Kubota Tractor B2410DN Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2410DN Tractor
Number of Pages: 311 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Speed Control Plate
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit[Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit[Opcion] / Lower Gasket Kit [Option]
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz/Cola Lampara / Head Light/Tail Lamp
Embrague / Clutch
Embrague Varilla / Clutch Rod
Trasero Eje Caja / Rear Axle Case
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Adelante Eje / Front Shaft
Pto Eje / Pto Shaft
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
4th Shaft
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Eje Trasero / Rear Axle
Freno / Brake
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Alejado Control Palanca / Remote Control Lever
Hidraulico Control Palanca / Hydraulic Control Lever
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula[Componente Piezas] / Remote Control Valve [Component Parts]
Varillaje 2 Tercer Punto (Tirante) / 3-Point Linkage 2(Lift Rod)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Adelante Accionar Eje / Front Drive Shaft
Mangueta Brazo / Knuckle Arm
Arrastre Vinculo / Drag Link
Atar Varilla / Tie Rod
Direccion Poste / Steering Post
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump(Ps)
Hidraulico Bomba(Potencia Direccion)[Componente Piezas] / Hydraulic Pump(Ps) [Component Parts]
Bajar Vinculo / Lower Link
3-Punto Varillaje 1(Parte Superior Vinculo) / 3-Point Linkage 1(Top Link)
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Palanca Guia / Lever Guide
Guardabarros / Fender
Guardabarros Soporte / Fender Stay
Piso Asiento / Floor Seat
Asiento[Excepto[G]] / Seat [Except [G]]
Asiento[G] / Seat [G]
Peldano / Step
Rueda Delantera(5-12) / Front Wheel (5-12)
Rueda Delantera(6-12b)[Opcion] / Front Wheel (6-12b) [Option]
Rueda Trasera(8-16) / Rear Wheel (8-16)
Etiqueta / Label
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Adelante Pto[Opcion] / Front Pto [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Embrague / Clutch
Pto Eje / Pto Shaft
4th Shaft
Freno / Brake
Pto Protector
Capo / Bonnet
Peldano / Step
Etiqueta / Label
