Kubota Tractor B2400D Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2400D Tractor
Number of Pages: 325 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crank Shaft
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Filtro De Aire [Fr][Uk][G] / Air Cleaner [Fr][Uk][G]
Filtro De Aire (Doble) [Excepto[Fr][Uk][G]] / Air Cleaner (Double) [Except[Fr][Uk][G]]
Filtro De Aire (Doble) [[Fr][Uk][G]Opcion] / Air Cleaner (Double) [[Fr][Uk][G]Option]
Silenciador / Muffler
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Luz / Light
Remolque Vaso/Reflector / Trailer Socket/Reflector
Faro De Labor [Opcion] / Working Light [Option]
Embrague / Clutch
Embrague Varilla / Clutch Rod
Bastidor/Enganche Delantero / Frame/Front Hitch
Trasero Eje Caja / Rear Axle Case
Eje De Embrague/Eje Propulsor / Clutch Shaft/Propeller Shaft
Segundo Eje/Tercero Eje/Cuarto Eje / 2nd Shaft/3rd Shaft/4th Shaft
Eje De Quinto/Eje De Tdf / 5th Shaft/Pto Shaft
Tdf Intermedia / Mid Pto
Adelante Pto[Opcion] / Front Pto [Option]
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Bi-Velocidad Girar Palanca / Bi-Speed Turn Lever
Eje Trasero / Rear Axle
Freno / Brake
Freno Pedal / Brake Pedal
Palanca De Control De Posicion / Positon Control Lever
Palanca De Mando De Servicios Externos [Con Distribuidor Auxiliar] / Remote Control Lever [With Aux.Con.Valve]
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Caudal Divisor Valvula[Componente Piezas] / Flow Divider Valve [Component Parts]
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line(Steering)
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Distribuidor De Servicios Externos [Tipo Con Distribuidor Auxiliar] / Remote Control Valve [With Aux.Con.Valve]
Ascenso Varilla / Lift Rod
Cilindro De Elevacion De Segadora [Opcion] / Mower Lift Cylinder [Option]
Adelante Eje / Front Axle
Bi-Velocidad Girar Embrague / Bi-Speed Turn Clutch
Adelante Accionar Eje / Front Drive Shaft
Bi-Velocidad Girar Engranaje Caja / Bi-Speed Turn Gear Case
Bi-Velocidad Girar Caja / Bi-Speed Turn Case
Bi-Velocidad Girar Cambio Palanca / Bi-Speed Turn Shift Lever
Arrastre Vinculo / Drag Link
Atar Varilla / Tie Rod
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Bajar Vinculo / Lower Link
Capo(Capo) / Hood(Bonnet)
Lado Cubierta / Side Cover
Guardabarros / Fender
Extension Guardabarros / Extension Fender
Asiento Excepto [G] / Seat Except [G]
Asiento [G] / Seat [G]
Peldano / Step
Rops
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera(24*8.50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (9.5-18) / Rear Wheel (9.5-18)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Embrague / Clutch
Etiqueta / Label
Kit De Rele De Arranque [Opcion] / Starter Relay Kit [Option]
Front Axle Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Luz / Light
Embrague / Clutch
Freno / Brake
Peldano / Step
Rops
Embrague / Clutch
Etiqueta / Label
