Kubota Tractor B2400-HD Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2400-HD Tractor
Number of Pages: 293 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crank Shaft
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Filtro De Aire (Doble) [Opcion] / Air Cleaner (Double) [Option]
Silenciador / Muffler
Combustible Tubo / Fuel Pipe
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Luz / Light
Remolque Vaso/Reflector / Trailer Socket/Reflector
Faro De Labor [Opcion] / Working Light [Option]
Embrague / Clutch
Embrague Varilla / Clutch Rod
Bastidor/Enganche Delantero / Frame/Front Hitch
Trasero Eje Caja / Rear Axle Case
Eje De Embrague/Eje Propulsor / Clutch Shaft/Propeller Shaft
Hst
Hst[Componente Piezas] / Hst [Component Parts]
Segundo Eje/Tercero Eje/Cuarto Eje / 2nd Shaft/3rd Shaft/4th Shaft
Eje De Quinto/Eje De Tdf / 5th Shaft/Pto Shaft
Tdf Intermedia / Mid Pto
Tdf Delantera [Opcion] / Front Pto [Option]
Eje Trasero / Rear Axle
Freno / Brake
Freno Pedal / Brake Pedal
Velocidad Cambio Palanca / Speed Change Lever
Velocidad Control Pedal / Speed Control Pedal
Velocidad Juego Palanca / Speed Set Lever
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Bi-Velocidad Girar Palanca / Bi-Speed Turn Lever
Coloque La Palanca De Mando / Position Control Lever
Alejado Control Palanca / Remote Control Lever
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line (Suction)
Caudal Divisor Valvula[Componente Piezas] / Flow Divider Valve [Component Parts]
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line (Steering)
Hidraulico Aceite Linea(Transmision) / Hydraulic Oil Line (T/M)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line (Hst)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Alejado Control Valvula / Remote Control Valve
Ascenso Varilla / Lift Rod
Cilindro De Elevacion De Segadora [Opcion] / Mower Lift Cylinder [Option]
Adelante Eje / Front Axle
Bi-Velocidad Girar Embrague / Bi-Speed Turn Clutch
Adelante Accionar Eje / Front Drive Shaft
Bi-Velocidad Girar Engranaje Caja / Bi-Speed Turn Gear Case
Bi-Velocidad Girar Caja / Bi-Speed Turn Case
Bi-Velocidad Girar Cambio Palanca / Bi-Speed Turn Shift Lever
Arrastre Vinculo / Drag Link
Atar Varilla / Tie Rod
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Barra De Tiro/Enganche / Lower Link/Hitch
Capo(Capo) / Hood (Bonnet)
Lado Cubierta / Side Cover
Guardabarros / Fender
Extension Guardabarros / Extension Fender
Cubierta Inferior De Asiento / Seat Cover Under
Asiento Excepto [G] / Seat Except[G]
Asiento [G] / Seat [G]
Peldano / Step
Rops
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera(24*8.50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (9.5-18) / Rear Wheel (9.5-18)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta / Label
Volante / Flywheel
Ventilador / Fan
Luz / Light
Embrague / Clutch
Hst
Freno / Brake
Peldano / Step
Rops
Etiqueta / Label
