Kubota Tractor BX2200E Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota BX2200E Tractor
Number of Pages: 355 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Speed Control Plate
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Alternador Y Polea / Alternator And Pulley
Motor De Arranque / Starter
Manocontacto De Aceite/Termometro / Oil Switch/Thermometer
Agua Bomba / Water Pump
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Hidraulico Bomba Cubierta / Hydraulic Pump Cover
Combustible Tubo / Fuel Pipe
Agua Tubo / Water Pipe
Tablero Panel / Panel Board
Culata Luz / Head Light
Peligro Luz/Cola Luz / Hazard Light/Tail Light
Licencia Lampara / License Lamp
Trasero Eje Caja / Rear Axle Case
Embrague Eje/Salida Eje / Clutch Shaft/Output Shaft
Helice Eje / Propeller Shaft
Hst
Hst[Componente Piezas] / Hst [Component Parts]
Pto Eje / Pto Shaft
Tdf Intermedia / Mid Pto
Gp Punto Muerto Eje / Gp Idle Shaft
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Pto Engranaje Cambio Brazo / Pto Gear Shift Arm
Punto Muerto Soporte Vinculo / Neutral Holder Link
Velocidad Control Pedal / Speed Control Pedal
Pto Selecto Palanca / Pto Select Lever
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Eje Trasero / Rear Axle
Freno / Brake
Estacionamiento Freno Cable / Parking Brake Wire
Freno Pedal / Brake Pedal
Hidraulico Control Palanca / Hydraulic Control Lever
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line(Steering)
Piston Hidraulico/Brazo De Elevacion [Fr] [Uk] [2wd] / Hydraulic Piston/Lift Arm [Fr] [Uk] [2wd]
Piston Hidraulico/Brazo De Elevacion [Excepto [Fr] [Uk] [2wd]] / Hydraulic Piston/Lift Arm [Except [Fr] [Uk] [2wd]]
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula[Componente Piezas] / Remote Control Valve [Component Parts]
Alejado Control Valvula Tubo / Remote Control Valve Pipe
Adelante Eje / Front Axle
Direccion Varillaje / Steering Linkage
Cortacespedes Trasero Vinculo Derecho / Mower Rear Link Rh
Cortacespedes Trasero Vinculo Izquierdo / Mower Rear Link Lh
Barra De Remolque [Excepto [Fr] [2wd]] / Drawbar [Except [Fr] [2wd]]
Pto Protector
Adelante Parrilla Soporte / Front Glille Support
Capo / Bonnet
Capo / Bonnet
Capo Lado / Bonnet Side
Centro Montante / Center Pillar
Panel Bastidor / Panel Frame
Espejo Retrovisor [Fr] [G] / Rearview Mirror [Fr] [G]
Espejo Retrovisor [Uk] / Rearview Mirror [Uk]
Guardabarros / Fender
Asiento [Fr] [Uk] / Seat [Fr] [Uk]
Asiento [G] / Seat [G]
Peldano / Step
Rueda Delantera(18*8.50-8) / Front Wheel(18*8.50-8)
Rueda Trasera(26*12.00-12) / Rear Wheel(26*12.00-12)
Etiqueta [Ingles] / Label [English]
Etiqueta [Frances] / Label [French]
Etiqueta [Alemania] / Label [Germany]
Kit De Brazo De Elevacion De Enganche Tripuntal [Fr] [Uk] [2wd] [Opcion] / 3-P Lift Arm Kit [Fr] [Uk] [2wd] [Option]
3-Punto Vinculo Kit 1[Opcion] / 3-P Link Kit 1 [Option]
3-Punto Vinculo Kit 2[Opcion] / 3-P Link Kit 2 [Option]
3-Punto Vinculo Kit 3[Opcion] / 3-P Link Kit 3 [Option]
Adelante Enganche Kit[Opcion] / Front Hitch Kit [Option]
Kit De Barra De Remolque [Fr] [2wd] [Opcion] / Drawber Kit [Fr] [2wd] [Option]
Rops Kit[Opcion] / Rops Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Hst
Pto Eje / Pto Shaft
Freno / Brake
Pto Protector
Capo / Bonnet
Capo / Bonnet
Peldano / Step
