Kubota Tractor B2530HDBC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2530HDBC Tractor
Number of Pages: 675 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Faro Delantero [Uk] / Head Light [Uk]
Faro Delantero [Ec] / Head Light [Ec]
Adelante Combinacion Luz / Front Combination Lamp
Lampara De Matricula [Uk] / License Lamp [Uk]
Lampara De Matricula [Ec] / License Lamp [Ec]
Funcionamiento Luz / Working Light
Panel De Control De Aire Acondicionado / Air-Con.Control Panel
Limpiaparabrisas / Wiper
Electrico Cableado (Principal) / Electrical Wiring (Body)
Electrico Cableado (Cabina) [Uk] / Electrical Wiring (Cab) [Uk]
Electrico Cableado (Cabina) [Ec] / Electrical Wiring (Cab) [Ec]
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Bloque De Cilindros) [Componente Piezas]1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Puerto Cubierta Del Bloque) [Componente Piezas]2 / Hst (Port Block Cover) [Component Parts] 2
Hst (Junta) [Componente Piezas]3 / Hst (Gasket) [Component Parts] 3
Hst (Soporte Neutral) [Componente Piezas]4 / Hst (Neutral Holder) [Component Parts] 4
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Hst
Pto Accionar Eje / Pto Drive Shaft
Pto Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Pto Engranaje Cambio Brazo / Pto Gear Shift Arm
Hst Desbloquear Brazo / Hst Release Arm
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Vara De Liberación De Velocidad / Cruise Release Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Coloque La Palanca De Mando / Position Control Lever
Alejado Control Palanca / Remote Control Lever
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea (Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Pto Valvula / Pto Valve
Pto Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Adelante Eje Caja Izquierdo / Axle Case Lh
Adelante Eje Caja Derecho / Axle Case Rh
Adelante Eje Iz / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Direccion Poste / Steering Post
Direccion Cilindro / Steering Cylinder
Bajar Vinculo / Lower Link
Superior Vinculo / Top Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet
Lado Cubierta / Side Cover
Centro Montante / Center Pillar
Cabina / Cab
Panel Inferior / Panel Cover
Peldano / Step
Asiento Inferior Cubierta / Seat Under Cover
Guardabarros Cubierta / Fender Cover
Peldano / Step
Encima Guardabarros / Fender
Cola Cubierta / Tail Cover
Puerta Izqd / Door Lh
Puerta Derecho / Door Rh
Cerradura De Puerta Izqd / Door Lock Lh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Ruido Supresion / Sound Absorber
Amortiguador De Sonido Trasero / Sound Absorber Rear
Placa De Aislacion / Insulation Plate
Interior Cubierta / Interior Cover
Asiento (Cobo Sc74/M91) [Excepto Alemania] / Seat (Cobo Sc74/M91) [Except Germany]
Asiento (Grammer Msg83/8) [Alemania] / Seat (Grammer Msg83/8) [Germany]
Asiento (Kab Seating Xh2/P1) [Excepto Alemania] / Seat (Kab Seating Xh2/P1) [Except Germany]
Asiento (Kab Seating 11/P1) [Excepto Alemania] / Seat (Kab Seating 11/P1) [Except Germany]
Asiento (Sears Mcs3000) [Excepto Alemania] / Seat (Sears Mcs3000) [Except Germany]
Adelante Vidrio Y Trasero Vidrio / Front Glass And Rear Glass
Lado Vidrio / Side Glass
Compuerta Trasero Vidrio / Hatch Back Glass
Bisagras Para Vidrio De Automóvil De Tres Puertas / Hatch Back Glass Hinge
Cable Del Aire Acondicionado / Air Conditioner Cable
Vaciar Manguito(Aire Acondicionador) / Drain Hose(Air Conditioner)
Condensador / Condenser
Aire Acondicionador Tubo / Air Conditioner Pipe
Compresor / Compressor
Aire Acondicionador Conducto / Air-Conditioner Duct
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Delantera (6-12b) [Opcion] / Front Wheel (6-12b) [Option]
Rueda Delantera (6-12) [Opcion] / Front Wheel (6-12) [Option]
Rueda Delantera (22*8,50-12) [Opcion] / Front Wheel (22*8.50-12) [Option]
Rueda Posterior (9,5-18) / Rear Wheel (9.5-18)
Rueda Posterior (315/75d-15) / Rear Wheel (315/75d-15)
Rueda Posterior (8-16) [Opcion] / Rear Wheel (8-16) [Option]
Rueda Posterior (9,5-16) [Opcion] / Rear Wheel (9.5-16) [Option]
Rueda Posterior (31*13,5-15) [Opcion] / Rear Wheel (31*13.5-15) [Option]
Etiqueta (Adelante) [Excepto Italiano] / Label (Front) [Except Italian]
Etiqueta (Adelante) [Italiano] / Label (Front) [Italian]
Etiqueta (Trasero) [Ingles] [Frances] / Label (Rear) [English] [French]
Etiqueta (Trasero) [Aleman] [Espanol] / Label (Rear) [German] [Spanish]
Etiqueta(Trasero) [Italiano] / Label (Rear) [Italian]
Etiqueta(Trasero) / Label (Rear)
Alternador Kit[Opcion] / Alternator Kit [Option]
Alternador[Componente Piezas][Opcion] / Alternator [Component Parts] [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Kit De Cd-Radio [Uk] [Opcion] / Cd-Radio Kit [Uk] [Option]
Intermedia Pto(Por Rck54/Rck60-25b-Eu-F Cortacespedes) [Opcion] / Mid Pto Kit(For Rck54/Rck60-25b-Eu-F Mower) [Option]
Cortacespedes Ascenso Cilindro(Ascenso Brazo)[Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro(Cilindro)[Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Peso Delantera [Opcion] / Front Weight Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Hst
Hst
Pto Protector
Capo / Bonnet
Cabina / Cab
Peldano / Step
Peldano / Step
