Kubota Tractor B3030HDB(EC) Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B3030HDB(EC) Tractor
Number of Pages: 342 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear C Ase
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camsha Ft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Crankshaf T
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateu R / Fuel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / N Ozzle Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzl E Holder [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Tige D'accelerateur / Accelerator Rod
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtlre A Essence / Fuel Filt Er
Filtre A Carburant [Parties C Omposantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel P Ump
Ventilateur / Fa N
Tuyau D'eau / Wa Ter Pipe
Radiateur / Radi Ator
Reservoir Du Rad Iateur / Reserve Tank
Contact A Huile Therm Ometre / Oil Switch And Thermo Sensor
Solenoide D'arret / S Top Solenoid
Alternateur Complet / Alternator
Alternateur [Parties Composantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Pan El Board
Tableau De Bord (Piec Es Composantes) / Panel Board [Component Parts]
Tableau De Commutateu R / Panel Switch
Phare [Uk] / Head Lig Ht [Uk]
Phare [Ec] / Head Lig Ht [Ec]
Feux De Combinaison A Vant / Front Combination Lamp
Feux De Combinaison A Rriere / Rear Combination Lamp
Lamp Et Plaque D'imma Triculation [Uk] / License Lamp [Uk]
Lamp Et Plaque D'imma Triculation [Ec] / License Lamp [Ec]
Prise De Remorque / T Railer Socket
Faisceau Electrique / Electrical Wiring
Couvercle De Carter De Embrayage / Clutch Housing Cover
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differen Tial
Engrenage Conique Gauche / Bevel Ge Ar Lh
Engrenage Conique Droite / Bevel Ge Ar Rh
Carter Engre-Conique / Bevel Gear C Ase
Carter Reducteur Gauche / Front Axl E Case Lh
Carter Reducteur Droite / Front Axl E Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front Drive Shaft
Carter De Transmission / Transmis Sion Case
Carter De Differentiel / Differen Tial Gear Case
Arbre De Embrayage / Clutch Shaft
Hst / Hst
Hst (Couvercle De Bloc D'orifice) [Parties Composantes] 2 / Hst (Port Block Cover) [ Component Parts] 2
Hst (Joint) [Parties Composantes] 3 / Hst (Gasket) [Component Parts] 3
Hst (Support De Neutre) [Parties Composantes] 4 / Hst (Neutral Holder) [Component Pa Rts] 4
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre De Changement De Gamme / Ra Nge Gear Shaft
Arbre De Marche Arriere / Reverse Shaft
Arbre Primaire De Pdf / Pto Drive Shaft
Arbre De Pdf Embrayage / Pto Clut Ch Shaft
Pdf Embrayage / Pto Clutch
Pdf Ventrale / Mid Pto
Changement De Gamme / Range Gear
Differentiel Arriere / Rear Diffe Rential
Carter De Pont Arriere G. / Rear A Xle Case Lh
Carter De Pont Arriere D. / Rear A Xle Case Rh
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Bras De Chengement De Vit Esse Pdf / Pto Gear Shift Arm
Fourchette De Blocage Dif Ferentiel / Differential Lock Shift Fork
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Brak E Lever
Pedale De Commande De Vitesse / Speed Change Pedal
Tige De Commande De Vittesse / Speed Change Rod
Tige De Securite De Croisiere / Cruise Release Rod
Bras De Securite De Hst / Hst Release Arm
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Levier De Controle De Croisier E / Cruise Control Lever
Levier De Chengement De Vitess E Pdf / Pto Gear Shift Lever
Levier De Position / Position Control Lever
Levier De Distributeur Auxilia Ire / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Diff Erentiel / Differential Lock Pedal
Bras De Demi-Tour Rapide / Bi- Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Speed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Speed Turn Shaft
Colonne De Direction / Steering Post
Pedale De Inclinaison / Tilt Pedal
Barrd De Accouplement/Cylindre De Direct Ion / Steering Cylinder
Cylindre De Direction [Parties Composant Es] / Steering Cylinder [Component Parts]
Support Avant Dro It / Hydraulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydraulique (Aspiration) / Hydraulic Oil Line (Suct Ion)
Circuit D'huile H Ydraulique (Refoulement) / Hydraulic Oil Line (Deli Very)
Circuit D'huile H Ydraulique (Direction) / Hydraulic Oil Line (Steeri Ng)
Circuit D'huile H Ydraulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile H Ydraulique (Refroidisseur) / Hydraulic Oil Line (Oi L Cooler)
Circuit D'huile H Ydraulique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydrauli Que / Hydraulic Cylinder
Piston Hydrauliqu E/Bras De Relevage / Hydraulic Piston/Lift Arm
Distributeur [Par Ties Composantes] / Control Valve [Component Parts]
Controle Des Valv Es Auxiliaire / Remote Control Valve
Controle Des Valv Es Aux. [Parties Composantes] / Remote Control Valv E [Component Parts]
Tombent Ajustemen T Arbre / Fall Adjustment Shaft
Soupape De Surete / Relief Valve
Soupape De Pdf / Pto Valve
Soupape De Pdf [P Arties Composantes] / Pto Valve [Component Parts]
Barre De Relevage / Lift Rod
Tirant Inf Erieur / Lower Link
Tirant Sup Erieur / Top Link
Chaine De Arret / Check Chain
Barre D'at Telage / Drawbar
Attelage / Front Hitch
Attelage A Rriere / Rear Hitch
Capot Superieur / Hood (Bonnet)
Capot Lateral / Side Cover
Piller Centre / Center Pillar
Retroviseur [Uk] / Rearview Mirror [Uk]
Retroviseur [Ec] / Rearview Mirror [Ec]
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Aile / Fender
Aile / Fender
Plancher / Floor Sheet
Siege (Cobo Sc74/M91) [Excepte Allemagne] / Seat (Cobo Sc74/M91) [Except Germany]
Siege (Grammer Msg83/8) [Allemagne] / Sea T (Grammer Msg83/8) [Germany]
Siege (Kab Seating Xh2/P1) [Excepte Allem Agne] / Seat (Kab Seating Xh2/P1) [Except Germany]
Siege (Kab Seating 11/P1) [Excepte Allema Gne] / Seat (Kab Seating 11/P1) [Except Germany]
Siege (Sears Mcs3000) [Excepte Allemagne] / Seat (Sears Mcs3000) [Except Germany]
Marchepied / Step
Marchepied / Step
Couvercle Arriere / Tail Cover
Cadre Anti-Renversement / Rops
Roue Avant (7-12) / Front Wheel (7-12 )
Roue Avant (24*8,50-12) / Front Wheel (24*8.50-12)
Roue Arriere (12,4-16) / Rear Wheel (12.4-16)
Roue Arriere (13,6-16) / Rear Wheel (13.6-16)
Etiquette (Avant) [Excepte Italien] / Lab El (Front) [Except Italian]
Etiquette (Avant) [Italien] / Label (Fron T) [Italian]
Etiquette (Arriere) [Anglais] [Francais] / Label (Rear) [English] [French]
Etiquette (Arriere) [Italien] / Label (Re Ar) [Italian]
Accessories Et Piece De Service / Accessories A Nd Service Parts
Support Du Clignotant Avant [Option] / Front Winker Stay Kit [Option]
Eclairage De Travail [Option] / Working Light Kit [Option]
Pdf Ventrale(Pour Rck60-30b-Eu-F Tondeuse) [O Ption] / Mid Pto Kit(For Rck60-30b-Eu-F Mower) [Opt Ion]
Relevage 3-P 1 (Barre De Relevage) [Option] / 3-P Link Kit 1(Lift Rod) [Option]
Relevage 3-P 2 (Tirant Inferieur) [Option] / 3-P Link Kit 2(Lower Link) [Option]
Relevage 3-P 3 (Stabilisateur) [Option] / 3-P Link Kit 3(Stabilizer) [Option]
Cylindre De Relevage (Bras De Relevage) [Opti On] / Mower Lift Cylinder Kit(Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mo Wer Lift Cylinder Kit(Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Option]
Ventilateur / Fa N
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Relais / Relay
Hst / Hst
Aile / Fender
Aile / Fender
Aile / Fender
Marchepied / Step
Marchepied / Step
