Kubota Tractor B2231HDBC-S5 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2231HDBC-S5 Tractor
Number of Pages: 483 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Guide
Volante / Flywheel
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Entrada Tubo (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Sensor Thermo / Thermo Sensor
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Faro Delantero [Excepto Uk] / Head Light [Except Uk]
Faro Delantero [Uk] / Head Light [Uk]
Luz Matricula / License Lamp
Trabajo Luz / Working Light
Panel/Relé De Control De Aire Acondicionado / Air-Con.Control Panel/Relay
Antena/Altavoz / Antenna/Speaker
Leva (Delantera) / Wiper (Front)
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Instalacion Electrica (Cabina) / Electrical Wiring (Cab)
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Eje Delantero Izquierdo / Front Axle Lh
Eje Delantero Derecho / Front Axle Rh
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Embrague Eje / Clutch Shaft
Hst
Hst (Caja) [Componente Piezas] / Hst (Case) [Component Parts]
Hst (Bomba) [Componente Piezas] / Hst (Pump) [Component Parts]
Hst (Motor) [Componente Piezas] / Hst (Motor) [Component Parts]
Hst (Puerto Cubierta Del Bloque) [Componente Piezas] / Hst (Port Block Cover) [Component Parts]
Hst (Soporte Neutral) [Componente Piezas] / Hst (Neutral Holder) [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Tdf Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Bevel Gear Shaft
Tdf Engranaje Cambio Brazo / Pto Gear Shift Arm
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno (Delantera) / Brake Rod (Front)
Varilla De Freno (Trasero) / Brake Rod (Rear)
Cable De Liberación De Velocidad / Cruise Release Cable
Posicion Control Palanca / Position Control Lever
Palanca De Válvula Del Cargador / Loader Valve Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Direccion Poste / Steering Column
Hidraulico Aceite Linea (Impulsion) / Hydraulic Pipe (Delivery)
Hidraulico Aceite Linea (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Válvula Del Cargador [Componente Piezas] / Loader Valve [Component Parts]
Enlace De La Válvula Del Cargador / Loader Valve Link
Tubería Hidráulica Del Cargador / Hydraulic Loader Pipe
Hidraulico Cilindro / Hydraulic Cylinder
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Distribuidor / Control Valve
Tdf Valvula / Pto Valve
Tdf Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche / Rear Hitch
Tdf Protector / Pto Protector
Capo / Hood (Bonnet) Upper
Lado Cubierta / Side Cover
Asiento (Grammer Msg83/511) / Seat (Grammer Msg83/511)
Asiento (Grammer Msg93/511) / Seat (Grammer Msg93/511)
Asiento (Sears 807) / Seat (Sears 807)
Asiento (Sears 830) / Seat (Sears 830)
Cabina Bastidor / Cab Frame
Panel Inferior / Panel Cover
Asiento Inferior Cubierta / Seat Under Cover
Encima Guardabarros / Over Fender
Cola Cubierta / Tail Cover
Puerta Izqd / Door Lh
Puerta Dcha / Door Rh
Cerradura De Puerta Izqd / Door Lock Lh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Ruido Supresion / Sound Absorber
Interior Cubierta / Interior Cover
Adelante Vidrio / Front Glass
Cristal Puerta Trasera / Hatch Back Glass
Bisagras Para Vidrio De Automóvil De Tres Puertas / Hatch Back Glass Hinge
Manguera De Vaciado (Aire Acondicionado) / Drain Hose (Air Conditioner)
Condensador / Condenser
Aire Acondicionador Tubo / Air Conditioner Pipe
Compresor / Air Compressor
Conducto Aire Acondicionador / Air Conditioner Duct
Rueda Delantera (5-12) / Front Wheel (5-12)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Kit De Faro De Labor (Trasero) [Opcion] / Working Light Kit (Rear) [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Auxiliar Control Valvula [Opcion] / Auxiliary Control Valve [Option]
Valvula Auxiliar Control [Componente Piezas] [Opcion] / Auxiliary Control Valve [Component Parts] [Option]
Palanca De Distribuidor De Servicios Externos (Primero) [Opcion] / Auxiliary Control Valve Lever Kit (1st) [Option]
Palanca De Distribuidor De Servicios Externos (Segundo) [Opcion] / Auxiliary Control Valve Lever Kit (2nd) [Option]
Acoplador De Distribuider De Servicios Externos (Primero) [Opcion] / Auxiliary Control Valve Coupler (1st) [Option]
Acoplador De Distribuider De Servicios Externos (Segundo) [Opcion] / Auxiliary Control Valve Coupler (2nd) [Option]
Adelante Hidraulico Puerto Kit [Opcion] / Front Hydraulic Outlet Kit [Option]
