Kubota Tractor B2261DB Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2261DB Tractor
Number of Pages: 264 Pages
Articles Fré Quemment Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Jauge D'huile Et Guide / Dipstick And Duide
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant / Flywheel
Volant / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Plate
Porte-Buse Et Bougie De Préchauffage / Nozzle Hold Er And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Bride D'eau Et Thermostat / Water Flange And Therm Ostat
Pompe À Eau / Water Pump
Vanne Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Jeu De Joints Supérieur / Upper Gasket Kit
Jeu De Joints Inférieur / Lower Gasket Kit
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Compos Antes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Reservoir Du Padiateu R / Reserve Tank
Contact A Huile Thermometr E / Oil Switch And Thermo Sensor
Solenoide D'arret / Stop S Olenoid
Alternateur [Type Cadre An Ti-Renv. D'arriere] / Alternator [Rear Rops Type]
Alternateur [Type Cadre An Ti-Renv. D'ventrale] / Alternator [Mid Rops Type]
Alternateur [Paries Compos Antes] [Type Cadre Anti-Renv. D'arriere] / Alternat Or [Component Parts] [Rear Rops Type]
Alternateur [Paries Compos Antes] [Type Cadre Anti-Renv. D'ventrale] / Alterna Tor [Component Parts] [Mid Rops Type]
Demarreur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie / Battery
Commutateur [Type Cadre An Ti-Renv. D'arriere] / Switch [Rear Rops Type]
Commutateur [Type Cadre An Ti-Renv. D'ventrale] / Switch [Mid Rops Type]
Relais / Relay
Panneau De Bord / Panel Bo Ard
Tableau De Bord [Parties C Omposantes] / Panel Board [Component Parts]
Tableau De Commutateur / P Anel Switch
Phare Avant [Excepte Uk] / Head Light [Except Uk]
Phare Avant [Uk] / Head Li Ght [Uk]
Feux De Combinaison Avant [Type Cadre Anti-Renv. D'arriere] / Front Combinati On Lamp [Rear Rops Type]
Feux De Combinaison Avant [Type Cadre Anti-Renv. D'ventrale] / Front Combinat Ion Lamp [Mid Rops Type]
Feux De Combinaison Arrier E / Rear Combination Lamp
Lampe Plaque Immatriculati On [Type Cadre Anti-Renv. D'arriere] / License Lamp [Rear Rops Type]
Lampe Plaque Immatriculati On [Type Cadre Anti-Renv. D'ventrale] / License Lam P [Mid Rops Type]
Faisceau Electrique (Corps ) [Type Cadre Anti-Renv. D'arriere] / Electrical Wi Ring (Body) [Rear Rops Type]
Faisceau Electrique (Corps ) [Type Cadre Anti-Renv. D'ventrale] / Electrical W Iring (Body) [Mid Rops Type]
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Chassis Centre / Center Frame
Differentiel Avant / Front Differential
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Reducteur Gauche / Axle Case Lh
Carter Reducteur Droite / Axle Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre D'entrainement De Roue Avant / Fro Nt Wheel Drive Shaft
Carter De Transmission [Type Cadre Ant I-Renv. D'arriere] / Transmission Case [Rear Rops T Ype]
Carter De Transmission [Type Cadre Ant I-Renv. D'ventrale] / Transmission Case [Mid Rops T Ype]
Carter De Differentiel / Differential Gear Case
Carter De Pont Arriere G. [Type Cadre Anti-Renv. D'arriere] / Rear Axle Case Lh [Rear Rop S Type]
Carter De Pont Arriere G. [Type Cadre Anti-Renv. D'ventrale] / Rear Axle Case Lh [Mid Rop S Type]
Carter De Pont Arriere D. [Type Cadre Anti-Renv. D'arriere] / Rear Axle Case Rh [Rear Rop S Type]
Carter De Pont Arriere D. [Type Cadre Anti-Renv. D'ventrale] / Rear Axle Case Rh [Mid Rop S Type]
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller Shaf T
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre Principal De Changement / Main G Ear Shaft
Arbre De Changement De Gamme [Type Cad Re Anti-Renv. D'arriere] / Range Gear Shaft [Rear R Ops Type]
Arbre De Marche Arriere 1 / Reverse Sh Aft 1
Arbre De Marche Arriere 2 [Type Cadre Anti-Renv. D'arriere] / Reverse Shaft 2 [Rear Rops Type]
Arbre De Marche Arriere 2 [Type Cadre Anti-Renv. D'ventrale] / Reverse Shaft 2 [Mid Rops Type]
Arbre Primaire De Pdf [Type Cadre Anti -Renv. D'arriere] / Pto Drive Shaft [Rear Rops Type ]
Arbre Primaire De Pdf [Type Cadre Anti -Renv. D'ventrale] / Pto Drive Shaft [Mid Rops Type ]
Arbre De Pdf Changement [Type Cadre An Ti-Renv. D'arriere] / Pto Gear Shift Shaft [Rear Ro Ps Type]
Arbre De Pdf Changement [Type Cadre An Ti-Renv. D'ventrale] / Pto Gear Shift Shaft [Mid Ro Ps Type]
Pdf Ventrale [Type Cadre Anti-Renv. D' Arriere] / Mid Pto [Rear Rops Type]
Changement De Gamme / Bevel Gear Shaft
Differentiel Arriere / Rear Differenti Al
Fourchette De Changement De Vi Tesses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shutt Le Shift Fork
Tige De Inverseur / Shuttle Sh Ift Rod
Fourchette De Changement De Ga Mme / Range Gear Shift Fork
Bras De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'arriere] / Pto Gear Sh Ift Arm [Rear Rops Type]
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
F Rein Gauche / Brake Lh
F Rein Droite / Brake Rh
T Ige De Frein / Brake Rod
L Evier De Frein De Stationnement / Parking Brake Lev Er
Tige De Changement De Vitesses Prin Cipal / Main Gear Shift Rod
Levier De Changement De Gamme / Ran Ge Gear Shift Lever
Levier De Tranission Aux Roues Avan T / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'arriere] / Pto Gear Shift Lever [Rear Rops Type]
Levier De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'ventrale] / Pto Gear Shif T Lever [Mid Rops Type]
Levier Du Controle De Position / Po Sition Control Lever
Levier De Distributeur Auxiliaire / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Different Iel / Differential Lock Pedal
Bras De Demi-Tour Rapide / Bi-Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Sp Eed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Sp Eed Turn Shaft
Colonne De Direction / Steering Column
Verin De Direction / Steering Cylinder
Pompe Hydraulique / Hy Draulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrau Lique (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hydrau Lique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrau Lique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bra S De Relevage / Hydraulic Piston/Lift Arm
Levier De Revenue / Fe Ed Back Lever
Distributeur Controle / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Valve Auxiliaire / Aux Iliary Control Valve
Controle Des Valves Au X.[Parties Composantes] / Remote Control Valve [Com Ponent Parts]
Tombent Ajustement Arb Re / Fall Adjustment Shaft
Soupape De Surete / Re Lief Valve
Barre De Relevage / Lift Rod
Bras Inferieur [Type Cadre Anti-Renv. D'arriere] / Link,Lower [Rear Rops Type]
Bras Inferieur [Type Cadre Anti-Renv. D'ventrale ] / Lower Link [Mid Rops Type]
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere [Type Cadre Anti-Renv. D'arrier E] / Rear Hitch [Rear Rops Type]
Attelage Arriere [Type Cadre Anti-Renv. D'ventra Le] / Rear Hitch [Mid Rops Type]
Calandre Avant / Front Grille
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. [Type Cadre Anti-Renv. D'ar Riere] / Lever Guide Lh [Rear Rops Type]
Guide De Levier G. [Type Cadre Anti-Renv. D've Ntrale] / Lever Guide Lh [Mid Rops Type]
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Aile / Fender
Siege (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Siege (Grammer Msg83/511) / Seat (Grammer Msg8 3/511)
Siege (Grammer Msg93/511) / Seat (Grammer Msg9 3/511)
Siege (Sears 807) / Seat (Sears 807)
Siege (Sears 830) / Seat (Sears 830)
Marchepied / Step
Marchepied / Step
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Couvercle Arriere [Type Cadre Anti-Renv. D'arr Iere] / Rear Cover [Rear Rops Type]
Couvercle Arriere [Type Cadre Anti-Renv. D'ven Trale] / Rear Cover [Mid Rops Type]
Cadre Anti-Renversement 1 (Ventrale) / Rops 1 (Mid)
Cadre Anti-Renversement 2 (Arriere) [Type Cadr E Anti-Renv. D'arriere] / Rops 2 (Rear) [Rear Rops Type]
Cadre Anti-Renversement 2 (Arriere) [Type Cadr E Anti-Renv. D'ventrale] / Rops 2 (Rear) [Mid Rops Type]
Roue Avant (5-12) / Front Wheel (5-12)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6.00- 12)
Roue Avant (22*8,50-12) / Front Wheel (22 *8.50-12)
Roue Avant (24*8,50-12) / Front Wheel (24 *8.50-12)
Roue Arriere (9,5-16) / Rear Wheel (9.5- 16)
Roue Arriere (9,5-18) / Rear Wheel (9.5- 18)
Roue Arriere (31*13,5-15) / Rear Wheel ( 31*13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel ( 315/75d-15)
Etiquette (Avant) [Type Cadre Anti-Renv. D'arr Iere] / Label (Front) [Rear Rops Type]
Etiquette (Avant) [Type Cadre Anti-Renv. D'ven Trale] / Label (Front) [Mid Rops Type]
Etiquette (Arriere) [Type Cadre Anti-Renv. D'a Rriere] / Label (Rear) [Rear Rops Type]
Etiquette (Arriere) [Type Cadre Anti-Renv. D'v Entrale] / Label (Rear) [Mid Rops Type]
Chargeur Frontal Controle De La Valve Avant (Valve ) [Option] / Front Loader Control Valve Kit (Valve) [Option]
Chargeur Frontal Controle De La Valve Avant [Parti Es Composantes] [Option] / Front Loader Control Val Ve Kit [Component Parts] [Option]
Chargeur Frontal Controle De La Valve Avant (Levie R) [Option] / Front Loader Control Valve Kit (Lever ) [Option]
Chargeur Frontal Controle De La Valve Avant (Biell Ete) [Option] / Front Loader Control Valve Kit (Lin K) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuyau 1) [Option] / Front Loader Control Valve Kit (Pipe 1) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuyau 2) [Option] / Front Loader Control Valve Kit (Pipe 2) [Option]
Eclairage De Travail [Type Cadre Anti-Renv. D'arri Ere] [Option] / Working Light Kit [Rear Rops Type] [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower L Ift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Opt Ion]
Equipement Du Debouche Hydraulique Avant [Option] / Front Hydraulic Outlet Kit [Option]
