7,392
Kubota Tractor B2650DB-M Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota B2650DB-M Tractor
Number of Pages: 459 Pages
Engine 000100 Crankcase
Engine 000200 Oil Pan
Engine 000300 Cylinder Head
Engine 000400 Gear Case
Engine 000500 Head Cover
Engine 000600 Oil Filter
Engine 000700 Dipstick And Guide
Engine 010000 Main Bearing Case
Engine 010100 Camshaft And Idle Gear
Engine 010200 Piston And Crankshaft
Engine 010300 Flywheel
Engine 010500 Fuel Camshaft And Governor Shaft
Engine 020000 Idle Apparatus
Engine 020200 Injection Pump
Engine 020400 Governor
Engine 020500 Speed Control Plate
Engine 020600 Nozzle Holder And Glow
Engine 020700 Nipple Holder Component Parts
Engine 050000 Thermostat Water Flange And Thermostat
Engine 050100 Water Pump
Engine 060000 Valve And Rocker Arm
Engine 060100 Inlet Manifold
Engine 060200 Exhaust Manifold
Engine 060300 Air Cleaner
Engine 060400 Inlet Pipe (Air Cleaner)
Engine 060500 Muffler
Engine 090000 Upper Gasket Kit
Engine 090100 Lower Gasket Kit
Engine A00100 Accelerator Lever
Engine A02000 Accelerator Pedal
Fuel System A10100 Fuel Tank
Fuel System A11000 Fuel Pipe
Fuel System A12000 Fuel Filter
Fuel System A13000 Fuel Filter Component Parts
Fuel System A14000 Fuel Pump
Cooling Water System A40100 Fan
Cooling Water System A41000 Water Pipe
Radiator Note 040,210 New Part And Fig.No.M10500 Ref.No.120,125,130
Cooling Water System A43000 Reserve Tank
Electrical System A50100 Oil Switch And Thermal Sensor Oil
Electrical System A51000 Stop Solenoid
Electrical System A51500 Alternator
Electrical System A52000 Alternator Component Parts
Electrical System A52500 Starter
Electrical System A53000 Starter Component Parts
Electrical System A53500 Battery
Electrical System B10100 Key Switch
Electrical System B10300 Relay
B11500 Dashboard Panel Board Note Order By Ref.No.030 New Part And Fig.No.B12500 Ref.No.035.
Electrical System B12000 Panel Board
Electrical System B12500 Panel Switch
Electrical System B30100 Head Light
Electrical System B30800 Front Combined Headlight Front Combination
Electrical System B30900 Rear Combination Headlight
Electrical System B31300 License Lamp
Electrical System B31600 Trailer Socket Trailer
Electrical System B50100 Electrical Cables Electrical Wiring
Clutch C10100 Clutch
Clutch C11000 Clutch Rod
Clutch C30100 Clutch Pedal
Clutch C40100 Clutch Housing
Front Axle C41500 Center Frame
Front Axle C41700 Sub Frame
Front Axle G10100 Front Axle Frame
Front Axle G10500 Front Axle Case
Front Axle G11500 Front Differential
Front Axle G12100 Side Bevel Gear Lh
Front Axle G12200 Yan Bevel Gear Rh
Front Axle G12300 Inclination Gearbox Bevel Gear Case
Front Axle G12600 Front Axle Case Lh
Front Axle G12700 Front Axle Case Rh
Front Axle G13000 Front Axle Lh
Front Axle G13200 Front Axle Rh
Front Axle G13500 Front Drive Shaft
Transmission C42000 Transmission Case
Transmission C42500 Differential Gear
Transmission C42800 Rear Axle Case Left Side Rear Axle Case Lh
Transmission C42900 Rear Axle Case Right Side Rear Axle Case Rh
Transmission D00100 Clutch Shaft
Transmission D00500 Propeller Shaft
Transmission D09100 First Shaft
Transmission D09200 Second Shaft
Transmission D09300 Third Shaft
Transmission D10700 Main Gear Shaft
Transmission D10800 Range Gear Shaft
Transmission D11100 Reverse Shaft 1
Transmission D11200 Reverse Shaft 2
Transmission D11500 Shuttle Shaft
Transmission D13200 PTO Drive Shaft
Transmission D13400 PTO Gear Shift Shaft
Transmission D13900 Range Gear
Transmission D14000 Rear Differential
Speed Change D20100 Main Gear Shift
Speed Change D20500 Transmission Shuttle Weaving Fork Shuttle Shift
Speed Change D20600 Transmission Shuttle Weaving Rod Shuttle Shift
Speed Change D21700 Gear Range Transmission Fork Range Gear
Speed Change D22000 PTO Gear Shift
Speed Change D22500 Differential Lock Transmission Fork Differential
Speed Change F10100 Main Transmission Main Gear Shift
Speed Change F10300 Transmission Shuttle Weaving Arm Shuttle Shift
Speed Change F11000 Range Gear Shift
Speed Change F11300 Front Wheel Drive
Speed Change F12500 PTO Gear Shift
Speed Change F14000 Position Control Lever Position Control
Speed Change F14200 Remote Control Handle Remote Control
Speed Change F20100 Brake Pedal
Speed Change F20500 Differential Lock Pedal Differential Lock
Speed Change F24000 Bi-Speed Turn Arm
Rod Note Order By Ref.No.010 New Part And Fig.No.F24000 Ref.No.060 New Part And Fig.No.F25000 Ref.No.020 New
Speed Change F25000 Bi-Speed Turn Shaft
Rear Axle D30200 Rear Axle Lh
Rear Axle D30300 Rear Axle Rh
Brake E00200 Brake Lh
Brake E00300 Brake Rh
Brake E00500 Brake Rod
Brake E01500 Parking Brake Lever
Steering H10100 Steering Wheel
Steering H10500 Steering Post
Steering H10800 Slip Pedal Tilt Pedal
Steering H11000 Steering Controller
Steering H12100 Steering Cylinder
Steering H12200 Steering Cylinder Component Parts
Pump Motor System J12000 Hydraulic Pump
M Pump Motor System J12500 Hydraulic Pump Component Parts
Pump Motor System J20100 Hydraulic Oil Line (Suction)
Pump Motor System J21000 Hydraulic Oil Line (Feed) Oil
Pump Motor System J21500 Hydraulic Oil Line (Steering)
Pump Motor System J24500 Hydraulic Oil Line (F M) Oil
Pump Motor System J30100 Hydraulic Cylinder
Pump Engine System J31000 Hydraulic Piston Lifting Arm Hydraulic
Pump Motor System J33000 Feed Back Lever
Pump Motor System J40500 Control Valve
M Pump Motor System J41000 Control Valve Component Parts Control Valve
Pump Motor System J41200 Remote Control Valve Remote Control
Pump Motor System J41300 Remote Control Valve Component Parts
Pump Motor System J42800 Fall Adjustment Shaft
Pump Motor System J43000 Relief Valve
M Top Link Lower Link Hitch K10100 3 Point Link Lifting Rod) 3-
Top Link Lower Link Hitch K11500 Old Baj Lower
M Top Link Lower Link Hitch K12000 3 Point Tie (Upper Tie) 3-Point
Ball Link Lower Link Hitch K12500 Chain Of Control Check
Top Link Lower Link Hitch L10500 Drawbar
Top Link Lower Link Hitch L11500 Front Connection Front
Top Link Lower Link Hitch L11600 Rear Connection Rear
Top Link Lower Link Hitch L12500 PTO Protector
Hood Bonnet M10100 Front Grille
Hood Bonnet M10500 Bonnet (Hood)
Hood Bonnet M11300 Panel Cover
Hood Bonnet M12000 Side Cover
Hood Bonnet M13000 Shutter Plate
Hood Bonnet M20500 Rearview Mirror
Hood Bonnet M20800 Lever Guide Lh
Hood Bonnet M20900 Lever Guide Rh
Hood Bonnet M21000 Fender
Hood Bonnet M21700 Seat Support
Hood Bonnet M22001 Seat (Cobo Sc74 M91) Seat(Cobo Sc74 M91)
Hood Bonnet M22002 Seat (Cobo Sc74 M91) Seat(Sears 807)
Hood Bonnet M22003 Seat (Cobo Sc74 M91) Seat(Sears 830)
Hood Bonnet M22500 Step
Hood Bonnet M24000 Tail Cover
Hood Bonnet M26000 Tool Box
Hood Bonnet M31000 ROPS 1 (Middle) ROPS 1 (Mid)
Hood Bonnet M31100 ROPS 2 (Rear) ROPS 2 (Rear)
Front Wheel R10101 Front Wheel(6-12b) Front Wheel (6-12b)
Front Wheel R10102 Front Wheel(6-12) Front Wheel (6-12)
Front Wheel R10103 Front Wheel(6.00-12) Front Wheel (6.00-12)
Front Wheel R10104 Front Wheel(22 8.50-12) Front Wheel (22 8.50-12)
Front Wheel R10105 Front Wheel(24 8,50-12) Front Wheel (24 8.50-12)
Rear Wheels R11001 Rear Wheels (8-16) Rear Wheel (8-16)
Rear Wheels R11002 Rear Wheels (9.5-16) Rear Wheel (9.5-16)
Rear Wheels R11003 Rear Wheels (9.5-18) Rear Wheel (9.5-18)
Rear Wheels R11004 Rear Wheels (31 13.5-15) Rear Wheel (31 13.5-
Rear Wheels R11005 Rear Wheels (315 75d-15) Rear Wheel (315 75d-
Labels S10200 Label (Front)
Labels S10300 Label (Back) Label (Rear)
Accessories And Service Parts T10500 Accessories And Service Parts
M Option U75000 Front Loader Control Valve Kit (Valve) Optional Front Loader Control
Option U75100 Front Loader Control Valve Kit Component Parts Optional Front Loader Control
M Option U75300 Front Loader Control Valve Kit (Arm) Optional Front Loader Control
M Option U75400 Front Loader Control Valve Kit (Link) Optional Front Loader Control
Option U75500 Front Loader Control Valve Kit (Pipe 1) Optional Front Loader Control
Option U75600 Front Loader Control Valve Kit (Pipe 2) Optional Front Loader Control
Option U82300 Working Light Kit Option
Option U89201 Mower Lift Cylinder Kit (Cylinder) Without Hydraulic Pump Optional Mower Lift
Option U89202 Mower Lift Cylinder Kit (Cylinder) Without Hydraulic Pump Optional Mower Lift Cylinder
Option U89203 Mower Lifting Cylinder Kit (Cylinder) Without Hydraulic Pump Optional Mower Lift
Option U89204 Mower Lifting Cylinder Kit (Cylinder) Without Hydraulic Pump Optional Mower Lift
Option U89500 Front Weight Kit Option
Option U95800 Front Hydraulic Outlet Kit Optional Front Hydraulic Outlet Kit
