118
7,392
Kubota Tractor BX231 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota BX231 Tractor
Number of Pages: 373 Pages
Bx231
Bx231 Frequently Used Items Frequently Used Items Häufig Verwendete Elemente Frequently
Bx231 Motor Engine Kurbelghaeuse Crankcase
Bx231 Motor Engine Oelwanne Oil Pan
Bx231 Motor Engine Zylinderkopf Cylinder Head
Bx231 Motor Engine Getriebe Gehaeuse Gear Case
Bx231 Motor Engine Deckel Oben Head Cover
Bx231 Motor Engine Oelfilter Oil Filter
Bx231 Motor Engine Oelmessstab Dipstick
Bx231 Motor Engine Oel Pumpe Oil Pump
Bx231 Motor Engine Hauptlagergehaeuse Main Bearing Case
Bx231 Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
Bx231 Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
Bx231 Motor Engine Schwungrad Flywheel
Bx231 Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
Bx231 Motor Engine Freilaufapparat Idle Apparatus
Bx231 Motor Engine Einspritzenpumpe Injection Pump
Bx231 Motor Engine Regler Governor
Bx231 Motor Engine Geschwindigkeits-Regler Platte Speed Control Plate
Bx231 Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow Plug
Bx231 Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component Parts]
Bx231 Motor Engine Deckel Cover
Bx231 Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
Bx231 Motor Engine Wasserpumpe Water Pump
Bx231 Motor Engine Ventil Kipparmwelle Valve And Rocker Arm
Bx231 Motor Engine Einlasskruemmer Inlet Manifold
Bx231 Motor Engine Auspuffrummer Exhaust Manifold
Bx231 Motor Engine Luftreinheit Air Cleaner
Bx231 Motor Engine Ansaugenrohr Inlet Pipe
Bx231 Motor Engine Auspufftopf Muffler
Bx231 Motor Engine Dichtung-Geraet Upper Gasket Kit
Bx231 Motor Engine Unterdichtung-Geraet Lower Gasket Kit
Bx231 Motor Engine Beschleunigungshebel Accelerator Lever
Bx231 Brennstoff System Fuel System Kraftstofftank Fuel Tank
Bx231 Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
Bx231 Brennstoff System Fuel System Kraftstoffilter Fuel Filter
Bx231 Brennstoff System Fuel System Kraftstoffpumpe Fuel Pump
Bx231 Abkuehlung System Cooling Water System Ventilator Fan
Bx231 Abkuehlung System Cooling Water System Gebläseabdeckung Fan Shroud
Bx231 Abkuehlung System Cooling Water System Wasserrohr Water Pipe
Bx231 Abkuehlung System Cooling Water System Kuehler Radiator
Bx231 Abkuehlung System Cooling Water System Reservebehalter Reserve Tank
Bx231 Elektrisch System Electrical System Oelschalter Thermometer Oil Switch And
Bx231 Elektrisch System Electrical System Stop Solenoid Stop Solenoid
Bx231 Elektrisch System Electrical System Lichtmaschine Alternator
Bx231 Elektrisch System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
Bx231 Elektrisch System Electrical System Anlasser Starter
Bx231 Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter [Component
Bx231 Elektrisch System Electrical System Batterie Battery
Bx231 Elektrisch System Electrical System Instrumentenbrett Panel Board
Bx231 Elektrisch System Electrical System Wandplatte Schalter Panel Switch
Bx231 Elektrisch System Electrical System Sensor Und Relais Sensor And Relay
Bx231 Elektrisch System Electrical System Schalter Sensor Switch Sensor
Bx231 Elektrisch System Electrical System Scheinwerfer Head Light
Bx231 Elektrisch System Electrical System Ruecklicht Blinklicht Hazard Light Tail
Bx231 Elektrisch System Electrical System Kennzeichenleuchte License Lamp
Bx231 Elektrisch System Electrical System Reflektor Reflector
Bx231 Elektrisch System Electrical System Anhaengerkupplung Trailer Socket
Bx231 Elektrisch System Electrical System Elektrische Ausrustung (Koerper) Electrical
Bx231 Vorderachse Front Axle Vorderrahmen Front Frame
Bx231 Vorderachse Front Axle Halter Rahmen Frame Bracket
Bx231 Vorderachse Front Axle Motor Traeger Engine Support
Bx231 Vorderachse Front Axle Vorderachse-Gehaueuse Front Axle Case
Bx231 Vorderachse Front Axle Vorderachsen-Differential Front Differential
Bx231 Vorderachse Front Axle Antriebskegelrad Links Bevel Gear Lh
Bx231 Vorderachse Front Axle Antriebskegelrad Rechts Bevel Gear Rh
Bx231 Vorderachse Front Axle Vorderachse-Gehaeuse Links Front Axle Case
Bx231 Vorderachse Front Axle Vorderachse-Gehaeuse Rechs Front Axle Case
Bx231 Vorderachse Front Axle Vorderradachse Links Front Axle Lh
Bx231 Vorderachse Front Axle Vorderachse Rechts Front Axle Rh
Bx231 Vorderachse Front Axle Vorderantriebswelle Front Wheel Drive Shaft
Bx231 Transmission Transmission Getriebe-Gehaeuse Transmission Case
Bx231 Transmission Transmission Getriebe-Gehaeusedecken Transmission Case
Bx231 Transmission Transmission Hinterradachsegehaeuse Rs Rear Axle Case
Bx231 Transmission Transmission Kupplung-Welle Clutch Shaft
Bx231 Transmission Transmission Propellerwelle Propeller Shaft
Bx231 Transmission Transmission Hst (Zylinderblock) Hst (Cylinder Block)
Bx231 Transmission Transmission Hst (Arm) Hst (Arm)
Bx231 Transmission Transmission Hst (Port Block Deckel) Hst (Port Block Cover)
Bx231 Transmission Transmission Hst 4 (Oelkuehler Deckel) Hst 4 (Oil Cooler Cover)
Bx231 Transmission Transmission Drehzahlbereichswelle Range Gear Shaft
Bx231 Transmission Transmission Zapfwelle Pto Shaft
Bx231 Transmission Transmission Zapfwellekupplung Pto Clutch
Bx231 Transmission Transmission Mittlere Zapfwelle Mid Pto
Bx231 Transmission Transmission Hinterachsen-Differential Rear Differential
Bx231 Transmission Transmission Zwischenradwell Fwd Idle Shaft
Bx231 Transmission Transmission Zwischenradwell Gp Idle Shaft
Bx231 Transmission Transmission Vorderantriebswelle Front Wheel Propeller
Bx231 Getriebe System Speed Change Drehzahlbereichsschaltgabel Range Gear Shift
Bx231 Getriebe System Speed Change Zapfwellen-Schaltgabel Pto Gear Shift Fork
Bx231 Getriebe System Speed Change Zapfwellenarm Pto Gear Shift Arm
Bx231 Getriebe System Speed Change Fourchette Fur Differentialsperre Differential Lock
Bx231 Hinterradachse Rear Axle Hinterradachse Links Rear Axle Lh
Bx231 Hinterradachse Rear Axle Hinterradachse Rechts Rear Axle Rh
Bx231 Bremse Brake Bremse Links Brake Lh
Bx231 Bremse Brake Bremse Rechts Brake Rh
Bx231 Bremse Brake Bremsstange Brake Rod
Bx231 Bremse Brake Handbremsehebel Parking Brake Lever
Bx231 Bremse Brake Handbremsekabel Parking Brake Wire
Bx231 Kontrollhebel Operation Drehzahlaenderpedal Speed Change Pedal
Bx231 Kontrollhebel Operation Drehzahlreglerstange Speed Change Rod
Bx231 Kontrollhebel Operation Tempomat-Schalthebel Cruise Control Lever
Bx231 Kontrollhebel Operation Drehzahlbereichshebel Range Gear Shift Lever
Bx231 Kontrollhebel Operation Vorderrad Fahrhebel Front Wheel Drive Lever
Bx231 Kontrollhebel Operation Zapfwellenwahihebel Pto Select Lever
Bx231 Kontrollhebel Operation Zapfwellenschalthebel Pto Gear Shift Lever
Bx231 Kontrollhebel Operation Zusatzsteuerventilhebel Remote Control Lever
Bx231 Kontrollhebel Operation Kontroll-Hebel Hydraulic Control Lever
Bx231 Kontrollhebel Operation Bremspedal Brake Pedal
Bx231 Kontrollhebel Operation Differentialsperrepedal Differential Lock Pedal
Bx231 Lenkung Steering Lenkrad Steering Wheel
Bx231 Lenkung Steering Halter Lenkung Steering Bracket
Bx231 Lenkung Steering Kipphebel Tilt Lever
Bx231 Lenkung Steering Hilfskraftlenkung Steering Controller
Bx231 Lenkung Steering Lenkungszylinder Steering Cylinder
Bx231 Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [Component
Bx231 Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic Pump
Bx231 Pumpe Motor System Pump Motor System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump [
Bx231 Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Zuleitung) Hydraulic
Bx231 Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Lenkung) Hydraulic Oil
Bx231 Pumpe Motor System Pump Motor System Hydraulikzylinder Hydraulic Cylinder
Bx231 Pumpe Motor System Pump Motor System Hydraulikkolben Hubarm Hydraulic Piston
Bx231 Pumpe Motor System Pump Motor System Regelungsventil Control Valve
Bx231 Pumpe Motor System Pump Motor System Regelungsventil [Einzel-Teil] Control Valve [
Bx231 Pumpe Motor System Pump Motor System Zusatzsteuerventile Remote Control
Pumpe Motor System Pump Motor System Zusatzsteuerventil [Einzel-Teil] Remote Control
Bx231 Pumpe Motor System Pump Motor System Herbst Einstellwelle Fall Adjustment
Bx231 Pumpe Motor System Pump Motor System Hilfssteuerventilleitung Auxiliary Control
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Oberlenker
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Unterlenker
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hubstange
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Fuehrungskette
Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hintere Zugstangen Rs
Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hintere Zugstangen Ls
Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Maeher-Steuerzifferblatt
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Anhangerku
Bx231 Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Schutzabdeckung
Bx231 Motorhaube Hood Bonnet Vorder-Gitter Front Grille
Bx231 Motorhaube Hood Bonnet Motorhaube Obere Hood (Bonnet) Upper
Bx231 Motorhaube Hood Bonnet Motorhaube (Unten) Bonnet (Lower)
Bx231 Motorhaube Hood Bonnet Motorhaube Oeffnen Bonnet Open
Bx231 Motorhaube Hood Bonnet Muetze-Verriegelung Hood (Bonnet) Lock
Bx231 Motorhaube Hood Bonnet Seitemotorhaube Bonnet Side
Bx231 Motorhaube Hood Bonnet Achsestaender Center Pillar
Bx231 Motorhaube Hood Bonnet Instrumentenbrett-Deckel Panel Cover
Bx231 Motorhaube Hood Bonnet Rueckspiegel Rearview Mirror
Bx231 Motorhaube Hood Bonnet Hebelfuehrung Ls Lever Guide Lh
Hood Bonnet Hebelfuehrung Rs [Ausgenommen Vorder-Regelungshebel] Lever Guide Rh
Motorhaube Hood Bonnet Hebelfuehrung Rs [Vorder-Regelungshebel] Lever Guide Rh [
Bx231 Motorhaube Hood Bonnet Kotfluegel Fender
Bx231 Motorhaube Hood Bonnet Kotfluegeltraeger Fender Stay
Bx231 Motorhaube Hood Bonnet Sitz Traeger Seat Support
Bx231 Motorhaube Hood Bonnet Sitz Seat
Bx231 Motorhaube Hood Bonnet Sitz (Cobo Leather) Seat (Cobo Leather)
Bx231 Motorhaube Hood Bonnet Sitz (Sears Mechanical,Pvc) Seat (Sears Mechanical,
Bx231 Motorhaube Hood Bonnet Sitz (Sears Air,Pvc) Seat (Sears Air,Pvc)
Bx231 Motorhaube Hood Bonnet Tritt Step
Bx231 Motorhaube Hood Bonnet Trittbrettstrebe Step Stay
Bx231 Motorhaube Hood Bonnet Drehzahlbereichsschalteraufenthali Range Gear Shift
Bx231 Motorhaube Hood Bonnet Hinterer Deckung Rear Cover
Bx231 Motorhaube Hood Bonnet Sicherheitsrahmen Rops
Bx231 Vorderrad Front Wheel Vorderrad (18 8,5-10) Front Wheel (18 8.5-10)
Bx231 Hinterrad Rear Wheel Hinterrad (262,00-12) Rear Wheel (262.00-12)
Bx231 Aufkleber Labels Aufkleber (Vorder) Label (Front)
Bx231 Aufkleber Labels Aufkleber (Hintern) Label (Rear)
Zubehoer Und Service Teile Accessories And Service Parts Sontiges Zubehoer Und Service Teile
Bx231 Option Option Anhaengekupplung Vorne [Option] Front Hitch Kit [Option]
Bx231 Option Option Hinteranhangung [Option] Rear Hitch Kit [Option]
Bx231 Option Option Vordergewicht [Option] Front Weight Kit [Option]
Bx231 Option Option Buechse [Option] Fan Cover Kit [Option]
Bx231 Option Option Vorder-Regelungsventil (Ventil) [Option] Front Control Valve Kit (
Option Option Vorder-Regelungsventil (Ventil) [Einzel-Teil] [Option] Front Control Valve Kit (
Option Option Vorder-Regelungsventil (Regelungshebel) [Option] Front Control Valve Kit (
Option Option Vorder-Regelungsventil (Verriegelunghebel) [Option] Front Control Valve Kit
Option Vorder-Regelungsventil (Rohr Schnellkupplung) [Option] Front Control Valve Kit
Bx231 Option Option Vorder-Regelungsventil (Schlauch) [Option] Front Control Valve Kit (
