Kubota Tractor B3030HDBC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B3030HDBC Tractor
Number of Pages: 627 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Light
Licencia Lampara / License Lamp
Funcionamiento Luz / Working Light
Panel De Control De Aire Acondicionado / Air-Con.Control Panel
Limpiaparabrisas / Wiper
Electrico Cableado (Cuerpo) / Electrical Wiring (Body)
Electrico Cableado (Cabina) / Electrical Wiring (Cab)
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Bloque De Cilindros) [Componente Piezas]1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Puerto Cubierta Del Bloque) [Componente Piezas]2 / Hst (Port Block Cover) [Component Parts] 2
Hst (Junta) [Componente Piezas]3 / Hst (Gasket) [Component Parts] 3
Hst (Soporte Neutral) [Componente Piezas]4 / Hst (Neutral Holder) [Component Parts] 4
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Pto Accionar Eje / Pto Drive Shaft
Pto Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Gama Engranaje / Range Gear
Freno Derecho / Brake Rh
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Vara De Liberación De Velocidad / Cruise Release Rod
Hst Desbloquear Brazo / Hst Release Arm
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Coloque La Palanca De Mando / Position Control Lever
Alejado Contorol Palanca / Remote Control Lever
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea (Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line(Hst)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line(Oil Cooler)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line(F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Alejado Contorol Valvula / Remote Control Valve
Alejado Contorol Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Pto Valvula / Pto Valve
Pto Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Adelante Eje Caja Izquierdo / Axle Case Lh
Adelante Eje Caja Derecho / Axle Case Rh
Adelante Eje Iz / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Direccion Poste / Steering Post
Direccion Cilindro / Steering Cylinder
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet
Lado Cubierta / Side Cover
Centro Montante / Center Pillar
Cabina / Cab
Panel Inferior / Panel Under
Cabina / Cab
Peldano / Step
Asiento Inferior Cubierta / Seat Under Cover
Guardabarros Cubierta / Fender Cover
Encima Guardabarros / Over Fender
Cola Cubierta / Tail Cover
Puerta Izqd / Door Lh
Puerta Derecho / Door Rh
Cerradura De Puerta Izqd / Door Lock Lh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Ruido Supresion / Noise Suppression
Amortiguador De Sonido Trasero / Sound Absorber Rear
Placa De Aislacion / Insulation Plate
Interior Cubierta / Interior Cover
Asiento (Cobo Sc74/M91) [Excepto Alemania] / Seat (Cobo Sc74/M91) [Except Germany]
Asiento (Grammer Msg83/8) [Alemania] / Seat (Grammer Msg83/8) [Germany]
Asiento (Kab Seating Xh2/P1) [Excepto Alemania] / Seat (Kab Seating Xh2/P1) [Except Germany]
Asiento (Kab Seating 11/P1) [Excepto Alemania] / Seat (Kab Seating 11/P1) [Except Germany]
Asiento (Sears Mcs3000) [Excepto Alemania] / Seat (Sears Mcs3000) [Except Germany]
Adelante Vidrio Y Trasero Vidrio / Front Glass And Rear Glass
Lado Vidrio / Side Glass
Compuerta Trasero Vidrio / Hatch Back Glass
Bisagras Para Vidrio De Automóvil De Tres Puertas / Hatch Back Glass Hinge
Aire Acondicionador Operador / Air Conditioner Operation
Manguera De Vaciado(Aire Acondicionador) / Drain Hose(Air Conditioner)
Condensador / Condenser
Aire Acondicionador Tubo / Air Conditioner Pipe
Compresor / Compressor
Aire Acondicionador Conducto / Air-Conditioner Duct
Rueda Delantera(7-12) / Front Wheel(7-12)
Rueda Delantera (7-12) / Front Wheel (7-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Posterior(12,4-16) / Rear Wheel(12.4-16)
Rueda Trasera (13,6-16) / Rear Wheel(13.6-16)
Etiqueta (Adelante) [Excepto Italiano] / Label (Front) [Except Italian]
Etiqueta (Adelante) [Italiano] / Label (Front) [Italian]
Etiqueta (Trasero) [Ingles] / Label (Rear) [English]
Etiqueta (Trasero) [Espanol] / Label (Rear) [Spanish]
Etiqueta (Trasero) [Italiano] / Label (Rear) [Italian]
Etiqueta(Trasero) / Label (Rear)
Alternador Kit[Opcion] / Alternator Kit [Option]
Alternador[Componente Piezas][Opcion] / Alternator [Component Parts] [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
3-P Kit De Varillaje 1(Ascenso Varilla) [Opcion] / 3-P Link Kit 1(Lift Rod) [Option]
3-P Kit De Varillaje 2(Bajar Vinculo) [Opcion] / 3-P Link Kit 2(Lower Link) [Option]
3-P Kit De Varillaje 3(Estabilizador) [Opcion] / 3-P Link Kit 3(Stabilizer) [Option]
Cortacespedes Ascenso Cilindro(Ascenso Brazo)[Opcion] / Mower Lift Cylinder Kit(Lift Arm) [Option]
Cortacespedes Ascenso Cilindro(Ascenso Brazo)[Opcion] / Mower Lift Cylinder Kit(Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
