Kubota Tractor B3150HDB-F Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota B3150HDB-F Tractor
Number of Pages: 441 Pages
B3150hdb-F
B3150hdb-F Frequently Used Items Frequently Used Items Frequently Used Items Frequently
B3150hdb-F Motor Engine Kurbelghaeuse Crankcase
B3150hdb-F Motor Engine Ol-Fanger Oil Pan
B3150hdb-F Motor Engine Zylinderkopf Cylinder Head
B3150hdb-F Motor Engine Getriebe Gehaeuse Gear Case
B3150hdb-F Motor Engine Zylinderkopf-Deckel Head Cover
B3150hdb-F Motor Engine Oelfilter Oil Filter
B3150hdb-F Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
B3150hdb-F Motor Engine Hauptlagergehäuse Main Bearing Case
B3150hdb-F Motor Engine Nockenwelle Und Welle,Freilaufgetr Camshaft And Idle Gear
B3150hdb-F Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
B3150hdb-F Motor Engine Schwungrad Flywheel
B3150hdb-F Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
B3150hdb-F Motor Engine Freilaufapparat Idle Apparatus
B3150hdb-F Motor Engine Einspritzpumpe Injection Pump
B3150hdb-F Motor Engine Zylinderkopf Governor
B3150hdb-F Motor Engine Geschwindigkeitskontrolle Nockenhohn Speed Control
B3150hdb-F Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow
B3150hdb-F Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component
B3150hdb-F Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
B3150hdb-F Motor Engine Wasserpumpe Water Pump
B3150hdb-F Motor Engine Ventil Und Kippenarmwelle Valve And Rocker Arm
B3150hdb-F Motor Engine Einlasskruemmer Inlet Manifold
B3150hdb-F Motor Engine Auspuffrummer Exhaust Manifold
B3150hdb-F Motor Engine Luftfilter Air Cleaner
B3150hdb-F Motor Engine Ansaugenrohr (Luftreinheit) Inlet Pipe (Air Cleaner)
B3150hdb-F Motor Engine Auspufftopf Muffler
B3150hdb-F Motor Engine Oberdichtung-Geraet Upper Gasket Kit
B3150hdb-F Motor Engine Unterdichtung-Geraet Lower Gasket Kit
B3150hdb-F Motor Engine Beschleunigung-Hebel Accelerator Lever
B3150hdb-F Motor Engine Beschleunigung-Stange Accelerator Rod
B3150hdb-F Brennstoff System Fuel System Kraftstofftank Fuel Tank
B3150hdb-F Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
B3150hdb-F Brennstoff System Fuel System Kraftstoffsieb Fuel Filter
B3150hdb-F Brennstoff System Fuel System Kraftstoff-Filter [Einzel-Teil] Fuel Filter [
B3150hdb-F Brennstoff System Fuel System Kraftstoffpumpe Fuel Pump
B3150hdb-F Abkuehlung System Cooling Water System Ventilator Fan
System Cooling Water System Wasserrohr Water Pipe ## Note Order By Ref.No.060,070 New Parts.
Radiator ## Note Order By Ref.No.040,220 And Fig.No. Ref.No.170 And Fig.No. Ref.No.120,130 New Parts.
B3150hdb-F Abkuehlung System Cooling Water System Reservebehalter Reserve
B3150hdb-F Elektrisch System Electrical System Oelschalter Thermometer Oil Switch And
B3150hdb-F Elektrisch System Electrical System Stop Solenoid Stop Solenoid
B3150hdb-F Elektrisch System Electrical System Lichtmaschine Alternator
B3150hdb-F Elektrisch System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
B3150hdb-F Elektrisch System Electrical System Anlasser Starter
B3150hdb-F Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter [Component
B3150hdb-F Elektrisch System Electrical System Batterie Battery
B3150hdb-F Elektrisch System Electrical System Schalter Switch
B3150hdb-F Elektrisch System Electrical System Relais Relay
Instrumentenbrett Panel Board ## Note Order By Ref.No.030 New Part And Fig.No. Ref.No.
B3150hdb-F Elektrisch System Electrical System Instrumentenbrett [Einzel-Teil] Panel Board [
B3150hdb-F Elektrisch System Electrical System Wandplatte Schalter Panel
B3150hdb-F Elektrisch System Electrical System Scheinwerfer Head Light
B3150hdb-F Elektrisch System Electrical System Vorderseite Konbination-Licht Front
B3150hdb-F Elektrisch System Electrical System Hinter Kombination-Licht Rear Combination
B3150hdb-F Elektrisch System Electrical System Lampara De La Marticula License
B3150hdb-F Elektrisch System Electrical System Anhaengerkupplung Trailer
B3150hdb-F Elektrisch System Electrical System Elektrische Ausrustung Electrical
B3150hdb-F Kupplung Clutch Kupplung-Gehaeuse Clutch Housing
B3150hdb-F Kupplung Clutch Kupplung-Gehaeuse Deckel Clutch Housing Cover
B3150hdb-F Vorderachse Front Axle Mittlerahmeh Center Frame
B3150hdb-F Vorderachse Front Axle Sekunderahmen Sub Frame
B3150hdb-F Vorderachse Front Axle Vorderrachse-Rahmen Front Axle Frame
B3150hdb-F Vorderachse Front Axle Vorderachse Gehaueuse Front Axle Case
B3150hdb-F Vorderachse Front Axle Vorderachsen-Differential Front Differential
B3150hdb-F Vorderachse Front Axle Antriebskegelrad Links Bevel Gear Lh
B3150hdb-F Vorderachse Front Axle Antriebskegelrad Rechts Bevel Gear Rh
B3150hdb-F Vorderachse Front Axle Winkelzahnradgehaeuse Bevel Gear Case
B3150hdb-F Vorderachse Front Axle Vorderachse-Gehaeuse Links Front Axle Case
B3150hdb-F Vorderachse Front Axle Vorderachse-Gehaeuse Rechs Front Axle Case
B3150hdb-F Vorderachse Front Axle Vorderachse Front Axle Lh
B3150hdb-F Vorderachse Front Axle Vorderradachse Rechts Front Axle Rh
B3150hdb-F Vorderachse Front Axle Vorderantriebswelle Front Drive Shaft
B3150hdb-F Transmission Transmission Carcasa Caja Transferencia Transmission
B3150hdb-F Transmission Transmission Differentialgetriebegehaeuse Differential
B3150hdb-F Transmission Transmission Hinterradachsegehaeuse Ls Rear Axle Case
B3150hdb-F Transmission Transmission Hinterradachsegehaeuse Rs Rear Axle Case
B3150hdb-F Transmission Transmission Kupplung-Welle Clutch Shaft
B3150hdb-F Transmission Transmission Abstuetzung Rechts Vorne Propeller Shaft
B3150hdb-F Transmission Transmission Hst Hst
B3150hdb-F Transmission Transmission Hst (Antriebswelle) [Einzel-Teil] Hst (Case) [Component
B3150hdb-F Transmission Transmission Hst (Pumpe) [Einzel-Teil] Hst (Pump) [Component
B3150hdb-F Transmission Transmission Hst (Motor) [Einzel-Teil] Hst (Motor) [Component
F Transmission Transmission Hst (Portblockdeckel) [Einzel-Teil] 4 Hst (Port Block Cover)
F Transmission Transmission Hst (Neutralhalter) [Einzel-Teil] 5 Hst (Neutral Holder) [
B3150hdb-F Transmission Transmission Erstewelle First Shaft
B3150hdb-F Transmission Transmission Zweitewelle Second Shaft
B3150hdb-F Transmission Transmission Drittewelle Third Shaft
B3150hdb-F Transmission Transmission Drehzahlbereichswelle Range Gear Shaft
B3150hdb-F Transmission Transmission Umkeheren-Welle Reverse Shaft
B3150hdb-F Transmission Transmission Zapfantriebswelle Pto Drive Shaft
B3150hdb-F Transmission Transmission Zapfkupplung-Welle Pto Clutch Shaft
B3150hdb-F Transmission Transmission Zapfwellenkupplung Pto Clutch
B3150hdb-F Transmission Transmission Mittlere Zapfwelle Mid Pto
B3150hdb-F Transmission Transmission Drehzahlbereichszahnrad Range Gear
B3150hdb-F Transmission Transmission Hinterdifferential Rear Differential
B3150hdb-F Getriebe System Speed Change Drehzahlbereichsschaltgabel Range Gear
B3150hdb-F Getriebe System Speed Change Zapfwellenarm Pto Gear Shift Arm
B3150hdb-F Getriebe System Speed Change Fourchette Fur Differentialsperre Differential
B3150hdb-F Getriebe System Speed Change Drehzahlaenderpedal Speed Change
B3150hdb-F Getriebe System Speed Change Drehzahlreglerstange Speed Change
B3150hdb-F Getriebe System Speed Change Hst Auslosearm Hst Release Arm
B3150hdb-F Getriebe System Speed Change Drehzahlbereichshebel Range Shift
B3150hdb-F Getriebe System Speed Change Palanca Conductor De Rueda Delantera Front
B3150hdb-F Getriebe System Speed Change Tempomat-Schalthebel Cruise Control
B3150hdb-F Getriebe System Speed Change Drehzahlfreigabezug Cruise Release
B3150hdb-F Getriebe System Speed Change Zapfwellenschalthebel Pto Gear Shift
B3150hdb-F Getriebe System Speed Change Positions-Steuerhebel Position Control
B3150hdb-F Getriebe System Speed Change Laderventilhebel Loader Valve Lever
System Speed Change Bremspedal Brake Pedal ## Note Order By Ref.No.010.020.070 New Parts.
B3150hdb-F Getriebe System Speed Change Differentialsperrepedal Differential Lock
B3150hdb-F Getriebe System Speed Change Bi-Speed-Welle Bi-Speed Turn Shaft
B3150hdb-F Hinterradachse Rear Axle Hinterradachse Links Rear Axle Lh
B3150hdb-F Hinterradachse Rear Axle Hinterradachse Rechts Rear Axle Rh
B3150hdb-F Bremse Brake Bremse Links Brake Lh
B3150hdb-F Bremse Brake Bremse Rechts Brake Rh
B3150hdb-F Bremse Brake Bremsstange Brake Rod
B3150hdb-F Bremse Brake Handbremsehebel Parking Brake Lever
B3150hdb-F Kontrollhebel Operation Bi-Speed-Arm Bi-Speed Turn Arm
B3150hdb-F Kontrollhebel Operation Kurve A Geschwindgkeiten Stange Bi-Speed
B3150hdb-F Lenkung Steering Lenkrad Steering Wheel
B3150hdb-F Lenkung Steering Kardangelenk Steering Post
B3150hdb-F Lenkung Steering Lenkradverstellpedal Tilt Pedal
B3150hdb-F Lenkung Steering Lenkung Steering
B3150hdb-F Lenkung Steering Lenkungszylinder Steering Cylinder
B3150hdb-F Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [Component
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic
F Pumpe Motor System Pump Motor System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf(Ausaug) Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Zuleitung) Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Lenkung) Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Hst) Hydraulic
F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Oelkuehler) Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (F M) Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Laderventil Loader Valve
B3150hdb-F Pumpe Motor System Pump Motor System Laderventil [Bauteile] Loader Valve [
B3150hdb-F Pumpe Motor System Pump Motor System Laderventilverbindung Loader
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulikladerrohr Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulikzylinder Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Hydraulikkolben Hubarm Hydraulic
B3150hdb-F Pumpe Motor System Pump Motor System Palanca Control Feed Back
B3150hdb-F Pumpe Motor System Pump Motor System Kontrollventil Control Valve
F Pumpe Motor System Pump Motor System Regelungsventil [Einzel-Teil] Control Valve
B3150hdb-F Pumpe Motor System Pump Motor System Herbst Einstellwelle Fall Adjustment
B3150hdb-F Pumpe Motor System Pump Motor System Zapfventil Pto Valve
B3150hdb-F Pumpe Motor System Pump Motor System Zapfventil [Einzel-Teil] Pto Valve [
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hubstange
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Unterlenker
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Oberlenker
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Fuehrungskette
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Anhangerku
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hangung
B3150hdb-F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hinteranhangung
F Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Schutzabdeckung
B3150hdb-F Motorhaube Hood Bonnet Vorder-Gitter Front Grille
B3150hdb-F Motorhaube Hood Bonnet Motorhaube Hood (Bonnet) Upper
B3150hdb-F Motorhaube Hood Bonnet Instrumentenbrett-Deckel Panel Cover
B3150hdb-F Motorhaube Hood Bonnet Seitedeckel Side Cover
B3150hdb-F Motorhaube Hood Bonnet Abdecking Shutter Plate
B3150hdb-F Motorhaube Hood Bonnet Rueckspiegel Rearview Mirror
B3150hdb-F Motorhaube Hood Bonnet Hebelfuehrung Ls Lever Guide Lh
B3150hdb-F Motorhaube Hood Bonnet Hebelfuehrung Rs Lever Guide Rh
B3150hdb-F Motorhaube Hood Bonnet Kotfluegel Fender
B3150hdb-F Motorhaube Hood Bonnet Aufboden Floor Sheet
B3150hdb-F Motorhaube Hood Bonnet Sitz Traeger Seat Support
B3150hdb-F Motorhaube Hood Bonnet Sitz (Cobo Sc74 M91) Seat (Cobo Sc74 M91)
B3150hdb-F Motorhaube Hood Bonnet Sitz (Grammer Msg83 511) Seat (Grammer Msg83
B3150hdb-F Motorhaube Hood Bonnet Sitz (Grammer Msg93 511) Seat (Grammer Msg93
B3150hdb-F Motorhaube Hood Bonnet Sitz (Sears 807) Seat (Sears 807)
B3150hdb-F Motorhaube Hood Bonnet Sitz (Sears 830) Seat (Sears 830)
B3150hdb-F Motorhaube Hood Bonnet Tritt Step
B3150hdb-F Motorhaube Hood Bonnet Anti-Larm Modifikation Sound Absorber
B3150hdb-F Motorhaube Hood Bonnet Hintere-Deckel Tail Cover
B3150hdb-F Motorhaube Hood Bonnet Werkzeugkasten Tool Box
B3150hdb-F Motorhaube Hood Bonnet Sicherheitsrahmen Rops
B3150hdb-F Vorderrad Front Wheel Vorderrad (7-12) Front Wheel (7-12)
B3150hdb-F Vorderrad Front Wheel Vorderrad (24 8,50-12) Front Wheel (24 8.50-12)
B3150hdb-F Hinterrad Rear Wheel Hinterrad (12,4-16) Rear Wheel (12.4-16)
B3150hdb-F Hinterrad Rear Wheel Hinterrad (13.6-16) Rear Wheel (13.6-16)
B3150hdb-F Aufkleber Labels Aufkleber (Vorder) Label (Front)
B3150hdb-F Aufkleber Labels Aufkleber (Hintern) Label (Rear)
Zubehoer Und Service Teile Accessories And Service Parts Sontiges Zubehor Und Service-
B3150hdb-F Option Option Arbeitsscheinwerfer [Option] Working Light Kit [Option]
B3150hdb-F Option Option Kraftheberzylinder (Hubarm) [Option] Mower Lift Cylinder Kit (Lift
B3150hdb-F Option Option Kraftheberzylinder (Zylinder) [Option] Mower Lift Cylinder Kit (
B3150hdb-F Option Option Vordergewicht [Option] Front Weight Kit [Option]
B3150hdb-F Option Option Vorderer Hydraulikanschluss [Option] Front Hydraulic Outlet
B3150hdb-F
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
