Kubota Tractor B2261DB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2261DB Tractor
Number of Pages: 435 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Duide
Volante / Flywheel
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Entrada Tubo (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador [Tipo Trasero Rops] / Alternator [Rear Rops Type]
Alternador [Tipo Intermedia Rops] / Alternator [Mid Rops Type]
Alternador [Componente Piezas] [Tipo Trasero Rops] / Alternator [Component Parts] [Rear Rops Type]
Alternador [Componente Piezas] [Tipo Intermedia Rops] / Alternator [Component Parts] [Mid Rops Type]
Motor De Arranque / Starter
Conmutador [Tipo Trasero Rops] / Switch [Rear Rops Type]
Conmutador [Tipo Intermedia Rops] / Switch [Mid Rops Type]
Rele / Relay
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Faro Delantero [Excepto Uk] / Head Light [Except Uk]
Faro Delantero [Uk] / Head Light [Uk]
Lampeggiante Lampada [Tipo Trasero Rops] / Front Combination Lamp [Rear Rops Type]
Lampeggiante Lampada [Tipo Intermedia Rops] / Front Combination Lamp [Mid Rops Type]
Luz Matricula [Tipo Trasero Rops] / License Lamp [Rear Rops Type]
Luz Matricula [Tipo Intermedia Rops] / License Lamp [Mid Rops Type]
Instalacion Electrica (Cuerpo) [Tipo Trasero Rops] / Electrical Wiring (Body) [Rear Rops Type]
Instalacion Electrica (Cuerpo) [Tipo Intermedia Rops] / Electrical Wiring (Body) [Mid Rops Type]
Embrague / Clutch
Embrague Varilla / Clutch Rod
Secundario Bastidor / Sub Frame
Adelante Eje Caja Izquierdo / Axle Case Lh
Adelante Eje Caja Derecho / Axle Case Rh
Eje Delantero Izquierdo / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Cajatransmision [Tipo Trasero Rops] / Transmission Case [Rear Rops Type]
Cajatransmision [Tipo Intermedia Rops] / Transmission Case [Mid Rops Type]
Trasero Eje Caja Izquierdo [Tipo Trasero Rops] / Rear Axle Case Lh [Rear Rops Type]
Trasero Eje Caja Izquierdo [Tipo Intermedia Rops] / Rear Axle Case Lh [Mid Rops Type]
Trasero Eje Caja Derecho [Tipo Trasero Rops] / Rear Axle Case Rh [Rear Rops Type]
Trasero Eje Caja Derecho [Tipo Intermedia Rops] / Rear Axle Case Rh [Mid Rops Type]
Embrague Eje / Clutch Shaft
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Principal Engranaje Eje / Main Gear Shaft
Gama Engranaje Eje [Tipo Trasero Rops] / Range Gear Shaft [Rear Rops Type]
Gama Engranaje Eje [Tipo Intermedia Rops] / Range Gear Shaft [Mid Rops Type]
Retroceso Eje 1 / Reverse Shaft 1
Retroceso Eje 2 [Tipo Trasero Rops] / Reverse Shaft 2 [Rear Rops Type]
Retroceso Eje 2 [Tipo Intermedia Rops] / Reverse Shaft 2 [Mid Rops Type]
Tdf Accionar Eje [Tipo Trasero Rops] / Pto Drive Shaft [Rear Rops Type]
Tdf Accionar Eje [Tipo Intermedia Rops] / Pto Drive Shaft [Mid Rops Type]
Tdf Engranaje Cambio Eje [Tipo Trasero Rops] / Pto Gear Shift Shaft [Rear Rops Type]
Tdf Engranaje Cambio Eje [Tipo Intermedia Rops] / Pto Gear Shift Shaft [Mid Rops Type]
Tdf Intermedia [Tipo Trasero Rops] / Mid Pto [Rear Rops Type]
Gama Engranaje / Bevel Gear Shaft
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Inversor Cambio Varilla / Shuttle Shift Rod
Tdf Engranaje Cambio Brazo / Pto Gear Shift Fork
Tdf Engranaje Cambio Brazo [Tipo Trasero Rops] / Pto Gear Shift Arm [Rear Rops Type]
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Palanca De Cambio De Tdf [Tipo Trasero Rops] / Pto Gear Shift Lever [Rear Rops Type]
Palanca De Cambio De Tdf [Tipo Intermedia Rops] / Pto Gear Shift Lever [Mid Rops Type]
Posicion Control Palanca / Position Control Lever
Palanca De Distribuidor De Servicios Externos / Remote Control Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Direccion Poste / Steering Column
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Cilindro / Hydraulic Cylinder
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Distribuidor De Servicios Externos / Auxiliary Control Valve
Auxiliar Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Ascenso Varilla / Lift Rod
Bajar Vinculo [Tipo Trasero Rops] / Link,Lower [Rear Rops Type]
Bajar Vinculo [Tipo Intermedia Rops] / Lower Link [Mid Rops Type]
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche [Tipo Trasero Rops] / Rear Hitch [Rear Rops Type]
Trasero Enganche [Tipo Intermedia Rops] / Rear Hitch [Mid Rops Type]
Tdf Protector / Pto Protector
Capo / Hood (Bonnet) Upper
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Palanca Guia Izquierdo [Tipo Trasero Rops] / Lever Guide Lh [Rear Rops Type]
Palanca Guia Izquierdo [Tipo Intermedia Rops] / Lever Guide Lh [Mid Rops Type]
Guardabarros / Fender
Hoja (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Hoja (Grammer Msg83/511) / Seat (Grammer Msg83/511)
Hoja (Grammer Msg93/511) / Seat (Grammer Msg93/511)
Hoja (Sears 807) / Seat (Sears 807)
Hoja (Sears 830) / Seat (Sears 830)
Peldano / Step
Cola Cubierta / Tail Cover
Herramienta Caja / Tool Box
Trasero Cubierta [Tipo Trasero Rops] / Rear Cover [Rear Rops Type]
Trasero Cubierta [Tipo Intermedia Rops] / Rear Cover [Mid Rops Type]
Rops 1 (Intermedia) / Rops 1 (Mid)
Rops 2 (Trasero) [Tipo Trasero Rops] / Rops 2 (Rear) [Rear Rops Type]
Rops 2 (Trasero) [Tipo Intermedia Rops] / Rops 2 (Rear) [Mid Rops Type]
Rueda Delantera (5-12) / Front Wheel (5-12)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta (Adelante) [Tipo Trasero Rops] / Label (Front) [Rear Rops Type]
Etiqueta (Adelante) [Tipo Intermedia Rops] / Label (Front) [Mid Rops Type]
Etiqueta (Trasero) [Tipo Trasero Rops] / Label (Rear) [Rear Rops Type]
Etiqueta (Trasero) [Tipo Intermedia Rops] / Label (Rear) [Mid Rops Type]
Adelante Cargadora Cntorol Valvula Kit (Valvula) [Opcion] / Front Loader Control Valve Kit (Valve) [Option]
Adelante Cargadora Cntorol Valvula Kit [Componente Piezas] [Opcion] / Front Loader Control Valve Kit [Component Parts] [Option]
Adelante Cargadora Cntorol Valvula Kit (Palanca) [Opcion] / Front Loader Control Valve Kit (Lever) [Option]
Adelante Cargadora Cntorol Valvula Kit (Vinculo) [Opcion] / Front Loader Control Valve Kit (Link) [Option]
Adelante Cargadora Cntorol Valvula Kit (Tubo 1) [Opcion] / Front Loader Control Valve Kit (Pipe 1) [Option]
Adelante Cargadora Cntorol Valvula Kit (Tubo 2) [Opcion] / Front Loader Control Valve Kit (Pipe 2) [Option]
Kit De Faro De Labor [Tipo Trasero Rops] [Opcion] / Working Light Kit [Rear Rops Type] [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Adelante Hidraulico Puerto Kit [Opcion] / Front Hydraulic Outlet Kit [Option]
