Kubota Tractor B2261HDB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2261HDB Tractor
Number of Pages: 391 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Duide
Volante / Flywheel
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Entrada Tubo (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Varilla Acelerador / Accelerator Rod
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Faro Delantero [Excepto Uk] / Head Light [Except Uk]
Faro Delantero [Uk] / Head Light [Uk]
Luz Matricula / License Lamp
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Eje Delantero / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Embrague Eje / Clutch Shaft
Hst
Hst (Caso) [Componente Piezas] / Hst (Case) [Component Parts]
Hst (Bomba) [Componente Piezas] / Hst (Pump) [Component Parts]
Hst (Motor) [Componente Piezas] / Hst (Motor) [Component Parts]
Hst (Puerto Bloque Cubierta) [Componente Piezas] / Hst (Port Block Cover) [Component Parts]
Hst (Reten De Punto Muerto) [Componente Piezas] / Hst (Neutral Holder) [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Tdf Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Bevel Gear Shaft
Tdf Engranaje Cambio Brazo / Pto Gear Shift Arm
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Hst Desbloquear Brazo / Hst Release Arm
Cable De Liberación De Velocidad / Cruise Release Cable
Posicion Control Palanca / Position Control Lever
Palanca De Válvula Del Cargador / Loader Valve Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Direccion Poste / Steering Column
Hidraulico Aceite Linea (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Válvula Del Cargador [Componente Piezas] / Loader Valve [Component Parts]
Enlace De La Válvula Del Cargador / Loader Valve Link
Tubería Hidráulica Del Cargador / Hydraulic Loader Pipe
Hidraulico Cilindro / Hydraulic Cylinder
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Tdf Valvula / Pto Valve
Tdf Valvula [Componente Piezas] / Pto Valve [Component Parts]
3-Punto Varillaje (Ascenso Varilla) / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche / Rear Hitch
Tdf Protector / Pto Protector
Capo / Hood (Bonnet) Upper
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento(Cobo Sc74/M91) / Seat(Cobo Sc74/M91)
Asiento(Grammer Msg83/511) / Seat(Grammer Msg83/511)
Asiento(Grammer Msg93/511) / Seat(Grammer Msg93/511)
Asiento(Sears 807) / Seat(Sears 807)
Asiento(Sears 830) / Seat(Sears 830)
Peldano / Step
Ruido Supresion / Sound Absorber
Cola Cubierta / Tail Cover
Herramienta Caja / Tool Box
Trasero Cubierta / Rear Cover
Arco De Seguridad / Rops
Rueda Delantera (5-12) / Front Wheel (5-12)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Adelante Hidraulico Puerto Kit [Opcion] / Front Hydraulic Outlet Kit [Option]
Volante / Flywheel
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Hst
Peldano / Step
