118
7,392
Kubota Tractor BX231D5-C Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota BX231D5-C Tractor
Number of Pages: 382 Pages
Bx231d5-C
Bx231d5-C Frequently Used Items Frequently Used Items Häufig Verwendete Elemente Frequently
Bx231d5-C Motor Engine Kurbelghaeuse Crankcase
Bx231d5-C Motor Engine Oelwanne Oil Pan
Bx231d5-C Motor Engine Zylinderkopf Cylinder Head
Bx231d5-C Motor Engine Getriebe Gehaeuse Gear Case
Bx231d5-C Motor Engine Deckel Oben Head Cover
Bx231d5-C Motor Engine Oelfilter Oil Filter
Bx231d5-C Motor Engine Oelmessstab Dipstick
Bx231d5-C Motor Engine Oel Pumpe Oil Pump
Bx231d5-C Motor Engine Hauptlagergehaeuse Main Bearing Case
Bx231d5-C Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle
Bx231d5-C Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
Bx231d5-C Motor Engine Schwungrad Flywheel
Bx231d5-C Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
Bx231d5-C Motor Engine Freilaufapparat Idle Apparatus
Bx231d5-C Motor Engine Einspritzenpumpe Injection Pump
Bx231d5-C Motor Engine Regler Governor
Bx231d5-C Motor Engine Geschwindigkeits-Regler Platte Speed Control Plate
Bx231d5-C Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow Plug
Bx231d5-C Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component Parts]
Bx231d5-C Motor Engine Deckel Cover
Bx231d5-C Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
Bx231d5-C Motor Engine Wasserpumpe Water Pump
Bx231d5-C Motor Engine Ventil Kipparmwelle Valve And Rocker Arm
Bx231d5-C Motor Engine Einlasskruemmer Inlet Manifold
Bx231d5-C Motor Engine Auspuffrummer Exhaust Manifold
Bx231d5-C Motor Engine Luftreinheit Air Cleaner
Bx231d5-C Motor Engine Ansaugenrohr Inlet Pipe
Bx231d5-C Motor Engine Auspufftopf Muffler
Bx231d5-C Motor Engine Dichtung-Geraet Upper Gasket Kit
Bx231d5-C Motor Engine Unterdichtung-Geraet Lower Gasket Kit
Bx231d5-C Motor Engine Beschleunigungshebel Accelerator Lever
Bx231d5-C Brennstoff System Fuel System Kraftstofftank Fuel Tank
Bx231d5-C Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
Bx231d5-C Brennstoff System Fuel System Kraftstoffilter Fuel Filter
Bx231d5-C Brennstoff System Fuel System Kraftstoffpumpe Fuel Pump
Bx231d5-C Abkuehlung System Cooling Water System Ventilator Fan
Bx231d5-C Abkuehlung System Cooling Water System Gebläseabdeckung Fan Shroud
Bx231d5-C Abkuehlung System Cooling Water System Wasserrohr Water Pipe
Bx231d5-C Abkuehlung System Cooling Water System Kuehler Radiator
Bx231d5-C Abkuehlung System Cooling Water System Reservebehalter Reserve
Bx231d5-C Elektrisch System Electrical System Oelschalter Thermometer Oil Switch And
Bx231d5-C Elektrisch System Electrical System Stop Solenoid Stop Solenoid
Bx231d5-C Elektrisch System Electrical System Lichtmaschine Alternator
Bx231d5-C Elektrisch System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
Bx231d5-C Elektrisch System Electrical System Anlasser Starter
Bx231d5-C Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter [Component
Bx231d5-C Elektrisch System Electrical System Batterie Battery
Bx231d5-C Elektrisch System Electrical System Instrumentenbrett Panel Board
Bx231d5-C Elektrisch System Electrical System Wandplatte Schalter Panel Switch
Bx231d5-C Elektrisch System Electrical System Sensor Und Relais Sensor And
Bx231d5-C Elektrisch System Electrical System Schalter Sensor Switch Sensor
Bx231d5-C Elektrisch System Electrical System Scheinwerfer Head Light
Bx231d5-C Elektrisch System Electrical System Warnlicht Hazard Light
Bx231d5-C Elektrisch System Electrical System Hinter Licht Tail Light
Bx231d5-C Elektrisch System Electrical System Kennzeichenleuchte License
Bx231d5-C Elektrisch System Electrical System Reflektor Reflector
Bx231d5-C Elektrisch System Electrical System Anhaengerkupplung Trailer Socket
Bx231d5-C Elektrisch System Electrical System Elektrische Ausrustung (Vorder) Electrical
Bx231d5-C Elektrisch System Electrical System Elektrische Ausrustung (Hinten) Electrical
Bx231d5-C Vorderachse Front Axle Vorderrahmen Front Frame
Bx231d5-C Vorderachse Front Axle Halter Rahmen Frame Bracket
Bx231d5-C Vorderachse Front Axle Motor Traeger Engine Support
Bx231d5-C Vorderachse Front Axle Vorderachse-Gehaueuse Front Axle Case
Bx231d5-C Vorderachse Front Axle Vorderachsen-Differential Front Differential
Bx231d5-C Vorderachse Front Axle Antriebskegelrad Links Bevel Gear Lh
Bx231d5-C Vorderachse Front Axle Antriebskegelrad Rechts Bevel Gear Rh
Bx231d5-C Vorderachse Front Axle Vorderachse-Gehaeuse Links Front Axle Case
Bx231d5-C Vorderachse Front Axle Vorderachse-Gehaeuse Rechs Front Axle Case
Bx231d5-C Vorderachse Front Axle Vorderradachse Links Front Axle Lh
Bx231d5-C Vorderachse Front Axle Vorderachse Rechts Front Axle Rh
Bx231d5-C Vorderachse Front Axle Vorderantriebswelle Front Wheel Drive Shaft
Bx231d5-C Transmission Transmission Getriebe-Gehaeuse Transmission Case
Bx231d5-C Transmission Transmission Getriebe-Gehaeusedecken Transmission Case
Bx231d5-C Transmission Transmission Hinterradachsegehaeuse Rs Rear Axle Case
Bx231d5-C Transmission Transmission Kupplung-Welle Clutch Shaft
Bx231d5-C Transmission Transmission Propellerwelle Propeller Shaft
Bx231d5-C Transmission Transmission Hst (Zylinderblock) Hst (Cylinder Block)
Bx231d5-C Transmission Transmission Hst (Arm) Hst (Arm)
Bx231d5-C Transmission Transmission Hst (Port Block Deckel) Hst (Port Block
Bx231d5-C Transmission Transmission Hst 4 (Oelkuehler Deckel) Hst 4 (Oil Cooler
Bx231d5-C Transmission Transmission Drehzahlbereichswelle Range Gear Shaft
Bx231d5-C Transmission Transmission Zapfwelle Pto Shaft
Bx231d5-C Transmission Transmission Zapfwellekupplung Pto Clutch
Bx231d5-C Transmission Transmission Mittlere Zapfwelle Mid Pto
Bx231d5-C Transmission Transmission Hinterachsen-Differential Rear Differential
Bx231d5-C Transmission Transmission Zwischenradwell Fwd Idle Shaft
Bx231d5-C Transmission Transmission Zwischenradwell Gp Idle Shaft
Bx231d5-C Transmission Transmission Vorderantriebswelle Front Wheel Propeller
Bx231d5-C Getriebe System Speed Change Drehzahlbereichsschaltgabel Range Gear
Bx231d5-C Getriebe System Speed Change Zapfwellen-Schaltgabel Pto Gear Shift
Bx231d5-C Getriebe System Speed Change Zapfwellenarm Pto Gear Shift Arm
Bx231d5-C Getriebe System Speed Change Fourchette Fur Differentialsperre Differential
Bx231d5-C Hinterradachse Rear Axle Hinterradachse Links Rear Axle Lh
Bx231d5-C Hinterradachse Rear Axle Hinterradachse Rechts Rear Axle Rh
Bx231d5-C Bremse Brake Bremse Links Brake Lh
Bx231d5-C Bremse Brake Bremse Rechts Brake Rh
Bx231d5-C Bremse Brake Bremsstange Brake Rod
Bx231d5-C Bremse Brake Handbremsehebel Parking Brake Lever
Bx231d5-C Bremse Brake Handbremsekabel Parking Brake Wire
Bx231d5-C Kontrollhebel Operation Drehzahlaenderpedal Speed Change Pedal
Bx231d5-C Kontrollhebel Operation Drehzahlreglerstange Speed Change Rod
Bx231d5-C Kontrollhebel Operation Tempomat-Schalthebel Cruise Control Lever
Bx231d5-C Kontrollhebel Operation Drehzahlbereichshebel Range Gear Shift
Bx231d5-C Kontrollhebel Operation Vorderrad Fahrhebel Front Wheel Drive Lever
Bx231d5-C Kontrollhebel Operation Zapfwellenwahihebel Pto Select Lever
Bx231d5-C Kontrollhebel Operation Zapfwellenschalthebel Pto Gear Shift Lever
Bx231d5-C Kontrollhebel Operation Zusatzsteuerventilhebel Auxiliary Control
Bx231d5-C Kontrollhebel Operation Kontroll-Hebel Hydraulic Control Lever
Bx231d5-C Kontrollhebel Operation Bremspedal Brake Pedal
Bx231d5-C Kontrollhebel Operation Differentialsperrepedal Differential Lock
Bx231d5-C Lenkung Steering Lenkrad Steering Wheel
Bx231d5-C Lenkung Steering Halter Lenkung Steering Bracket
Bx231d5-C Lenkung Steering Kipphebel Tilt Lever
Bx231d5-C Lenkung Steering Hilfskraftlenkung Steering Controller
Bx231d5-C Lenkung Steering Lenkungszylinder Steering Cylinder
Bx231d5-C Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [Component
Bx231d5-C Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic
C Pumpe Motor System Pump Motor System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump
Bx231d5-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Zuleitung) Hydraulic
Bx231d5-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Lenkung) Hydraulic
Bx231d5-C Pumpe Motor System Pump Motor System Hydraulikzylinder Hydraulic
Bx231d5-C Pumpe Motor System Pump Motor System Hydraulikkolben Hubarm Hydraulic
Bx231d5-C Pumpe Motor System Pump Motor System Regelungsventil Control Valve
C Pumpe Motor System Pump Motor System Regelungsventil [Einzel-Teil] Control Valve
Bx231d5-C Pumpe Motor System Pump Motor System Zusatzsteuerventile Auxiliary Control
Pumpe Motor System Pump Motor System Zusatzsteuerventile [Einzel-Teil] Auxiliary Control
Bx231d5-C Pumpe Motor System Pump Motor System Herbst Einstellwelle Fall Adjustment
Bx231d5-C Pumpe Motor System Pump Motor System Hilfssteuerventilleitung Auxiliary Control
Bx231d5-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Oberlenker
Bx231d5-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Unterlenker
Bx231d5-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hubstange
Bx231d5-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Fuehrungskette
Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hintere Zugstangen
Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Maeher-Steuerzifferblatt
Bx231d5-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Anhangerku
C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Schutzabdeckung
Bx231d5-C Motorhaube Hood Bonnet Vorder-Gitter Front Grille
Bx231d5-C Motorhaube Hood Bonnet Motorhaube Obere Hood (Bonnet) Upper
Bx231d5-C Motorhaube Hood Bonnet Motorhaube (Unten) Bonnet (Lower)
Bx231d5-C Motorhaube Hood Bonnet Motorhaube Oeffnen Bonnet Open
Bx231d5-C Motorhaube Hood Bonnet Muetze-Verriegelung Hood (Bonnet) Lock
Bx231d5-C Motorhaube Hood Bonnet Seitemotorhaube Bonnet Side
Bx231d5-C Motorhaube Hood Bonnet Achsestaender Center Pillar
Bx231d5-C Motorhaube Hood Bonnet Instrumentenbrett-Deckel Panel Cover
Bx231d5-C Motorhaube Hood Bonnet Hebelfuehrung Ls Lever Guide Lh
Bx231d5-C Motorhaube Hood Bonnet Hebelfuehrung Rs Lever Guide Rh
Bx231d5-C Motorhaube Hood Bonnet Kotfluegel Fender
Motorhaube Hood Bonnet Kotfluegeltraeger Fender Stay ## 翻訳依頼済み Note
Bx231d5-C Motorhaube Hood Bonnet Sitz Traeger Seat Support
Bx231d5-C Motorhaube Hood Bonnet Sitz (Cobo Sc74 M91) Seat (Cobo Sc74 M91)
Bx231d5-C Motorhaube Hood Bonnet Sitz (Sears 807) Seat (Sears 807)
Bx231d5-C Motorhaube Hood Bonnet Sitz (Sears 830) Seat (Sears 830)
Bx231d5-C Motorhaube Hood Bonnet Tritt Step
Bx231d5-C Motorhaube Hood Bonnet Trittbrettstrebe Step Stay
Bx231d5-C Motorhaube Hood Bonnet Drehzahlbereichsschalteraufenthali Range Gear Shift
Bx231d5-C Kabine Cab Kabinengeruest Cab Frame
Bx231d5-C Vorderrad Front Wheel Vorderrad (18 8,5-10) Front Wheel (18 8.5-10)
Bx231d5-C Hinterrad Rear Wheel Hinterrad (262,00-12) Rear Wheel (262.00-12)
Bx231d5-C Aufkleber Labels Aufkleber (Vorder) Label (Front)
Bx231d5-C Aufkleber Labels Aufkleber (Hintern) Label (Rear)
Bx231d5-C Option Option Anhaengekupplung Vorne [Option] Front Hitch Kit [Option]
Bx231d5-C Option Option Hinteranhangung [Option] Rear Hitch Kit [Option]
Bx231d5-C Option Option Vordergewicht [Option] Front Weight Kit [Option]
Bx231d5-C Option Option Buechse [Option] Fan Cover Kit [Option]
Bx231d5-C Option Option Vorder-Regelungsventil (Ventil) [Option] Front Control Valve Kit (
Option Option Vorder-Regelungsventil (Ventil) [Einzel-Teil] [Option] Front Control Valve Kit (
Option Option Vorder-Regelungsventil (Regelungshebel) [Option] Front Control Valve Kit
Option Option Vorder-Regelungsventil (Verriegelunghebel) [Option] Front Control Valve
Option Option Vorder-Regelungsventil (Rohr Schnellkupplung) [Option] Front Control Valve
Bx231d5-C Option Option Vorder-Regelungsventil (Schlauch) [Option] Front Control Valve Kit
