speed Change Drehzahlbereichshebel Range Gear
Bx2350d(S.No.70001-) Getriebe System Speed Change Habel Fuer Vorderradantrieb Front Wheel
Bx2350d(S.No.70001-) Getriebe System Speed Change Zapfwellenwahlhebel Pto Select
Bx2350d(S.No.70001-) Getriebe System Speed Change Zapfwellenschalthebel Pto Gear
Bx2350d(S.No.70001-) Getriebe System Speed Change Regelungsventil-Schalthebel Remote Control
Bx2350d(S.No.70001-) Hinterradachse Rear Axle Hinterradachse Links Rear Axle
Bx2350d(S.No.70001-) Hinterradachse Rear Axle Hinterradachse Rechts Rear Axle
Bx2350d(S.No.70001-) Hinterradachse Rear Axle Differentialsperrepedal Differential
Bx2350d(S.No.70001-) Bremse Brake Bremse Links Brake Lh
Bx2350d(S.No.70001-) Bremse Brake Bremse Rechts Brake Rh
Bx2350d(S.No.70001-) Bremse Brake Bremsstange Brake Rod
Bx2350d(S.No.70001-) Bremse Brake Handbremsehebel Parking Brake Lever
Bx2350d(S.No.70001-) Bremse Brake Handbremsekabel Parking Brake Wire
Bx2350d(S.No.70001-) Bremse Brake Bremspedal Brake Pedal
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Bedienungshebel Der Hydraulik Hydraulic
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Hydraulikpumpe Hydraulic
S.No.70001-) Hydraulik System Hydraulic System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump
S.No.70001-) Hydraulik System Hydraulic System Hydraulik-Kreislauf (Liferung) Hydraulic
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Hydraulik-Kreislauf(Lenk) Hydraulic
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Hydraulikzylinder Hydraulic
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Hydraulikkolben Hubarm Hydraulic
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Regelungsventil Control
S.No.70001-) Hydraulik System Hydraulic System Regelungsventil [Einzel-Teil] Control Valve
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Zusatzsteuerventil Remote Control
70001-) Hydraulik System Hydraulic System Zusatzsteuerventil [Einzel-Teil] Remote Control
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Einstellwelle Fall Adjustment
Bx2350d(S.No.70001-) Hydraulik System Hydraulic System Zusatzsteuerventile-Rohr Remote
Bx2350d(S.No.70001-) Lenkung Steering Lenkgriff Steering Wheel
Bx2350d(S.No.70001-) Lenkung Steering Hilfskraftlenkung Steering Controller
Bx2350d(S.No.70001-) Lenkung Steering Lenkungszylinder Steering Cylinder
Bx2350d(S.No.70001-) Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [
70001-) Oberlenker Oberlenkertraeger Schutzabdeckung Top Link Top Link Bracket Pto Protector
Oberlenker Oberlenkertraeger Schutzabdeckung Top Link Top Link Bracket Pto Protector Halterung
Oberlenker Oberlenkertraeger Schutzabdeckung Top Link Top Link Bracket Pto Protector Hintere
70001-) Oberlenker Oberlenkertraeger Schutzabdeckung Top Link Top Link Bracket Pto Protector 4
70001-) Oberlenker Oberlenkertraeger Schutzabdeckung Top Link Top Link Bracket Pto Protector 5
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Vordergitter-Stutze Front Glille
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Motorhaube Bonnet
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Seitemotorhaube Bonnet Side
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Achsestaender Center Pillar
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Plattenrahmen Panel Frame
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Rueckspiegel [Ausgenommen Uk] Rearview Mirror
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Rueckspiegel [Uk] Rearview Mirror
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Hebelfuehrung Ls Lever Guide Lh
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Hebelfuehrung Rs Lever Guide Rh
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Kotfluegel Fender
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Sitz Traeger Seat Support
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Sitz [Kdg] Seat [Kdg]
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Tritt Step
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Trittbrettstrebe Step Stay
Bx2350d(S.No.70001-) Motorhaube Hood Bonnet Ueberrollbuegel Rops
Bx2350d(S.No.70001-) Vorderrad Reifen Front Wheel Vorderrad Reifen(18 8,5-10) Front Wheel(
Bx2350d(S.No.70001-) Hinterrad Reifen Rear Wheel Hinterrad Reifen (262,00-12) Rear Wheel(
Bx2350d(S.No.70001-) Hinterrad Reifen Rear Wheel Hinterrad Reifen (262-12) Rear Wheel(
Bx2350d(S.No.70001-) Aufkleber Labels Aufkleber (Vorne) (Ausgenommen Uk) Label (Front) [
Bx2350d(S.No.70001-) Aufkleber Labels Aufkleber (Vorne) (Uk) Label (Front) [Uk]
Bx2350d(S.No.70001-) Aufkleber Labels Aufkleber (Hinten) (Ausgenommen Uk) Label (Rear) [
Bx2350d(S.No.70001-) Aufkleber Labels Aufkleber (Hinten) (Uk) Label (Rear) [Uk]
Sonstiges Zubehoer Und Service Teile Accessories And Service Parts Sontiges Zubehor Und
Bx2350d(S.No.70001-) Option Option Kupplungskit Vorne [Option] Front Hitch Kit [Option]
Bx2350d(S.No.70001-) Option Option Fan Decke [Option] Fan Cover Kit [Option]
S.No.70001-) Option Option Vorder-Regelungsventil (Ventil) [Option] Front Control Valve
Option Option Vorder-Regelungsventil (Ventil) [Einzel-Teil][Option] Front Control Valve
S.No.70001-) Option Option Vorder-Regelungsventil (Stange) [Option] Front Control Valve
S.No.70001-) Option Option Vorder-Regelungsventil (Hebel) [Option] Front Control Valve
No.70001-) Option Option Vorder-Regelungsventil (Kreislauf) [Option] Front Control Valve
Bx2350d(S.No.70001-) Option Option Hydraulikanschluss [Option] Hydraulic Port Kit [
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
