Kubota Tractor B2710HDB Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2710HDB Tractor
Number of Pages: 212 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Pompe D'alimentation(Mecanique) / Fuel Pump(Mecha Nical)
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket K It [Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Compo Santes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Reservoir Du Radiate Ur / Reserve Tank
Alternateur Complet / Alt Ernator
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Tableau De Bord / Panel B Oard
Tableau De Bord (Pieces C Omposantes) / Panel Board [Component Parts]
Phare/Fuex Arriere / Head Light/Tail Lamp
Faisceau Electrique / Ele Ctrical Wiring
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedala D'embrayage / Clutch Pedal
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Carter De Differentiel / Differential Gear Case
Carter De Pont Arriere / Rear Axle Ca Se
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller Sha Ft
Hst / Hst
Hst / Hst
Hst [Parties Composantes] 1 / Hst [Co Mponent Parts] 1
Hst [Parties Composantes] 2 / Hst [Co Mponent Parts] 2
Hst [Parties Composantes] 3 / Hst [Co Mponent Parts] 3
Arbre De Avant / Front Shaft
Arbre De Prise De Force / Pto Shaft
Pdf Ventrale / Mid Pto
Differentiel Arriere / Rear Different Ial
Arbre D'entrainement Avant / Front Wh Eel Propeller Shaft
2eme Arbre / 2nd Shaft
3eme Arbre / 3rd Shaft
4eme Arbre / 4th Shaft
Axe Arriere / Rear Axle
Pedale De Verrouillage Du Differentiel / Differential Lock Pedal
Frein / Brake
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Brake Le Ver
Pedale De Frien / Brake Pedal
Levier De Vittese Constante / Speed Set Lever
Biellete De Support Neutre / Neutral Holder Link
Pedale De Commande Vitesse / Speed Control Pedal
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Tranission Aux Roue S Avant / Front Wheel Drive Lever
Levier De Chengement De Vites Se Pdf / Pto Gear Shift Lever
Levier De Demi-Tour Rapide / Bi-Speed Turn Lever
Levier De Distributeu R Auxiliaire / Remote Control Lever
Levier De Controle Hy Draulique / Hydraulic Control Lever
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Pa Rties Composantes] / Hydraulic Pump [Component Part S]
Circuit D'huile Hydra Ulique(Aspirat) / Hydraulic Oil Line(Suction)
Circuit C'huile Hydra Ulique (Retour) / Hydraulic Oil Line(Delivery)
Circuit D'huile Hydra Ulique(Direction) / Hydraulic Oil Line(Steering)
Circuit D'huile Hydra Ulique (T/M) / Hydraulic Oil Line (T/M)
Circuit D'huile Hydra Ulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydra Ulique (Refroidisseur) / Hydraulic Oil Line (Oil Co Oler)
Circuit D'huile Hydra Ulique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Br As De Relevage / Hydraulic Piston/Lift Arm
Levier De Controle De Position / Feed Back Lever
Distributeur Hydrauli Que / Control Valve
Distributer [Parties Composantes] / Control Valve [Component Parts]
Distributeur Auxiliai Re / Remote Control Valve
Controle Des Valves A Ux.[Parties Composantes] / Remote Control Valve [Co Mponent Parts]
Differentiel Avant / Front Differential
Demi Arbre De Pont Avant / Differential Gear Shaft
Carter Engre-Conique / Bevel Gear Case
Pont Avant / Front Axle
Embrayage De Demi-Tour Rapide / Bi-Spee D Turn Clutch
Arbre De Entrainement Avant / Front Dri Ve Shaft
Carter De Distribution De Demi-Tour Rap Ide / Bi-Speed Turn Gear Case
Carter De Demi-Tour Rapide / Bi-Speed T Urn Case
Levier De Vitesses De Demi-Tour Rapide / Bi-Speed Turn Shift Lever
Bielle De Direction / Drag Link
Colonne De Direction / Steering Post
Pompe Hydraulique(D.A.) [Parties Composantes ] / Hydraulic Pump(Ps) [Component Parts]
Tirant Inferie Ur / Lower Link
Relevage 3 Poi Nts 1(Bras Superieur) / 3-Point Linkage 1(Top Link)
Barre D'attela Ge / Drawbar
Attelage / Fro Nt Hitch
Attelage Arrie Re / Rear Hitch
Protection Pdf / Pto Protector
Capot / Bonnet
Capot / Bonnet
Capot Lateral / Side Cover
Retroviseur [Fr] [G] / Rearview Mirror [Fr] [ G]
Retroviseur [Uk] / Rearview Mirror [Uk]
Aile / Fender
Aile Support / Fender Stay
Siege [Fr] [Uk] / Seat [Fr] [Uk]
Siege [G] / Seat [G]
Marchepied / Step
Marchepied / Step
Cadre Anti-Renversement / Rops
Roue Avant (7-12) / Front Wheel (7-12)
Marchepied / Step
Roue Avant (24*8,50-12) / Front Wheel (24 *8.50-12)
Roue Arriere (12,4-16) / Rear Wheel (12. 4-16)
Roue Arriere (13,6-16) / Rear Wheel (13 .6-16)
Etiquette [Francais] / Label [French]
Etiquette [Allemagne] / Label [German]
Etiquette [Anglais] / Label [English]
Accessories Et Piece De Service / Accessories And S Ervice Parts
Eclairage De Travail [Option] / Working Light Kit [Option]
Colonne De Direction Durite [Option] / Power Stee Ring Hose Kit [Option]
Cylindre De Relevage [Option] / Mower Lift Cylind Er Kit [Option]
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Embrayage / Clutch
Hst / Hst
Hst / Hst
Frein / Brake
Capot / Bonnet
Capot / Bonnet
Aile / Fender
Marchepied / Step
Marchepied / Step
Marchepied / Step
