Kubota Tractor B2420D-F B2420D-F2 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2420D-F ; B2420D-F2 Tractor
Number of Pages: 417 Pages
Bloque Motor / Crank Case
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Caja De Cambios Ppal / Main Bearing Case
Pistón/Cigüeñal / Piston And Crankshaft
Volante / Flywheel
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Valvulas Y Balancines / Valve And Rocker Arm
Filtro De Aire / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Filtro Combustible / Fuel Filter
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Ventilador / Fan
Manguitoagua / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Conmutador / Switch
Rele / Relay
Rele / Relay
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Faro Delantero / Head Light
Intermitente Lampara / Winker Lamp
Luz Matricula / License Lamp
Instalacion Electrica / Electrical Wiring
Embrague / Clutch
Embrague Varilla / Clutch Rod
Pedal Embrague / Clutch Pedal
Embrague Carcasa Cubierta / Clutch Housing Cover
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Embrague Eje / Clutch Shaft
Adelante Eje / Front Shaft
Pto Eje / Pto Shaft
Gama Engranaje / Range Gear
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Eje De Cuarto Adelante / 4th Shaft
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Control Palanca / Hydraulic Control Lever
Freno Pedal / Brake Pedal
Mangueta Brazo / Knuckle Arm
Vinculo,Arrastre / Drag Link
Atar Varilla / Tie Rod
Direccion Poste / Steering Post
Hidraulico Bomba (Potencia Direccion) / Hydraulic Pump (Ps)
Hidraulico Bomba (Potencia Direccion) [Componente Piezas] / Hydraulic Pump (Ps) [Component Parts]
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Palanca Alimentacion Trasera / Feed Back Lever
Distribuidor / Control Valve
3-Punto Varillaje (Ascenso Varilla) / 3-Point Linkage (Lift Rod)
Bajar Vinculo / Lower Link
3-Punto Varillaje (Parte Superior Vinculo) / 3-Point Linkage (Top Link)
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche / Rear Hitch
Protector Tdf / Pto Protector
Parrilla Frontal / Front Grille
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Centro Montante / Center Pillar
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento (Cobo Sc74/M91) [Except [Kdg]] / Seat (Cobo Sc74/M91) [Except [Kdg]]
Asiento (Sears 607) [Except [Kdg]] / Seat (Sears 607) [Except [Kdg]]
Peldano / Step
Cola Cubierta / Tail Cover
Arco Seguridad / Rops
Rueda Delantera (7-12) / Front Wheel (7-12)
Rueda Delantera (6-12) [Opcion] / Front Wheel (6-12) [Option]
Rueda Delantera (6-12b) [Opcion] / Front Wheel (6-12b) [Option]
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (9,5-16) [Opcion] / Rear Wheel (9.5-16) [Option]
Rueda Trasera (8-16) [Opcion] / Rear Wheel (8-16) [Option]
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Unidad,Intermitente [Opcion] / Flasher Unit Kit [Option]
Carter / Oil Pan
Volante / Flywheel
Ventilador / Fan
Conmutador / Switch
Conmutador / Switch
Rele / Relay
Rele / Relay
Embrague / Clutch
Pto Eje / Pto Shaft
Capo / Bonnet
Peldano / Step
