Kubota Tractor B2350HDB-C Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2350HDB-C Tractor
Number of Pages: 483 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Lamp
Licencia Lampara / License Lamp
Funcionamiento Luz / Working Light
Relé/Panel De Control De Aire Acondicionado / Air-Con.Control Panel/Relay
Antena/Altavoz / Antenna/Speaker
Leva (Delantera) / Wiper (Front)
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Electrico Cableado (Cabina) / Electrical Wiring (Cab)
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Adelante Eje / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Caja) [Componente Piezas] 1 / Hst (Case) [Component Parts] 1
Hst (Bomba) [Componente Piezas] 2 / Hst (Pumpe) [Component Parts] 2
Hst (Motor) [Componente Piezas] 3 / Hst (Motor) [Component Parts] 3
Hst (Puerto Cubierta Del Bloque) [Componente Piezas] 4 / Hst (Port Block Cover) [Component Parts] 4
Hst (Soporte Neutral) [Componente Piezas] 5 / Hst (Neutral Holder) [Component Parts] 5
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Pto Accionar Eje / Pto Drive Shaft
Tdf Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Tdf Engranaje Cambio Brazo / Pto Gear Shift Arm
Velocidad Control Varilla / Speed Control Rod
Cable De Liberación De Velocidad / Cruise Release Cable
Coloque La Palanca De Mando / Position Control Lever
Palanca De Válvula Del Cargador [Kdg] / Loader Valve Lever [Kdg]
Freno Pedal / Brake Pedal
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla (Adelante) / Brake Rod (Front)
Freno Varilla (Trasero) / Brake Rod (Rear)
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Direccion Poste / Steering Post
Direccion / Steering Contoroller
Direccion Cilindro / Steering Cylinder
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Linea De Aceite Hidraulico Radiador De Aceite / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line (F/M)
Válvula Del Cargador / Loader Valve
Válvula Del Cargador [Partes Del Componente] / Loader Valve [Component Parts]
Enlace De La Válvula Del Cargador / Loader Valve Link
Tubería Hidráulica Del Cargador / Hydraulic Loader Pipe
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Palanca Alimentacion Trasera / Feed Back Lever
Tdf Valvula / Pto Valve
Tdf Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Lado Cubierta / Side Cover
Asiento(Grammer Msg83/511) / Seat(Grammer Msg83/511)
Asiento(Grammer Msg93/511) / Seat(Grammer Msg93/511)
Asiento(Sears 807) / Seat(Sears 807)
Asiento(Sears 830) / Seat(Sears 830)
Cabina Bastidor / Cab Frame
Panel Inferior / Panel Cover
Asiento Inferior Cubierta / Seat Under Cover
Encima Guardabarros / Over Fender
Cola Cubierta / Tail Cover
Puerta Izqd / Door Lh
Puerta Derecho / Door Rh
Cerradura De Puerta Izqd / Door Lock Lh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Ruido Supresion / Sound Absorber
Interior Cubierta / Interior Cover
Adelante Vidrio Y Trasero Vidrio / Front Glass
Compuerta Trasero Vidrio / Hatch Back Glass
Bisagras Para Vidrio De Automóvil De Tres Puertas / Hatch Back Glass Hinge
Manguera De Vaciado(Aire Acondicionado) / Drain Hose (Air Conditioner)
Condensador / Condenser
Aire Acondicionador Tubo / Air Conditioner Pipe
Compresor / Air Compressor
Aire Acondicionador Conducto / Air-Conditioner Duct
Rueda Delantera (6-12b) / Front Wheel (6-12b)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Kit De Sonda [Option] / Tube Kit [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Adelante Hidraulico Puerto Kit [Opcion] / Front Hydraulic Outlet Kit [Option]
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Hst
Pto Protector
