Kubota Tractor B3150HDB-F Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B3150HDB-F Tractor
Number of Pages: 249 Pages
Frequently Used I Tems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe ( Air Cleaner)
Silencieux / Muffler
Tige D'accelerateur / Accelerator Rod
Reservoir A Carburant / Fuel Ta Nk
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Com Posantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel Pum P
Ventilateur / Fan
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Reservoir Du Radia Teur / Reserve Tank
Contact A Huile Thermom Etre / Oil Switch And Thermo Sensor
Solenoide D'arret / Sto P Solenoid
Alternateur Complet / A Lternator
Alternateur [Parties Co Mposantes] / Alternator [Component Parts]
Demarreur / Starter
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Panel Board
Tableau De Bord [Pieces Composantes] / Panel Board [Component Parts]
Tableau De Commutateur / Panel Switch
Phare / Head Light
Phare / Head Light
Feux De Combinaison Ava Nt / Front Combination Lamp
Feux De Combinaison Arr Iere / Rear Combination Lamp
Lamp Et Plaque D'immatr Iculation / License Lamp
Prise De Remorque / Tra Iler Socket
Faisceau Electrique / E Lectrical Wiring
Couvercle De Carter De Embrayage / Clutch Ho Using Cover
Chassis Second / Sub Frame
Differentiel Avant / Front Differenti Al
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Cas E
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front D Rive Shaft
Carter De Transmission / Transmissi On Case
Carter De Differentiel / Differenti Al Gear Case
Carter De Pont Arriere G. / Rear Ax Le Case Lh
Carter De Pont Arriere D. / Rear Ax Le Case Rh
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller S Haft
Hst / Hst
Hst (Cas) [Parties Composantes] 1 / Hst (Case) [Component Parts] 1
Hst (Pompe) [Parties Composantes] 2 / Hst (Pump) [Component Parts] 2
Hst (Moteur) [Parties Composantes] 3 / Hst (Motor) [Component Parts] 3
Hst (Couvercle De Bloc D'orifice) [ Parties Composantes] 4 / Hst (Port Block Cover) [Co Mponent Parts] 4
Hst (Support De Neutre) [Parties Co Mposantes] 5 / Hst (Neutral Holder) [Component Part S] 5
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre De Changement De Gamme / Rang E Gear Shaft
Arbre De Marche Arriere / Reverse S Haft
Arbre Primaire De Pdf / Pto Drive S Haft
Arbre De Pdf Embrayage / Pto Clutch Shaft
Pdf Ventrale / Mid Pto
Changement De Gamme / Range Gear
Differentiel Arriere / Rear Differe Ntial
Bras De Chengement De Vites Se Pdf / Pto Gear Shift Arm
Fourchette De Blocage Diffe Rentiel / Differential Lock Shift Fork
Pedale De Commande De Vites Se / Speed Change Pedal
Tige De Commande De Vittess E / Speed Change Rod
Bras De Securite De Hst / H St Release Arm
Levier De Changement De Gam Me / Range Shift Lever
Levier De Tranission Aux Ro Ues Avant / Front Wheel Drive Lever
Levier De Commande D'avance / Cruise Control Lever
Croisière De Presse Cable / Cruise Release Cable
Levier De Chengement De Vit Esse Pdf / Pto Gear Shift Lever
Levier De Position / Positi On Control Lever
Levier De Distributeur De C Hargeur / Loader Valve Lever
Pedale De Verrouillage Du D Ifferentiel / Differential Lock Pedal
Arbre De Braquage 2 Vitesses / Bi-Speed Turn Shaft
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Bras De Demi-Tour Rapide / Bi-Sp Eed Turn Arm
Tige De Virage A 2 Vitesses / Bi -Speed Shift Rod
Colonne De Direction / Steering Wheel
Colonne De Direction / Steering Post
Cylindre De Direction / Steering Cylinder
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [ Parties Composantes] / Hydraulic Pump [Component Pa Rts]
Circuit D'huile Hyd Raulique (Aspirat) / Hydraulic Pipe (Suction)
Circuit D'huile Hyd Raulique (Refoulement) / Hydraulic Oil Line (Delive Ry)
Circuit D'huile Hyd Raulique (Direction) / Hydraulic Oil Line (Steering )
Circuit D'huile Hyd Raulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hyd Raulique (Refroidissement) / Hydraulic Oil Line (Oi L Cooler)
Circuit D'huile Hyd Raulique (F/M) / Hydraulic Oil Line (F/M)
Distributeur De Cha Rgeur / Loader Valve
Distributeur De Cha Rgeur [Parties Composantes] / Loader Valve [Compone Nt Parts]
Biellete De Distrib Uteur De Chargeur / Loader Valve Link
Tuyau De Chargeur D E Hydraulique / Hydraulic Loader Pipe
Cylindre Hydrauliqu E / Hydraulic Cylinder
Piston Hydraulique/ Bras De Relevage / Hydraulic Piston/Lift Arm
Levier De Controle De Position / Feed Back Lever
Distributeur [Parti Es Composantes] / Control Valve [Component Parts]
Tombent Ajustement Arbre / Fall Adjustment Shaft
Soupape De Pdf / Pt O Valve
Soupape De Pdf [Par Ties Composantes] / Pto Valve [Component Parts]
Barre De Relevage / Lift Rod
Tirant Inferieur / Lower Link
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere / Rear Hitch
Protection Pdf / Pto Protector
Capot Superieur / Hood (Bonnet) Upper
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Plancher / Floor Sheet
Siege (Cobo Sc74/M91) / Seat (Cobo Sc74/M91 )
Siege (Grammer Msg83/511) / Seat (Grammer M Sg83/511)
Siege (Grammer Msg93/511) / Seat (Grammer M Sg93/511)
Siege (Sears 807) / Seat (Sears 807)
Siege (Sears 830) / Seat (Sears 830)
Marchepied / Step
Modification Insonore / Sound Absorber
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Cadre Anti-Renversment / Rops
Roue Avant (24*8,50-12) / Front Wheel (24*8.50-12)
Roue Arriere (12,4-16) / Rear Wheel ( 12.4-16)
Roue Arriere (13,6-16) / Rear Wheel (13.6-16)
Accessories Et Piece De Service / Accessories And Service Parts
Eclairage De Travail [Option] / Working Light K It [Option]
Cylindre De Relevage (Bras De Relevage) [Option ] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mowe R Lift Cylinder Kit (Cylinder) [Option]
Equipement Du Debouche Hydraulique Avant [Optio N] / Front Hydraulic Outlet Kit [Option]
