Kubota Tractor B2650HDB-F Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2650HDB-F Tractor
Number of Pages: 441 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Lamp
Licencia Lampara / License Lamp
Instalacion Electrica / Electrical Wiring
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Adelante Eje / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Caso) [Componente Piezas] 1 / Hst (Case) [Component Parts] 1
Hst (Bomba) [Componente Piezas] 2 / Hst (Pump) [Component Parts] 2
Hst (Motor) [Componente Piezas] 3 / Hst (Motor) [Component Parts] 3
Hst (Puerto Bloque Cubierta) [Componente Piezas] 4 / Hst (Port Block Cover) [Component Parts] 4
Hst (Reten De Punto Muerto) [Componente Piezas] 5 / Hst (Neutral Holder) [Component Parts] 5
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Pto Accionar Eje / Pto Drive Shaft
Tdf Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Tdf Engranaje Cambio Brazo / Pto Gear Shift Arm
Hst Desbloquear Brazo / Hst Release Arm
Gama Engranaje Cambio Palanca / Range Shift Lever
Cable De Liberación De Velocidad / Cruise Release Cable
Coloque La Palanca De Mando / Position Control Lever
Palanca De Válvula Del Cargador / Loader Valve Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Direccion Poste / Steering Post
Direccion / Steering
Direccion Cilindro / Steering Cylinder
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Linea De Aceite Hidraulico Radiador De Aceite / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Válvula Del Cargador [Partes Del Componente] / Loader Valve [Component Parts]
Enlace De La Válvula Del Cargador / Loader Valve Link
Tubería Hidráulica Del Cargador / Hydraulic Loader Pipe
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Tdf Valvula / Pto Valve
Tdf Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Hood (Bonnet) Upper
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Asiento (Grammer Msg83/511) / Seat (Grammer Msg83/511)
Asiento (Grammer Msg93/511) / Seat (Grammer Msg93/511)
Asiento (Sears 807) / Seat (Sears 807)
Asiento (Sears 830) / Seat (Sears 830)
Peldano / Step
Ruido Supresion / Sound Absorber
Cola Cubierta / Tail Cover
Herramienta Caja / Tool Box
Arco De Seguridad / Rops
Rueda Delantera (6-12b) / Front Wheel (6-12b)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8.50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Adelante Hidraulico Puerto Kit [Opcion] / Front Hydraulic Outlet Kit [Option]
