Kubota Tractor B2231HDBC-S5 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2231HDBC-S5 Tractor
Number of Pages: 590 Pages
Article S Fréquemment Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camsha Ft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Crankshaf T
Volant / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateu R / Fuel Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Pl Ate
Porte-Buse Et Bougie De Préchauffage / Nozzle Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzl E Holder [Component Parts]
Bride D'eau Et Thermostat / Water Flange And Thermostat
Vanne Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant / Fuel Fil Ter
Filtre A Carburant [Parties C Omposantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel P Ump
Ventilateur / Fa N
Tuyau D'eau / Wa Ter Pipe
Radiateur / Radi Ator
Reservoir Du Pad Iateur / Reserve Tank
Thermometre / Thermo Sensor
Solenoide D'arret / S Top Solenoid
Alternateur [Paries C Omposantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Panneau De Bord / Pan El Board
Tableau De Commutateu R / Panel Switch
Phare Avant [Excepte Uk] / Head Light [Except Uk]
Phare Avant [Uk] / He Ad Light [Uk]
Feux De Combinaison A Vant / Front Combination Lamp
Feux De Combinaison A Rriere / Rear Combination Lamp
Lampe Plaque Immatric Ulation / License Lamp
Lumiere De Travail / Working Light
Plafonnier / Room Lig Ht
Panneau De Commande D 'Air Conditionneur/Relais / Air-Con.Control Panel/R Elay
Antenne/Annonceur / A Ntenna/Speaker
Reservoir Lave-Glace / Washer Tank
Essuie-Glase (Avant) / Wiper (Front)
Faisceau Electrique ( Corps) / Electrical Wiring (Body)
Faisceau Electrique ( Cabine) / Electrical Wiring (Cab)
Couvercle De Carter De Embrayage / Clutch Housing Cover
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differen Tial
Engrenage Conique Gauche / Bevel Ge Ar Lh
Engrenage Conique Droite / Bevel Ge Ar Rh
Carter Engre-Conique / Bevel Gear C Ase
Carter Reducteur Gauche / Front Axl E Case Lh
Carter Reducteur Droite / Front Axl E Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre D'entrainement De Roue Avant / Front Wheel Drive Shaft
Carter De Transmission / Transmis Sion Case
Carter De Differentiel / Differen Tial Gear Case
Carter De Pont Arriere G. / Rear Axle Case Lh
Carter De Pont Arriere D. / Rear Axle Case Rh
Arbre De Embrayage / Clutch Shaft
Hst / Hst
Hst (Cas) [Parties Composantes] / Hst (Case) [Component Parts]
Hst (Pompe) [Parties Composantes] / Hst (Pump) [Component Parts]
Hst (Moteur) [Parties Composantes ] / Hst (Motor) [Component Parts]
Hst (Couvercle De Bloc D' Orifice ) [Parties Composantes] / Hst (Port Block Cover) [C Omponent Parts]
Hst (Support De Neutre) [Parties Composantes] / Hst (Neutral Holder) [Component Part S]
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre De Changement De Gamme / Ra Nge Gear Shaft
Arbre De Marche Arriere / Reverse Shaft
Arbre Primaire De Pdf / Pto Drive Shaft
Arbre De Pdf Embrayage / Pto Clut Ch Shaft
Embrayage Pdf / Pto Clutch
Pdf Ventrale / Mid Pto
Changement De Gamme / Bevel Gear Shaft
Differentiel Arriere / Rear Diffe Rential
Bras De Chengement De Vit Esse Pdf / Pto Gear Shift Arm
Fourchette De Blocage Dif Ferentiel / Differential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein (Avant) / Brake Rod (Front)
Tige De Frein (Arriere) / Brake Rod (Rear)
Levier De Frein De Stationnement / Parking Brak E Lever
Pedale De Commande De Vitesse / Speed Change Pedal
Tige De Commande De Vittesse / Speed Change Rod
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Commande D'avance / Cruise Control Lever
Croisière De Presse Cable / Cr Uise Release Cable
Levier De Chengement De Vitess E Pdf / Pto Gear Shift Lever
Levier Du Controle De Position / Position Control Lever
Levier De Distributeur De Char Geur / Loader Valve Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Diff Erentiel / Differential Lock Pedal
Bras De Demi-Tour Rapide / Bi- Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Speed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Speed Turn Shaft
Colonne De Direction / Steering Column
Pompe Hydraulique / Hydraulic Pump
Circuit D'huile H Ydraulique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile H Ydraulique (Refoulement) / Hydraulic Pipe (Delivery )
Circuit D'huile H Ydraulique (Direction) / Hydraulic Oil Line (Steeri Ng)
Circuit D'huile H Ydraulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile H Ydraulique (Refroidisseur) / Hydraulic Oil Line (Oi L Cooler)
Circuit D'huile H Ydraulique (F/M) / Hydraulic Oil Line (F/M)
Distributeur De C Hargeur / Loader Valve
Distributeur De C Hargeur [Parties Composantes] / Loader Valve [Compo Nent Parts]
Biellete De Distr Ibuteur De Chargeur / Loader Valve Link
Tuyau De Chargeur De Hydraulique / Hydraulic Loader Pipe
Cylindre Hydrauli Que / Hydraulic Cylinder
Piston Hydrauliqu E/Bras De Relevage / Hydraulic Piston/Lift Arm
Distributeur Cont Role / Control Valve
Tombent Ajustemen T Arbre / Fall Adjustment Shaft
Soupape De Pdf / Pto Valve
Soupape De Pdf [P Arties Composantes] / Pto Valve [Component Parts]
Barre De Relevage / Lift Rod
Bras Inferieur / Lower Link
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere / Rear Hitch
Calandre Avant / Front Grille
Hst / Hst
Capot Lateral / Side Cover
Siege (Grammer Msg83/511) / Seat (Grammer Msg83/511)
Siege (Grammer Msg93/511) / Seat (Grammer Msg93/511)
Siege (Sears 807) / Seat (Sears 807)
Siege (Sears 830) / Seat (Sears 830)
Armature De Cabine / Cab Frame
Couvercle De Panneau / Panel Cover
Couvercle Inferieur / Seat Under Cover
Aile De Dessus / Over Fender
Couvercle Arriere / Tail Cover
Portiere Gauche / Door Lh
Portiere Droite / Door Rh
Serrure De Portiere Gauche / Door Lock Lh
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Tapis / Floor Mat
Abri Interieur / Interior Cover
Guide De Levier D. / Lever Guide Rh
Glace Avant / Front Glass
Vitre Arriere / Hatch Back Glass
Retroviseur / Rearview Mirror
Air Conditionneur / Air C Onditioner
Tuyau Purge (Air Conditio Nneur) / Drain Hose (Air Conditioner)
Condensateur / Condenser
Tuyau De Air Conditionneu R / Air Conditioner Pipe
Tuyau De Chauffage / Heat Er Hose
Conduit De Climatiseur / Air Conditioner Duct
Roue Avant (5-12) / Front Wheel (5-1 2)
Roue Avant (6-12) / Front Wheel (6-1 2)
Roue Avant (6,00-12) / Front Wheel ( 6.00-12)
Roue Avant (22*8,50-12) / Front Whee L (22*8.50-12)
Roue Avant (24*8,50-12) / Front Whee L (24*8.50-12)
Roue Arriere (8-16) / Rear Wheel (8 -16)
Roue Arriere (9,5-18) / Rear Wheel (9.5-18)
Roue Arriere (31*13,5-15) / Rear Wh Eel (31*13.5-15)
Roue Arriere (315/75d-15) / Rear Wh Eel (315/75d-15)
Eclairage De Travail (Arriere) [Option] / Wor King Light Kit (Rear) [Option]
Essuie-Glase [Option] / Rear Wiper Kit [Optio N]
Cylindre De Relevage (Bras De Relevage) [Opti On] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mo Wer Lift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Option]
Controle De La Valve Auxiliaire [Option] / Au Xiliary Control Valve [Option]
Controle De La Valve Auxiliare [Parties Compo Santes] [Option] / Auxiliary Control Valve [Compone Nt Parts] [Option]
Levier De Controle De La Valve Auxiliaire (1e Me) [Option] / Auxiliary Control Valve Lever Kit (1 St) [Option]
Levier De Controle De La Valve Auxiliaire (2e Me) [Option] / Auxiliary Control Valve Lever Kit (2 Nd) [Option]
Accouplement De La Valve Auxiliaire (1eme) [O Ption] / Auxiliary Control Valve Coupler (1st) [Opt Ion]
Accouplement De La Valve Auxiliaire (2eme) [O Ption] / Auxiliary Control Valve Coupler (2nd) [Opt Ion]
Equipement Du Debouche Hydraulique Avant [Opt Ion] / Front Hydraulic Outlet Kit [Option]
Bkidk5321 >> B2231hdbc-S5
Volant / Flywheel
Volant / Flywheel
Pompe À Eau / Water Pump
Ventilateur / Fa N
Ventilateur / Fa N
Alternateur / Alterna Tor
Demarreur / Starter
Demarreur / Starter
Batterie / Battery
Batterie / Battery
Relais / Relay
Hst / Hst
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Verin De Direction / Steering Cylinder
Cylindre De Direction [Parties Composant Es] / Steering Cylinder [Component Parts]
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Distributeur [Par Ties Composantes] / Control Valve [Component Parts]
Serrure De Portiere Droite / Door Lock Rh
Tapis / Floor Mat
Tapis / Floor Mat
Modification Insonore / Sound Absorber
Guide De Levier G. / Lever Guide Lh
Penture De Glace Arriere / Hatch Back Glass Hing E
Compresseur / Air Compres Sor
Tapis / Floor Mat
