Kubota Tractor B3030HDB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B3030HDB Tractor
Number of Pages: 533 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Lamp
Licencia Lampara / License Lamp
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Bloque De Cilindros) [Componente Piezas] 1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Puerto Cubierta Del Bloque) [Componente Piezas] 2 / Hst (Port Block Cover) [Component Parts] 2
Hst (Junta) [Componente Piezas] 3 / Hst (Gasket) [Component Parts] 3
Hst (Soporte Neutral) [Componente Piezas] 4 / Hst (Neutral Holder) [Component Parts] 4
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Pto Accionar Eje / Pto Drive Shaft
Pto Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Gama Engranaje / Range Gear
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno / Brake Rod
Vara De Liberación De Velocidad / Cruise Release Rod
Hst Desbloquear Brazo / Hst Release Arm
Coloque La Palanca De Mando / Position Control Lever
Alejado Contorol Palanca / Remote Control Lever
Freno Pedal / Brake Pedal
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Speed Control Plate
Adelante Eje Iz / Front Axle Lh
Eje Delantero Dr / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Direccion Poste / Steering Post
Speed Control Plate
Direccion Cilindro / Steering Cylinder
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Alejado Contorol Valvula / Remote Control Valve
Alejado Contorol Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Pto Valvula / Pto Valve
Pto Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Superior Vinculo / Top Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Hood (Bonnet)
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Centro Montante / Center Pillar
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento(Cobo Sc74/M91) / Seat(Cobo Sc74/M91)
Asiento(Grammer Msg83/8) / Seat(Grammer Msg83/8)
Asiento(Kab Seating Xh2/P1) / Seat(Kab Seating Xh2/P1)
Asiento(Kab Seating 11/P1) / Seat(Kab Seating 11/P1)
Asiento(Sears Mcs3000) / Seat(Sears Mcs3000)
Peldano / Step
Cola Cubierta / Tail Cover
Rops
Rueda Delantera(7-12) / Front Wheel(7-12)
Rueda Delantera(24*8,50-12) / Front Wheel(24*8.50-12)
Rueda Posterior(12,4-16) / Rear Wheel(12.4-16)
Rueda Trasera (13,6-16) / Rear Wheel(13.6-16)
Etiqueta (Adelante) [Excepto Italiano] / Label (Front) [Except Italian]
Etiqueta (Adelante) [Italiano] / Label (Front) [Italian]
Etiqueta (Trasero) [Ingles] / Label (Rear) [English]
Etiqueta (Trasero) [Espanol] / Label (Rear) [Spanish]
Etiqueta (Trasero) [Italiano] / Label (Rear) [Italian]
Etiqueta(Trasero) / Label (Rear)
Rueda Intermitente Soporte [Opcion] / Front Winker Stay Kit [Option]
3-P Kit De Varillaje 1(Ascenso Varilla) [Opcion] / 3-P Link Kit 1(Lift Rod) [Option]
3-P Kit De Varillaje 2(Bajar Vinculo) [Opcion] / 3-P Link Kit 2(Lower Link) [Option]
3-P Kit De Varillaje 3(Estabilizador) [Opcion] / 3-P Link Kit 3(Stabilizer) [Option]
Cortacespedes Ascenso Cilindro(Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit(Lift Arm) [Option]
Cortacespedes Ascenso Cilindro(Cilindro) [Opcion] / Mower Lift Cylinder Kit(Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Hst
Speed Control Plate
Speed Control Plate
Pto Protector
Peldano / Step
Rops
