Kubota Tractor B2650DB-M Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2650DB-M Tractor
Number of Pages: 515 Pages
Frequently Used It Ems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Piston Et Vilebrequin / Piston And Crankshaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Injecteurs Et Bougies Prechauffage / Nozzle Hold Er And Glow Plug
Injecteurs Et Tuyauteries [Parties Composantes] / Nozzle Holder [Component Parts]
Bride A Eau Et Thermostat / Water Flange And The Rmostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (A Ir Cleaner)
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Essence [Parties Compos Antes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiato R
Reservoir Du Radiat Eur / Reserve Tank
Contact A Huile Thermome Tre / Oil Switch And Thermo Sensor
Alternateur Complet / Al Ternator
Alternateur [Parties Com Posantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur / Starter
Batterie / Battery
Batterie / Battery
Tableau De Bord / Panel Board
Tableau De Bord [Parties Composantes] / Panel Board [Component Parts]
Tableau De Commutateur / Panel Switch
Phare Avant / Head Light
Lampe De Clignotant / Fr Ont Combination Lamp
Feux De Combinaison Arri Ere / Rear Combination Lamp
Lampe Plaque Immatricula Tion / License Lamp
Prise De Remorque / Trai Ler Socket
Cablage Electrique / Ele Ctrical Wiring
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedale D'embrayage / Clutch Pedal
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Support Essieu Avant / Front Axle Fram E
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Front Axle C Ase Lh
Essieu Avavt Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front Dr Ive Shaft
Carter De Transmission / Transmissio N Case
Carter De Differentiel / Differentia L Gear Case
Carter De Pont Arriere G. / Rear Axl E Case Lh
Carter De Pont Arriere D. / Rear Axl E Case Rh
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller Sh Aft
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre Principal De Changement / Main Gear Shaft
Arbre De Marche Arriere 1 / Reverse Shaft 1
Arbre De Marche Arriere 2 / Reverse Shaft 2
Arbre Primaire De Pdf / Pto Drive Sh Aft
Arbre De Pdf Changement / Pto Gear S Hift Shaft
Differentiel Arriere / Rear Differen Tial
Fourchette De Changement De Vitesses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shu Ttle Shift Fork
Tige De Inverseur / Shuttle Shift Rod
Fourchette De Chengement De Vitesse Pdf / Pto Gear Shift Fork
Fourchette De Blocage Differ Entiel / Differential Lock Shift Fork
Tige De Changement De Vitess Es Principal / Main Gear Shift Lever
Levier Inverseur De Marche / Shuttle Shift Lever
Levier De Changement De Gamm E / Range Gear Shift Lever
Levier De Tranission Aux Rou Es Avant / Front Wheel Drive Lever
Levier De Chengement De Vite Sse Pdf / Pto Gear Shift Lever
Levier De Controle Position / Position Control Lever
Levier De Distributeur Auxil Iaire / Remote Control Lever
Pedale De Frien / Brake Peda L
Pedale De Verrouillage Du Di Fferentiel / Differential Lock Pedal
Bras De Demi-Tour Rapide / B I-Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Speed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Speed Turn Shaft
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Brake L Ever
Colonne De Direction / Steering Post
Controleur De Direction / Steering Controll Er
Verin De Direction / Steering Cylinder
Pompe Hydraulique / Hydraulic Pump
Pompe Hydraulique [P Arties Composantes] / Hydraulic Pump [Component Par Ts]
Circuit D'huile Hydr Aulique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit C'huile Hydr Aulique (Retour) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydr Aulique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydr Aulique (F/M) / Hydraulic Oil Line (F/M)
Verin Hydraulique / Hydraulic Cylinder
Piston Hydraulique/B Ras De Relevage / Hydraulic Piston/Lift Arm
Levier De Renvoi / F Eed Back Lever
Distributeur Hydraul Ique / Control Valve
Distributeur [Partie S Composantes] / Control Valve [Component Parts]
Controle Des Valves Auxiliaire / Remote Control Valve
Controle Des Valves Aux. [Parties Composantes] / Remote Control Valve [ Component Parts]
Tombent Ajustement A Rbre / Fall Adjustment Shaft
Soupape De Surete / Relief Valve
Relevage 3 Points (Barre De Relevage) / 3-Poin T Linkage (Lift Rod)
Tirant Inferieur / Lower Link
Relevage 3 Points (Tirant Superieur) / 3-Point Linkage (Top Link)
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere / Rear Hitch
Protection Pdf / Pto Protector
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Siege(Cobo Sc74/M91) / Seat(Cobo Sc74/M91)
Siege(Sears 807) / Seat(Sears 807)
Marchepied / Step
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Cadre Anti-Renversement 1 (Ventrale) / Rops 1 (Mid)
Cadre Anti-Renversement 2 (Arriere) / Rops 2 (Rear)
Roue Avant (6-12b) / Front Wheel (6-12b )
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6.0 0-12)
Roue Avant (24*8,50-12) / Front Wheel ( 24*8.50-12)
Roue Arriere (8-16) / Rear Wheel (8-16 )
Roue Arriere (9,5-16) / Rear Wheel (9. 5-16)
Roue Arriere (9,5-18) / Rear Wheel (9. 5-18)
Roue Arriere (31*13,5-15) / Rear Wheel (31*13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel (315/75d-15)
Accessories Et Piece De Service / Accessories And Service Parts
Chargeur Frontal Controle De La Valve Avant [Par Ties Composantes] [Option] / Front Loader Control V Alve Kit [Component Parts] [Option]
Chargeur Frontal Controle De La Valve Avant (Lev Ier) [Option] / Front Loader Control Valve Kit (Lev Er) [Option]
Chargeur Frontal Controle De La Valve Avant (Bie Llete) [Option] / Front Loader Control Valve Kit (L Ink) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuy Au 1) [Option] / Front Loader Control Valve Kit (Pi Pe 1) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuy Au 2) [Option] / Front Loader Control Valve Kit (Pi Pe 2) [Option]
Eclairage De Travail [Option] / Working Light Ki T [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Aucune Pompe Hy D.] [Option] / Mower Lift Cylinder Kit (Cylinder) [ No Hyd.Pump] [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower Lift Cylinder Kit (Cylinder) [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [O Ption]
Equipement Du Debouche Hydraulique Avant [Option ] / Front Hydraulic Outlet Kit [Option]
Bkidk5074 >> B2650db-M
Ventilateur / Fan
Demarreur / Starter
Batterie / Battery
Commutateur / Switch
Relais / Relay
Embrayage / Clutch
Differentiel Avant / Front Differentia L
Carter Reducteur Droite / Front Axle C Ase Rh
Verib De Direction [Parties Composantes] / Steering Cylinder [Component Parts]
Avertisseur De Recul / Bonnet (Hood)
Aile / Fender
Aile / Fender
Siege(Sears 830) / Seat(Sears 830)
Marchepied / Step
Roue Avant (22*8,50-12) / Front Wheel ( 22*8.50-12)
Chargeur Frontal Controle De La Valve Avant (Val Ve) [Option] / Front Loader Control Valve Kit (Valv E) [Option]
Ventilateur / Fan
Demarreur / Starter
Demarreur / Starter
Batterie / Battery
Batterie / Battery
Embrayage / Clutch
Aile / Fender
Marchepied / Step
Ventilateur / Fan
Demarreur / Starter
Batterie / Battery
Relais / Relay
Embrayage / Clutch
Aile / Fender
Aile / Fender
Marchepied / Step
