Kubota Tractor B2350HDB-C Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota B2350HDB-C Tractor
Number of Pages: 501 Pages
B2350hdb-C
B2350hdb-C Frequently Used Items Frequently Used Items Frequently Used Items Frequently
B2350hdb-C Motor Engine Kurbelghaeuse Crankcase
B2350hdb-C Motor Engine Oelwanne Oil Pan
B2350hdb-C Motor Engine Zylinderkopf Cylinder Head
B2350hdb-C Motor Engine Getriebe Gehaeuse Gear Case
B2350hdb-C Motor Engine Zylinderkopf-Deckel Head Cover
B2350hdb-C Motor Engine Oelfilter Oil Filter
B2350hdb-C Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
B2350hdb-C Motor Engine Hauptlagergehäuse Main Bearing Case
B2350hdb-C Motor Engine Nockenwelle Und Welle,Freilaufgetr Camshaft And Idle Gear
B2350hdb-C Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
B2350hdb-C Motor Engine Schwungrad Flywheel
B2350hdb-C Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
B2350hdb-C Motor Engine Freilaufapparat Idle Apparatus
B2350hdb-C Motor Engine Einspritzpumpe Injection Pump
B2350hdb-C Motor Engine Zylinderkopf Governor
B2350hdb-C Motor Engine Geschwindigkeitskontrolle Nockenhohn Speed Control
B2350hdb-C Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow
B2350hdb-C Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component
B2350hdb-C Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
B2350hdb-C Motor Engine Wasserpumpe Water Pump
B2350hdb-C Motor Engine Ventil Und Kippenarmwelle Valve And Rocker Arm
B2350hdb-C Motor Engine Ansaugrohr Inlet Manifold
B2350hdb-C Motor Engine Auspuffrummer Exhaust Manifold
B2350hdb-C Motor Engine Luftfilter Air Cleaner
B2350hdb-C Motor Engine Ansaugenrohr (Luftreinheit) Inlet Pipe (Air Cleaner)
B2350hdb-C Motor Engine Auspufftopf Muffler
B2350hdb-C Motor Engine Juego De Juntas Superior Upper Gasket Kit
B2350hdb-C Motor Engine Niederdichtungentasche Lower Gasket Kit
B2350hdb-C Motor Engine Beschleunigerhebel Accelerator Lever
B2350hdb-C Brennstoff System Fuel System Karroceair Fuel Tank
B2350hdb-C Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
B2350hdb-C Brennstoff System Fuel System Kraftstoffsieb Fuel Filter
B2350hdb-C Brennstoff System Fuel System Kraftstoff-Filter [Einzel-Teil] Fuel Filter [
B2350hdb-C Brennstoff System Fuel System Kraftstoffpumpe Fuel Pump
B2350hdb-C Abkuehlung System Cooling Water System Ventilator Fan
System Cooling Water System Wasserrohr Water Pipe ## Note Order By Ref.No.060,070 New Parts.
Radiator ## Note Order By Ref.No.190,200 And Fig.No. Ref.No.180 And Fig.No. Ref.No.120,130 New Parts.
B2350hdb-C Abkuehlung System Cooling Water System Reservebehalter Reserve
B2350hdb-C Elektrisch System Electrical System Oelschalter Thermometer Oil Switch And
B2350hdb-C Elektrisch System Electrical System Stop Solenoid Stop Solenoid
B2350hdb-C Elektrisch System Electrical System Lichtmaschine Alternator
B2350hdb-C Elektrisch System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
B2350hdb-C Elektrisch System Electrical System Anlasser Starter
B2350hdb-C Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter [Component
B2350hdb-C Elektrisch System Electrical System Batterie Battery
B2350hdb-C Elektrisch System Electrical System Schalter Switch
B2350hdb-C Elektrisch System Electrical System Relais Relay
B2350hdb-C Elektrisch System Electrical System Instrumentenbrett Panel Board
B2350hdb-C Elektrisch System Electrical System Wandplatte Schalter Panel
B2350hdb-C Elektrisch System Electrical System Scheinwerfer Head Light
B2350hdb-C Elektrisch System Electrical System Vorderseite Kombination-Licht Front
B2350hdb-C Elektrisch System Electrical System Hinter Kombination-Licht Rear Combination
B2350hdb-C Elektrisch System Electrical System Lampara De La Marticula License
B2350hdb-C Elektrisch System Electrical System Anhaengerkupplung Trailer
B2350hdb-C Elektrisch System Electrical System Arbeitslicht Working Light
B2350hdb-C Elektrisch System Electrical System Innenbeleuchtung Room Light
C Elektrisch System Electrical System Bedientafel Von Luft Veredler Relais Air-Con.
B2350hdb-C Elektrisch System Electrical System Antenne Lautsprecher Antenna
B2350hdb-C Elektrisch System Electrical System Scheibenwischer-Behaelter Washer
B2350hdb-C Elektrisch System Electrical System Wischer (Vorn) Wiper (Front)
B2350hdb-C Elektrisch System Electrical System Elektrische Ausrustung (Koerper) Electrical
B2350hdb-C Elektrisch System Electrical System Elektrische Ausrustung (Kabine) Electrical
B2350hdb-C Kupplung Clutch Kupplung-Gehaeuse Clutch Housing
B2350hdb-C Kupplung Clutch Kupplung-Gehaeuse Deckel Clutch Housing Cover
B2350hdb-C Vorderachse Front Axle Mittlerahmeh Center Frame
B2350hdb-C Vorderachse Front Axle Sekunderahmen Sub Frame
B2350hdb-C Vorderachse Front Axle Vorderrachse-Rahmen Front Axle Frame
B2350hdb-C Vorderachse Front Axle Vorderachse Gehaueuse Front Axle Case
B2350hdb-C Vorderachse Front Axle Vorderachsen-Differential Front Differential
B2350hdb-C Vorderachse Front Axle Antriebskegelrad Links Bevel Gear Lh
B2350hdb-C Vorderachse Front Axle Antriebskegelrad Rechts Bevel Gear Rh
B2350hdb-C Vorderachse Front Axle Winkelzahnradgehaeuse Bevel Gear Case
B2350hdb-C Vorderachse Front Axle Vorderachse-Gehaeuse Links Front Axle Case
B2350hdb-C Vorderachse Front Axle Vorderachse-Gehaeuse Rechs Front Axle Case
B2350hdb-C Vorderachse Front Axle Vorderradachse Rechts Front Axle Lh
B2350hdb-C Vorderachse Front Axle Vorderradachse Rechts Front Axle Rh
B2350hdb-C Vorderachse Front Axle Vorderantriebswelle Front Drive Shaft
B2350hdb-C Transmission Transmission Getriebe Gehaeuse Transmission Case
B2350hdb-C Transmission Transmission Differentialgetriebegehaeuse Differential
B2350hdb-C Transmission Transmission Hinterradachsegehaeuse Ls Rear Axle Case
B2350hdb-C Transmission Transmission Hinterradachsegehaeuse Rs Rear Axle Case
B2350hdb-C Transmission Transmission Kupplung-Welle Clutch Shaft
B2350hdb-C Transmission Transmission Abstuetzung Rechts Vorne Propeller Shaft
B2350hdb-C Transmission Transmission Hst Hst
B2350hdb-C Transmission Transmission Hst (Gehaeuse) [Einzel-Teil] Hst (Case) [Component
B2350hdb-C Transmission Transmission Hst (Pumpe) [Einzel-Teil] Hst (Pumpe) [Component
B2350hdb-C Transmission Transmission Hst (Motor) [Einzel-Teil] Hst (Motor) [Component
C Transmission Transmission Hst (Port Block Deckel) [Einzel-Teil] 4 Hst (Port Block Cover)
C Transmission Transmission Hst (Neutralhalter) [Einzel-Teil] 5 Hst (Neutral Holder) [
B2350hdb-C Transmission Transmission Erstewelle First Shaft
B2350hdb-C Transmission Transmission Zweitewelle Second Shaft
B2350hdb-C Transmission Transmission Drittewelle Third Shaft
B2350hdb-C Transmission Transmission Drehzahlbereichswelle Range Gear Shaft
B2350hdb-C Transmission Transmission Umkeheren-Welle Reverse Shaft
B2350hdb-C Transmission Transmission Zapfantriebswelle Pto Drive Shaft
B2350hdb-C Transmission Transmission Zapfkupplung-Welle Pto Clutch Shaft
B2350hdb-C Transmission Transmission Zapfwellenkupplung Pto Clutch
B2350hdb-C Transmission Transmission Mittlere Zapfwelle Mid Pto
B2350hdb-C Transmission Transmission Drehzahlbereichszahnrad Range Gear
B2350hdb-C Transmission Transmission Hinterdifferential Rear Differential
B2350hdb-C Getriebe System Speed Change Drehzahlbereichsschaltgabel Range Gear
B2350hdb-C Getriebe System Speed Change Zapfwellenarm Pto Gear Shift Arm
B2350hdb-C Getriebe System Speed Change Fourchette Fur Differentialsperre Differential
B2350hdb-C Getriebe System Speed Change Drehzahlaenderpedal Speed Change
B2350hdb-C Getriebe System Speed Change Drehzahlreglerstange Speed Control
B2350hdb-C Getriebe System Speed Change Drehzahlbereichshebel Range Gear Shift
B2350hdb-C Getriebe System Speed Change Palanca Conductor De Rueda Delantera Front
B2350hdb-C Getriebe System Speed Change Tempomat-Schalthebel Cruise Control
B2350hdb-C Getriebe System Speed Change Drehzahlfreigabezug Cruise Release
B2350hdb-C Getriebe System Speed Change Zapfwellenschalthebel Pto Gear Shift
B2350hdb-C Getriebe System Speed Change Positions-Steuerhebel Position Control
B2350hdb-C Getriebe System Speed Change Laderventilhebel [Ke] [Kes] Loader Valve Lever
B2350hdb-C Getriebe System Speed Change Laderventilhebel [Kdg] Loader Valve Lever
B2350hdb-C Getriebe System Speed Change Bremspedal Brake Pedal
B2350hdb-C Getriebe System Speed Change Differentialsperrepedal Differential Lock
Speed Shift Rod ## Note Order By Ref.No.010 And Fig.No. Or Fig.No. Ref.No.060 And Fig.No. Ref.No.
B2350hdb-C Getriebe System Speed Change Bi-Speed-Welle Bi-Speed Turn Shaft
B2350hdb-C Hinterradachse Rear Axle Hinterradachse Links Rear Axle Lh
B2350hdb-C Hinterradachse Rear Axle Hinterradachse Rechts Rear Axle Rh
B2350hdb-C Bremse Brake Bremse Links Brake Lh
B2350hdb-C Bremse Brake Bremse Rechts Brake Rh
B2350hdb-C Bremse Brake Bremsstange (Vorder) Brake Rod (Front)
B2350hdb-C Bremse Brake Bremsstange (Hintern) Brake Rod (Rear)
B2350hdb-C Bremse Brake Handbremsehebel Parking Brake Lever
B2350hdb-C Kontrollhebel Operation Bi-Speed-Arm Bi-Speed Turn Arm
B2350hdb-C Lenkung Steering Lenkungshandgriff Steering Handle
B2350hdb-C Lenkung Steering Kardangelenk Steering Post
B2350hdb-C Lenkung Steering Lenkradverstellpedal Tilt Pedal
B2350hdb-C Lenkung Steering Hilfskraftlenkung Steering Contoroller
B2350hdb-C Lenkung Steering Verbindungssatange Steering Cylinder
B2350hdb-C Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [Component
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic
C Pumpe Motor System Pump Motor System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Ausaug) Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Liferung) Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Lenkung) Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Hst) Hydraulic
C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (Oelkuehler) Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulik-Kreislauf (F M) Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Laderventil Loader Valve
B2350hdb-C Pumpe Motor System Pump Motor System Laderventil [Einzel-Teil] Loader Valve [
Laderventilverbindung Loader Valve Link ## Note Order By Ref.No.010 And Fig.No. Ref.No.050
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulikladerrohr Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulikzylinder Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Hydraulikkolben Hubarm Hydraulic
B2350hdb-C Pumpe Motor System Pump Motor System Wirken Sie Hebel Rueck Feed Back
B2350hdb-C Pumpe Motor System Pump Motor System Kontrollventil Control Valve
C Pumpe Motor System Pump Motor System Regelungsventil [Einzel-Teil] Control Valve
B2350hdb-C Pumpe Motor System Pump Motor System Herbst Einstellwelle Fall Adjustment
B2350hdb-C Pumpe Motor System Pump Motor System Zapfventil Pto Valve
B2350hdb-C Pumpe Motor System Pump Motor System Zapfventil [Einzel-Teil] Pto Valve [
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hubstange
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Unterlenker
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Fuehrungskette
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Anhangerku
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hangung
B2350hdb-C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Hinteranhangung
C Oberlenker Unterlenker Vorderanhangung Top Link Lower Link Hitch Schutzabdeckung
B2350hdb-C Motorhaube Hood Bonnet Vorder-Gitter Front Grille
B2350hdb-C Motorhaube Hood Bonnet Motorhaube Hood (Bonnet) Upper
B2350hdb-C Motorhaube Hood Bonnet Seitedeckel Side Cover
B2350hdb-C Motorhaube Hood Bonnet Abdecking Shutter Plate
B2350hdb-C Motorhaube Hood Bonnet Sitz(Grammer Msg83 511) Seat(Grammer Msg83
B2350hdb-C Motorhaube Hood Bonnet Sitz(Grammer Msg93 511) Seat(Grammer Msg93
B2350hdb-C Motorhaube Hood Bonnet Sitz(Sears 807) Seat(Sears 807)
B2350hdb-C Motorhaube Hood Bonnet Sitz(Sears 830) Seat(Sears 830)
B2350hdb-C Kabine Cab Kabinengeruest Cab Frame
B2350hdb-C Kabine Cab Tafeldecken Panel Cover
B2350hdb-C Kabine Cab Untere Bedeckung Seat Under Cover
B2350hdb-C Kabine Cab Ueber Kotfluegel Over Fender
B2350hdb-C Kabine Cab Hintere-Deckel Tail Cover
B2350hdb-C Kabine Cab Tuer Links Door Lh
B2350hdb-C Kabine Cab Tuer Rechts Door Rh
B2350hdb-C Kabine Cab Tuerverriegeln Links Door Lock Lh
B2350hdb-C Kabine Cab Tuerverriegeln Rechts Door Lock Rh
B2350hdb-C Kabine Cab Innere Duch Inner Roof
B2350hdb-C Kabine Cab Aubenseite Duch Outer Roof
B2350hdb-C Kabine Cab Kabinehalter Vorder Cab Bracket Front
B2350hdb-C Kabine Cab Kabinehalter Hinter Cab Bracket Rear
B2350hdb-C Kabine Cab Bodenmatte Floor Mat
B2350hdb-C Kabine Cab Anti-Larm Modifikation Sound Absorber
B2350hdb-C Kabine Cab Innere Deckel Interior Cover
B2350hdb-C Kabine Cab Hebelfuehrung Ls Lever Guide Lh
B2350hdb-C Kabine Cab Hebelfuehrung Rs Lever Guide Rh
B2350hdb-C Kabine Cab Vorderteil Front Glass
B2350hdb-C Kabine Cab Glas Hinter Hatch Back Glass
B2350hdb-C Kabine Cab Glasscharnier Heckklappe Hatch Back Glass Hinge
B2350hdb-C Kabine Cab Rueckspiegel Rearview Mirror
B2350hdb-C Klimaanlage Air Conditioner Klimaanlage Air Conditioner
B2350hdb-C Klimaanlage Air Conditioner Draenrohr (Klimaanlage) Drain Hose (Air
B2350hdb-C Klimaanlage Air Conditioner Kondensator Condenser
B2350hdb-C Klimaanlage Air Conditioner Klimaanlage Schlauch Air Conditioner
B2350hdb-C Klimaanlage Air Conditioner Heizung Schlauch Heater Hose
B2350hdb-C Klimaanlage Air Conditioner Kompressor Air Compressor
B2350hdb-C Klimaanlage Air Conditioner Klimaanlagen-Leitung Air-Conditioner
B2350hdb-C Vorderrad Front Wheel Vorderrad (6-12b) Front Wheel (6-12b)
B2350hdb-C Vorderrad Front Wheel Vorderrad (6-12) Front Wheel (6-12)
B2350hdb-C Vorderrad Front Wheel Vorderrad (6,00-12) Front Wheel (6.00-12)
B2350hdb-C Vorderrad Front Wheel Vorderrad (22 8,50-12) Front Wheel (22 8.50-12)
B2350hdb-C Vorderrad Front Wheel Vorderrad (24 8,50-12) Front Wheel (24 8.50-12)
B2350hdb-C Hinterrad Rear Wheel Hinterrad (8-16) Rear Wheel (8-16)
B2350hdb-C Hinterrad Rear Wheel Hinterrad (9,5-16) Rear Wheel (9.5-16)
B2350hdb-C Hinterrad Rear Wheel Hinterrad (9,5-18) Rear Wheel (9.5-18)
B2350hdb-C Hinterrad Rear Wheel Hinterrad (313,5-15) Rear Wheel (313.5-15)
B2350hdb-C Hinterrad Rear Wheel Hinterrad (315 75d-15) Rear Wheel (315 75d-15)
B2350hdb-C Aufkleber Labels Aufkleber (Vorder) Label (Front)
B2350hdb-C Aufkleber Labels Aufkleber (Hintern) Label (Rear)
Zubehoer Und Service Teile Accessories And Service Parts Sontiges Zubehor Und Service-
B2350hdb-C Option Option Scheibenwischer [Option] Rear Wiper Kit [Option]
B2350hdb-C Option Option Rohr-Kit [Option] Tube Kit [Option] ## S.Nr. =80451 S.No.; =80451 S.No. =
B2350hdb-C Option Option Kraftheberzylinder (Hubarm) [Option] Mower Lift Cylinder Kit (Lift
B2350hdb-C Option Option Kraftheberzylinder (Zylinder) [Option] Mower Lift Cylinder Kit (
B2350hdb-C Option Option Vordergewicht [Option] Front Weight Kit [Option]
Vorderer Hydraulikanschluss [Option] Front Hydraulic Outlet Kit [Option] ## Hinweis Bestellung Nach Ref.
B2350hdb-C
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
