Kubota Tractor B2231HDB-F2-S5 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2231HDB-F2-S5 Tractor
Number of Pages: 236 Pages
Artic Les Fréquemment Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Cams Haft And Idle Gear Shaft
Pistons Et Vilebrequin / Piston And Cranksh Aft
Volant / Flywheel
Arbre A Cames De Carburant Et Arbre Regulat Eur / Fuel Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Plate
Porte-Buse Et Bougie De Préchauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Noz Zle Holder [Component Parts]
Bride D'eau Et Thermostat / Water Flange An D Thermostat
Pompe À Eau / Water Pump
Vanne Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pi Pe (Air Cleaner)
Silencieux / Muffler
Reservoir A Carburant / Fue L Tank
Tuyau A Carburant / Fuel Pi Pe
Filtre A Carburant / Fuel F Ilter
Filtre A Carburant [Parties Composantes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Reservoir Du P Adiateur / Reserve Tank
Contact A Huile The Rmometre / Oil Switch And Thermo Sensor
Alternateur / Alter Nator
Alternateur [Paries Composantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Composantes] / Starter [Component Parts]
Batterie / Battery
Commutateur / Switc H
Relais / Relay
Panneau De Bord / P Anel
Tableau De Bord [Pa Rties Composantes] / Panel Board [Component Parts]
Tableau De Commutat Eur / Panel Switch
Phare Avant [Ec] / Head Light [Ec]
Phare Avant [Uk] / Head Light [Uk]
Feux De Combinaison Avant / Front Combination Lamp
Feux De Combinaison Arriere / Rear Combination Lamp
Lampe Plaque Immatr Iculation / License Lamp
Faisceau Electrique (Corps) / Electrical Wiring (Body)
Couvercle De Carter De Embrayage / Clutc H Housing Cover
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Carter Reducteur / Front Axle Cas E
Differentiel Avant / Front Differ Ential
Engrenage Conique Gauche / Bevel Gear Lh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Front A Xle Case Lh
Carter Reducteur Droite / Front A Xle Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre D'entrainement De Roue Avan T / Front Wheel Drive Shaft
Carter De Transmission / Transm Ission Case
Carter De Differentiel / Differ Ential Gear Case
Carter De Pont Arriere G. / Rea R Axle Case Lh
Carter De Pont Arriere D. / Rea R Axle Case Rh
Arbre De Embrayage / Clutch Sha Ft
Arbre De Transmission / Propell Er Shaft
Hst / Hst
Hst (Cas) [Parties Composantes] / Hst (Case) [Component Parts]
Hst (Pompe) [Parties Composante S] / Hst (Pump) [Component Parts]
Hst (Moteur) [Parties Composant Es] / Hst (Motor) [Component Parts]
Hst (Couvercle De Bloc D'orific E) [Parties Composantes] / Hst (Port Block Cover) [ Component Parts]
Hst (Support De Neutre) [Partie S Composantes] / Hst (Neutral Holder) [Component Pa Rts]
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre De Marche Arriere / Rever Se Shaft
Arbre Primaire De Pdf / Pto Dri Ve Shaft
Arbre De Pdf Embrayage / Pto Cl Utch Shaft
Embrayage Pdf / Pto Clutch
Changement De Gamme / Bevel Gea R Shaft
Differentiel Arriere / Rear Dif Ferential
Fourchette De Changemen T De Gamme / Range Gear Shift Fork
Bras De Chengement De V Itesse Pdf / Pto Gear Shift Arm
Fourchette De Blocage D Ifferentiel / Differential Lock Shift Fork
Essieu Arriere Gauche / Rear Axl E Lh
Essieu Arriere Droite / Rear Axl E Rh
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Br Ake Lever
Pedale De Commande De Vitess E / Speed Change Pedal
Tige De Commande De Vittesse / Speed Change Rod
Bras De Securite De Hst / Hs T Release Arm
Levier De Changement De Gamm E / Range Gear Shift Lever
Levier De Tranission Aux Rou Es Avant / Front Wheel Drive Lever
Levier De Commande D'avance / Cruise Control Lever
Levier De Chengement De Vite Sse Pdf / Pto Gear Shift Lever
Levier Du Controle De Positi On / Position Control Lever
Levier De Distributeur De Ch Argeur / Loader Valve Lever
Pedale De Frien / Brake Peda L
Pedale De Verrouillage Du Di Fferentiel / Differential Lock Pedal
Bras De Demi-Tour Rapide / B I-Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Speed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Speed Turn Shaft
Colonne De Direction / Steering Column
Verin De Direction / Steering Cylinder
Cylindre De Direction [Parties Composa Ntes] / Steering Cylinder [Component Parts]
Pompe Hydrauliq Ue / Hydraulic Pump
Circuit D'huile Hydraulique (Aspirat) / Hydraulic Oil Line (Suctio N)
Circuit D'huile Hydraulique (Direction) / Hydraulic Oil Line (Stee Ring)
Circuit D'huile Hydraulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydraulique (Refroidisseur) / Hydraulic Oil Line ( Oil Cooler)
Circuit D'huile Hydraulique (F/M) / Hydraulic Oil Line (F/M)
Distributeur De Chargeur / Loader Valve
Distributeur De Chargeur [Parties Composantes] / Loader Valve [Com Ponent Parts]
Biellete De Dis Tributeur De Chargeur / Loader Valve Link
Tuyau De Charge Ur De Hydraulique / Hydraulic Loader Pipe
Cylindre Hydrau Lique / Hydraulic Cylinder
Piston Hydrauli Que/Bras De Relevage / Hydraulic Piston/Lift Arm
Levier De Reven Ue / Feed Back Lever
Distributeur [P Arties Composantes] / Control Valve [Component Part S]
Tombent Ajustem Ent Arbre / Fall Adjustment Shaft
Soupape De Pdf / Pto Valve
Soupape De Pdf [Parties Composantes] / Pto Valve [Component Parts]
Barre De Relevage / Lift Rod
Bras Inferieur / Lower Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere / Rear Hitch
Calandre Avant / Front Grille
Capot Lateral / Side Cover
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Plancher / Floor Sheet
Siege(Cobo Sc74/M91) / Seat(Cobo Sc74/M 91)
Siege(Grammer Msg83/511) / Seat(Grammer Msg83/511)
Siege(Grammer Msg93/511) / Seat(Grammer Msg93/511)
Siege(Sears 807) / Seat(Sears 807)
Siege(Sears 830) / Seat(Sears 830)
Marchepied / Step
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Cadre Anti-Renversment / Rops
Roue Avant (5-12) / Front Wheel (5 -12)
Roue Avant (6-12) / Front Wheel (6 -12)
Roue Avant (6,00-12) / Front Wheel (6.00-12)
Roue Avant (22*8,50-12) / Front Wh Eel (22*8.50-12)
Roue Avant (24*8,50-12) / Front Wh Eel (24*8.50-12)
Roue Arriere (8-16) / Rear Wheel (8-16)
Roue Arriere (9,5-16) / Rear Whee L (9.5-16)
Roue Arriere (9,5-18) / Rear Whee L (9.5-18)
Roue Arriere (31*13,5-15) / Rear Wheel (31*13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel (315/75d-15)
Accessoires Et Pieces De Service / Accessorie S And Service Parts
Eclairage De Travail [Option] / Working Lig Ht Kit [Option]
Cylindre De Relevage (Bras De Relevage) [Op Tion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower Lift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight K It [Option]
Equipement Du Debouche Hydraulique Avant [O Ption] / Front Hydraulic Outlet Kit [Option]
