Kubota Tractor B2231DB-S5 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2231DB-S5 Tractor
Number of Pages: 488 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Filtre D'huile / Oil Filter
Volant / Flywheel
Volant / Flywheel
Plaque De Vitesse-Controle / Speed Control Plat E
Porte-Buse Et Bougie De Préchauffage / Nozzle H Older And Glow Plug
Pompe À Eau / Water Pump
Vanne Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe ( Air Cleaner)
Silencieux / Muffler
Reservoir A Carburant / Fuel Ta Nk
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant / Fuel Filte R
Filtre A Carburant [Parties Com Posantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel Pum P
Ventilateur / Fan
Radiateur / Radiat Or
Reservoir Du Padia Teur / Reserve Tank
Contact A Huile Thermom Etre / Oil Switch And Thermo Sensor
Solenoide D'arret / Sto P Solenoid
Alternateur [Type Cadre Anti-Renv. D'arriere] / Alternator [Rear Rops Type ]
Demarreur / Starter
Batterie / Battery
Commutateur [Type Cadre Anti-Renv. D'arriere] / Switch [Rear Rops Type]
Relais / Relay
Panneau De Bord / Panel Board
Tableau De Bord [Partie S Composantes] / Panel Board [Component Parts]
Tableau De Commutateur / Panel Switch
Phare Avant [Uk] / Head Light [Uk]
Feux De Combinaison Ava Nt [Type Cadre Anti-Renv. D'arriere] / Front Combin Ation Lamp [Rear Rops Type]
Feux De Combinaison Arr Iere / Rear Combination Lamp
Lampe Plaque Immatricul Ation [Type Cadre Anti-Renv. D'arriere] / License L Amp [Rear Rops Type]
Faisceau Electrique (Co Rps) [Type Cadre Anti-Renv. D'arriere] / Electrical Wiring (Body) [Rear Rops Type]
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differenti Al
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Cas E
Carter Reducteur Gauche / Axle Case L H
Carter Reducteur Droite / Axle Case R H
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre D'entrainement De Roue Avant / Front Wheel Drive Shaft
Carter De Transmission [Type Cadre Anti-Renv. D'arriere] / Transmission Case [Rear Rop S Type]
Carter De Differentiel / Differenti Al Gear Case
Carter De Pont Arriere G. [Type Cad Re Anti-Renv. D'arriere] / Rear Axle Case Lh [Rear Rops Type]
Carter De Pont Arriere D. [Type Cad Re Anti-Renv. D'arriere] / Rear Axle Case Rh [Rear Rops Type]
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller S Haft
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre Principal De Changement / Mai N Gear Shaft
Arbre De Changement De Gamme [Type Cadre Anti-Renv. D'arriere] / Range Gear Shaft [Rea R Rops Type]
Arbre De Marche Arriere 1 / Reverse Shaft 1
Arbre De Marche Arriere 2 [Type Cad Re Anti-Renv. D'arriere] / Reverse Shaft 2 [Rear Ro Ps Type]
Arbre Primaire De Pdf [Type Cadre A Nti-Renv. D'arriere] / Pto Drive Shaft [Rear Rops T Ype]
Arbre De Pdf Changement [Type Cadre Anti-Renv. D'arriere] / Pto Gear Shift Shaft [Rear Rops Type]
Pdf Ventrale [Type Cadre Anti-Renv. D'arriere] / Mid Pto [Rear Rops Type]
Changement De Gamme / Bevel Gear Sh Aft
Differentiel Arriere / Rear Differe Ntial
Fourchette De Changement De Vitesses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Sh Uttle Shift Fork
Tige De Inverseur / Shuttle Shift Rod
Fourchette De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'arriere] / Pt O Gear Shift Fork [Rear Rops Type]
Bras De Chengement De Vites Se Pdf [Type Cadre Anti-Renv. D'arriere] / Pto Gear Shift Arm [Rear Rops Type]
Fourchette De Blocage Diffe Rentiel / Differential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Tige De Changement De Vitesses P Rincipal / Main Gear Shift Rod
Levier De Inverseur / Shuttle Sh Ift Lever
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Tranission Aux Roues A Vant / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'arriere] / Pto Gear Sh Ift Lever [Rear Rops Type]
Levier Du Controle De Position / Position Control Lever
Levier De Distributeur Auxiliair E / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Differ Entiel / Differential Lock Pedal
Bras De Demi-Tour Rapide / Bi-Sp Eed Turn Arm
Tige De Virage A 2 Vitesses / Bi -Speed Shift Rod
Arbre De Braquage 2 Vitesses / Bi -Speed Turn Shaft
Colonne De Direction / Steering Column
Verin De Direction / Steering Cylinder
Pompe Hydraulique / Hydraulic Pump
Pompe Hydraulique [ Parties Composantes] / Hydraulic Pump [Component Pa Rts]
Circuit D'huile Hyd Raulique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hyd Raulique (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hyd Raulique (Direction) / Hydraulic Oil Line (Steering )
Circuit D'huile Hyd Raulique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydrauliqu E / Hydraulic Cylinder
Piston Hydraulique/ Bras De Relevage / Hydraulic Piston/Lift Arm
Distributeur Contro Le / Control Valve
Distributeur [Parti Es Composantes] / Control Valve [Component Parts]
Valve Auxiliaire / Auxiliary Control Valve
Controle Des Valves Aux.[Parties Composantes] / Remote Control Valve [ Component Parts]
Tombent Ajustement Arbre / Fall Adjustment Shaft
Soupape De Surete / Relief Valve
Barre De Relevage / Lift Rod
Bras Inferieur [Type Cadre Anti-Renv. D'arrie Re] / Link,Lower [Rear Rops Type]
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere [Type Cadre Anti-Renv. D'arr Iere] / Rear Hitch [Rear Rops Type]
Calandre Avant / Front Grille
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. [Type Cadre Anti-Renv. D 'Arriere] / Lever Guide Lh [Rear Rops Type]
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Siege (Grammer Msg83/511) / Seat (Grammer M Sg83/511)
Siege (Grammer Msg93/511) / Seat (Grammer M Sg93/511)
Siege (Sears 807) / Seat (Sears 807)
Siege (Sears 830) / Seat (Sears 830)
Marchepied / Step
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Couvercle Arriere [Type Cadre Anti-Renv. D' Arriere] / Rear Cover [Rear Rops Type]
Cadre Anti-Renversement 2 (Arriere) [Type C Adre Anti-Renv. D'arriere] / Rops 2 (Rear) [Rear Ro Ps Type]
Roue Avant (5-12) / Front Wheel (5-12)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6. 00-12)
Roue Avant (22*8,50-12) / Front Wheel (22*8.50-12)
Roue Avant (24*8,50-12) / Front Wheel (24*8.50-12)
Roue Arriere (8-16) / Rear Wheel (8-1 6)
Roue Arriere (9,5-16) / Rear Wheel (9 .5-16)
Roue Arriere (9,5-18) / Rear Wheel (9 .5-18)
Roue Arriere (31*13,5-15) / Rear Whee L (31*13.5-15)
Etiquette (Avant) [Type Cadre Anti-Renv. D' Arriere] / Label (Front) [Rear Rops Type]
Etiquette (Arriere) [Type Cadre Anti-Renv. D'arriere] / Label (Rear) [Rear Rops Type]
Accessoires Et Pieces De Service / Accessories An D Service Parts
Chargeur Frontal Controle De La Valve Avant (Va Lve) [Option] / Front Loader Control Valve Kit (Val Ve) [Option]
Chargeur Frontal Controle De La Valve Avant (Le Vier) [Option] / Front Loader Control Valve Kit (Le Ver) [Option]
Chargeur Frontal Controle De La Valve Avant (Bi Ellete) [Option] / Front Loader Control Valve Kit ( Link) [Option]
Chargeur Frontal Controle De La Valve Avant (Tu Yau 1) [Option] / Front Loader Control Valve Kit (P Ipe 1) [Option]
Chargeur Frontal Controle De La Valve Avant (Tu Yau 2) [Option] / Front Loader Control Valve Kit (P Ipe 2) [Option]
Cylindre De Relevage (Bras De Relevage) [Option ] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mowe R Lift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [ Option]
Equipement Du Debouche Hydraulique Avant [Optio N] / Front Hydraulic Outlet Kit [Option]
Bkidk5319 >> B2231db-S5
Volant / Flywheel
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Wate R Pipe
Alternateur [Paries Com Posantes] [Type Cadre Anti-Renv. D'arriere] / Alter Nator [Component Parts] [Rear Rops Type]
Demarreur / Starter
Batterie / Battery
Relais / Relay
Phare Avant [Excepte Uk ] / Head Light [Except Uk]
Embrayage / Clutch
Aile / Fender
Siege (Cobo Sc74/M91) / Seat (Cobo Sc74/M91 )
Marchepied / Step
Roue Arriere (315/75d-15) / Rear Whee L (315/75d-15)
Chargeur Frontal Controle De La Valve Avant [Pa Rties Composantes] [Option] / Front Loader Control Valve Kit [Component Parts] [Option]
Eclairage De Travail [Type Cadre Anti-Renv. D'a Rriere] [Option] / Working Light Kit [Rear Rops Typ E] [Option]
