Kubota Tractor B8200 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B8200 Tractor
Number of Pages: 131 Pages
C Arter Moteur / Crancase
C Arter D'huile / Oil Pan
C Ulasse / Cylinder Head
C Arter De Distribution / Gear Case
P Aliers De Vilebrequin Principal / Main Bearing Case
C Ouvre-Culbuteurs / Cylinder Head Cover
C Ollecteur D'admission / Inlet Manifold
S Oupapes Et Culbuteurs / Valve Rocker Arm
A Rbre A Cames / Camshaft
L Evier D'arret Du Moteur / Engine Stop Lever
P Ompe D'engrenage / Gear Pump
P Iston Et Vilebrequin / Crankshaft
V Olant Moteur / Flywheel
P Orte-Injecteur / Nozzle Holder
P Laque De Limiteur De Vitesse / Speed Control Plate
R Egulateur De Regime / Governor
Bride A Eau / Water Fla Nge
Pompe A Eau / Water Pum P
Radiateur / Radiator
Arbre A Cames De Carburant / Fuel Ca Mshaft
[Component Parts]
[Component Parts]
[M ] [O]
[F] [G]
[F] [G]
[Component Parts]
[Component Parts]
[M][O]
[M][O]
[F][G]
[F][G]
[M][O]
[F][G]
[F][O]
[G][M]
[F][G]
[F][G]
[Component Parts]
Couvercle De Carter / Case Co Ver And Lift
Distributeur 1 / Control Valv E 1
Distributeur 2 / Control Valv E 2
Systeme Hydraulique / Oil Pre Ssure Pipe
Pompe Hydraulique / Oil Press Ure
Carter De Transmission / Transmission Ca Se And Differential Case
Couvre / Cover
Carter D'essieu / Axle Case
Ier Arbre Et 2eme Arbre / Ist Shaft And 2nd Shaft
3eme Arbre / 3rd Shaft
Arbre D'entrainement Avant Et 6eme Arbre / Front Drive Shaft And 6th Shaft
7eme Arbre Et Arbre De Prise De Force / 7th Shaft And Pto Shaft
Embrayage / Clutch
Pedale / Pedal
Pedale / Pedal
[F]
[F]
[G][M]
[O]
[F]
[B8200ep]
[B8200ept]
[B8200ept]
[B8200dp]
[B8200dpt]
[B8200dp]
[B8200dp]
Levier De Changeme Nt De Vitesse / Main Speed Change
Fourchette De Chan Gement De Vitesse / Speed Change Fork
Fourchette D'entra Inement Avant / Front Drive Fork
Fourchette De Chan Gement De Vitesse / Rotary Speed Change Fork
Levier De Vitesse- Changement 1 / Speed Change Lever 1
Levier De Vitesse- Changement 2 / Speed Change Lever 2
Pedale Differentie L / Diff Lock Pedal
Levier A Relacher / Release Lever
Fre In / Brake
Plateau Du Lote / Side Plate A Nd Hitch
Aile / Fender
Couvercle De Changement De Vit Esse / Speed Change Cover
Couvre / Cover
[F][O]
Pedale / Pedal
Couvre / Cover
[M][O]
[M][O]
[F][G]
Capot / Skirt
Support De Capot / Bonnet Brac Ket
[F][G]
[F][G]
[F][G]
[B8200dp]
[B8200dp]
Direction / Steering
[M][O]
[F][G]
Cha Ssis De Marchepied / Step And Frame
[B8 200e]
[B8 200e]
[B8200d]
[B8200d]
[B8200d]
[ B8200d]
[B8200d]
[B8200d]
[B8200d]
[B8200d]
[B8200d]
Accessoires Et Pieces Service / Accessorie S And Service Parts Group
[Component Parts]
[Component Parts]
[M ] [O]
[F] [G]
[F] [G]
[Component Parts]
[Component Parts]
[M][O]
[M][O]
[F][G]
[F][G]
[M][O]
[F][G]
[F][O]
[G][M]
[F][G]
[F][G]
[Component Parts]
Couvre / Cover
Embrayage / Clutch
Pedale / Pedal
Pedale / Pedal
[F]
[F]
[G][M]
[O]
[F]
[B8200ep]
[B8200ept]
[B8200ept]
[B8200dp]
[B8200dpt]
[B8200dp]
[B8200dp]
Fre In / Brake
Aile / Fender
Couvre / Cover
[F][O]
Pedale / Pedal
Couvre / Cover
[M][O]
[M][O]
[F][G]
Capot / Skirt
[F][G]
[F][G]
[F][G]
[B8200dp]
[B8200dp]
[M][O]
[F][G]
[B8 200e]
[B8 200e]
[B8200d]
[B8200d]
[B8200d]
[ B8200d]
[B8200d]
[B8200d]
[B8200d]
[B8200d]
[B8200d]
