Kubota Tractor B2410D Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2410D Tractor
Number of Pages: 427 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Speed Control Plate
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Agua Bomba / Water Pump
Filtro De Aire[Fr][G][Uk] / Air Cleaner [Fr] [G] [Uk]
Filtro De Aire / Air Cleaner [Se]
Silenciador / Muffler
Superior Junta Kit[Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit[Opcion] / Lower Gasket Kit [Option]
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador[Fr][G][Uk] / Alternator [Fr] [G] [Uk]
Alternador / Alternator [Se]
Alternador[Componente Piezas][Fr][G][Uk] / Alternator [Component Parts] [Fr] [G] [Uk]
Alternador [Componente Piezas] / Alternator [Component Parts] [Se]
Motor De Arranque / Starter
Conmutador / Switch
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz/Cola Lampara / Head Light/Tail Lamp
Embrague / Clutch
Embrague Varilla / Clutch Rod
Caja De Eje Trasero / Rear Axle Case [Except [Bi-Speed Turn Type]]
Caja De Eje Trasero[Tipo De Giro Bi-Speed] / Rear Axle Case [Bi-Speed Turn Type]
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Adelante Eje / Front Shaft
Pto Eje / Pto Shaft
Tdf Intermedia[Tipo De Tdf Intermedia] / Mid Pto [Mid Pto Type]
Intermedia Tdf / Mid Pto [Except [Mid Pto Type]]
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Eje De Cuarto Adelante / 4th Shaft
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Gama Engranaje Cambio Palanca / Range Gear Shift Lever [Mid Rops Type]
Gama Engranaje Cambio Palanca / Range Gear Shift Lever [Except [Mid Rops Type]]
Palanca De Cambio De Tdf[Tipo Tdf Intermedia] / Pto Gear Shift Lever [Mid Pto Type]
Palanca De Cambio De Tdf / Pto Gear Shift Lever [Except [Mid Pto Type]]
Palanca De Giro Bi-Speed[Tipo De Giro Bi-Speed] / Bi-Speed Turn Lever [Bi-Speed Turn Type]
Freno / Brake
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Alejado Control Palanca / Remote Control Lever [Aux.Control Valve Type]
Hidraulico Control Palanca / Hydraulic Control Lever
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line (F/M)
Cilindro Hidraulico / Hydraulic Cylinder [Aux.Control Valve Type]
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Alejado Control Valvula / Remote Control Valve [Aux.Control Valve Type]
Auxiliar Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts] [Aux.Control Valve Type]
Carcasa Eje Delantero / Front Axle Case [Except [Bi-Speed Turn Type]]
Caja De Eje Delantero[Tipo De Giro Bi-Speed] / Front Axle Case [Bi-Speed Turn Type]
Diferencial Delantero / Front Differential [Except [Bi-Speed Turn Type]]
Diferencial Delantero[Tipo De Giro Bi-Speed] / Front Differential [Bi-Speed Turn Type]
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje Caja / Front Axle Case [Except [Bi-Speed Turn Type]]
Adelante Eje / Front Axle
Embrague De Giro Bi-Speed[Tipo De Giro Bi-Speed] / Bi-Speed Turn Clutch [Bi-Speed Turn Type]
Adelante Accionar Eje / Front Drive Shaft [Except [Bi-Speed Turn Type]]
Eje Propulsor Delantero[Tipo De Giro Bi-Speed] / Front Drive Shaft [Bi-Speed Turn Type]
Caja De Engranajes De Giro Bi-Speed[Tipo De Giro Bi-Speed] / Bi-Speed Turn Gear Case [Bi-Speed Turn Type]
Caja De Giro Bi-Speed[Tipo De Giro Bi-Speed] / Bi-Speed Turn Case [Bi-Speed Turn Type]
Palanca De Cambio De Giro Bi-Speed[Tipo De Giro Bi-Speed] / Bi-Speed Turn Shift Lever [Bi-Speed Turn Type]
Mangueta Brazo / Knuckle Arm
Arrastre Vinculo / Drag Link
Atar Varilla / Tie Rod
Direccion Poste / Steering Post
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump(Ps)
Hidraulico Bomba(Potencia Direccion)[Componente Piezas] / Hydraulic Pump(Ps) [Component Parts]
Varillaje 2 Tercer Punto (Tirante) / 3-Point Linkage 2(Lift Rod)
Bajar Vinculo / Lower Link
3-Punto Varillaje 1(Parte Superior Vinculo) / 3-Point Linkage 1(Top Link)
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Tdf Protector / Pto Protector
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Espejo Retrovisor / Rearview Mirror [Fr] [G] [Se]
Espejo Retrovisor[Uk] / Rearview Mirror [Uk]
Guia De Palanca[Fr][G][Uk] / Lever Guide [Fr] [G] [Uk]
Palanca Guia / Lever Guide [Se]
Guardabarros / Fender
Extension Guardabarros / Extension Fender
Tirante De Guardabarros / Fender Stay [Except [Bi-Speed Turn Type]]
Tirante De Guardabarros / Fender Stay [Bi-Speed Turn Type]
Piso Asiento / Floor Seat
Asiento / Seat [Fr] [G] [Se]
Asiento[G] / Seat [G]
Peldano / Step
Arco / Rops
Rueda Delantera(6-12b) / Front Wheel (6-12b)
Rueda Delantera(6-12) / Front Wheel (6-12)
Rueda Delantera(6,00-12) / Front Wheel (6.00-12)
Rueda Delantera(22*8.50-12) / Front Wheel (22*8.50-12)
Rueda Delantera(24*8.50-12) / Front Wheel (24*8.50-12)
Rueda Trasera(8-16) / Rear Wheel (8-16)
Rueda Trasera(9.5-16) / Rear Wheel (9.5-16)
Rueda Trasera(9.5-18) / Rear Wheel (9.5-18)
Rueda Trasera(31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera(315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta / Label [Fr]
Etiqueta / Label [G]
Etiqueta[Uk] / Label [Uk]
Etiqueta / Label [Se]
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Potencia Direccion Manguito Kit[Opcion] / Power Steering Hose Kit [Option]
Adelante Pto[Opcion] / Front Pto [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit [Option]
