Kubota Tractor B2230HDBC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2230HDBC Tractor
Number of Pages: 383 Pages
Frequently Used It Ems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pistons Et Vilebrequin / Piston And Crankshaft # # No.S.<=As9994 S.No.;<=As9994 / S.No.<=As9994 S.No .;<=As9994
Pistons Et Vilebrequin / Piston And Crankshaft # # No.S.>=Au0001 S.No.;>=Au0001 / S.No.>=Au0001 S.No .;>=Au0001
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Kit D'accouplements Rapides [Option] / Water Fla Nge And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Tige D'accelerateur / Accelerator Rod
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Comp Osantes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiato R
Reservoir Du Radiat Eur / Reserve Tank
Contact A Huile Thermome Tre / Oil Switch And Thermo Sensor
Alternateur Complet / Al Ternator
Alternateur [Parties Com Posantes] / Alternator [Component Parts]
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Panel Board
Tableau De Bord (Pieces Composantes) / Panel Board [Component Parts]
Tableau De Commutateur / Panel Switch
Phare [Uk] / Head Light [Uk]
Phare [Ec] / Head Light [Ec]
Feux De Combinaison Avan T / Front Combination Lamp
Feux De Combinaison Arri Ere / Rear Combination Lamp
Lamp Et Plaque D'immatri Culation [Uk] / License Lamp [Uk]
Lamp Et Plaque D'immatri Culation [Ec] / License Lamp [Ec]
Prise De Remorque / Trai Ler Socket
Phare De Travail / Worki Ng Light
Panneau De Commande D'ai R Conditionneur / Air-Con.Control Panel
Cuve De Lavage / Washer Tank
Came / Wiper
Faisceau Electrique (Arr Iere) / Electrical Wiring (Body)
Faisceau Electrique (Cab Ine) [Uk] / Electrical Wiring (Cab) [Uk]
Faisceau Electrique (Cab Ine) [Ec] / Electrical Wiring (Cab) [Ec]
Couvercle De Carter De Embrayage / Clutch Hou Sing Cover
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Carter De Transmission / Transmissio N Case
Carter De Differentiel / Differentia L Gear Case
Carter De Pont Arriere G. / Rear Axl E Case Lh
Carter De Pont Arriere D. / Rear Axl E Case Rh
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller Sh Aft
Hst / Hst
Hst (Bloc De Cylindre) [Parties Comp Osantes] 1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Couvercle De Bloc D'orifice) [P Arties Composantes] 2 / Hst (Port Block Cover) [Com Ponent Parts] 2
Hst (Joint) [Parties Composantes] 3 / Hst (Gasket) [Component Parts] 3
Hst (Support De Neutre) [Parties Com Posantes] 4 / Hst (Neutral Holder) [Component Parts ] 4
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre De Marche Arriere / Reverse Sh Aft
Arbre Primaire De Pdf / Pto Drive Sh Aft
Arbre De Pdf Embrayage / Pto Clutch Shaft
Pdf Ventrale / Mid Pto
Differentiel Arriere / Rear Differen Tial
Bras De Chengement De Vitess E Pdf / Pto Gear Shift Arm
Fourchette De Blocage Differ Entiel / Differential Lock Shift Fork
Bras De Securite De Hst / Hs T Release Arm
Levier De Changement De Gamm E / Range Gear Shift Lever
Levier De Tranission Aux Rou Es Avant / Front Wheel Drive Lever
Levier De Chengement De Vite Sse Pdf / Pto Gear Shift Lever
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Pedale De Verrouillage Du Differentie L / Differential Lock Pedal
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Levier De Frein De Stationnement / Parking Brake L Ever
Pedale De Frien / Brake Pedal
Pedale De Commande De Vitesse / S Peed Change Pedal
Tige De Commande De Vittesse / Sp Eed Change Rod
Tige De Securite De Croisiere / C Ruise Release Rod
Levier De Commande D'avance / Cru Ise Control Lever
Arbre De Braquage 2 Vitesses / Bi- Speed Turn Shaft
Levier De Position / Position Control Lever
Levier De Distribute Ur Auxiliaire / Remote Control Lever
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [P Arties Composantes] / Hydraulic Pump [Component Par Ts]
Circuit D'huile Hydr Aulique(Aspirat) / Hydraulic Oil Line(Suction)
Circuit C'huile Hydr Aulique (Retour) / Hydraulic Oil Line(Delivery)
Circuit D'huile Hydr Aulique(Direction) / Hydraulic Oil Line(Steering)
Circuit D'huile Hydr Aulique (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydr Aulique (Refroidisseur) / Hydraulic Oil Line (Oil C Ooler)
Circuit D'huile Hydr Aulique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydraulique / Hydraulic Cylinder
Levier De Controle D E Position / Feed Back Lever
Distributeur Hydraul Ique / Control Valve
Distributer [Parties Composantes] / Control Valve [Component Parts]
Distributeur Auxilia Ire / Remote Control Valve
Controle Des Valves Aux.[Parties Composantes] / Remote Control Valve [C Omponent Parts]
Tombent Ajustement A Rbre / Fall Adjustment Shaft
Soupape De Surete / Relief Valve
Soupare De Pdf / Pto Valve
Soupare De Pdf [Part Ies Composantes] / Pto Valve [Component Parts]
Barre De Relevage / Lift Rod
Tige De Virage A 2 Vitesses / Bi-Speed Shift Rod
Differentiel Avant / Front Differentia L
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Axle Case Lh
Carter Reducteur Droite / Axle Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front Dr Ive Shaft
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direction / Steering Cylinder
Tirant Inferi Eur / Lower Link
Tirant Superi Eur / Top Link
Chaine D'arre T / Check Chain
Barre D'attel Age / Drawbar
Attelage / Fr Ont Hitch
Attelage Arri Ere / Rear Hitch
Protection Pd F / Pto Protector
Capot / Bonnet
Capot / Bonnet
Capot Lateral / Side Cover
Capot / Bonnet
Piller Centre / Center Pillar
Cabine / Cab
Couvercle De Panneau / Panel Cover
Marchepied / Step
Couvercle Inferieur / Seat Under Cover
Couvercle De Aile / Fender Cover
Aile / Fender
Aile / Fender
Couvercle Arriere / Tail Cover
Porte Gauche / Door Lh
Serrure De Portiere Droite / Door Lock Rh
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Tapis / Floor Mat
Modification Insonore / Sound Absorber
Modification Insonore Arriere / Sound Absorber Rear
Plaque D'isolation / Insulation Plate
Abri Interieur / Interior Cover
Guide De Levier G. / Lever Guide Lh
Siege (Cobo Sc74/M91) [Excepte Allemand] / Seat (Co Bo Sc74/M91) [Except Germany]
Ventilateur / Fan
Siege (Kab Seating 11/P1) [Excepte Allemand] / Seat (Kab Seating 11/P1) [Except Germany]
Glace Avant Et Glace Arriere / Front Glass And Rear Glass
Glace Lateral / Side Glass
Glace De Arriere / Hatch Back Glass
Penture De Glace Arriere / Hatch Back Glass Hinge
Retroviseur / Rearview Mirror
Air Conditionneur / Air Cond Itioner
Cable De Air Conditionneur / Air Conditioner Cable
Tuyau De Drainage(Air Condit Ionneur) / Drain Hose(Air Conditioner)
Condensateur / Condenser
Tuyau De Air Conditionneur / Air Conditioner Pipe
Compresseur / Compressor
Conduit De Climatiseur / Air -Conditioner Duct
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (22*8,50-12) / Front Wheel (2 2*8.50-12)
Roue Avant (6,00-12) [Option] / Front Wh Eel (6.00-12) [Option]
Roue Avant (6-12b) [Option] / Front Whee L (6-12b) [Option]
Roue Avant (24*8,50-12) [Option] / Front Wheel (24*8.50-12) [Option]
Roue Arriere (9,5-16) / Rear Wheel (9.5 -16)
Roue Arriere (31*13,5-15) / Rear Wheel (31*13.5-15)
Roue Arriere (9,5-18) [Option] / Rear W Heel (9.5-18) [Option]
Roue Arriere (8-16) [Option] / Rear Whe El (8-16) [Option]
Roue Arriere (315/75d-15) [Option] / Re Ar Wheel (315/75d-15) [Option]
Etiquette (Avant) [Excepte Italien] / Label (Front) [Except Italian]
Etiquette (Avant) [Italien] / Label (Front) [Italian]
Etiquette (Arriere) [Anglais] [Francais] / L Abel (Rear) [English] [French]
Etiquette (Arriere) [Allemand] [Espagnol] / Label (Rear) [German] [Spanish]
Etiquette (Arriere) [Italien] / Label (Rear) [Italian]
Accessories Et Piece De Service / Accessories And Service Parts
Alternateur [Option] / Alternator Kit [Option]
Alternateur [Parties Composantes] [Option] / Alt Ernator [Component Parts] [Option]
Essuie-Glace [Option] / Rear Wiper Kit [Option]
Cd-Radio [Uk] [Option] / Cd-Radio Kit [Uk] [Opti On]
Pdf Ventrale(Pour Rck54/Rck60-25b-Eu-F Tondeuse) [Option] / Mid Pto Kit(For Rck54/Rck60-25b-Eu-F Mo Wer) [Option]
Cabine / Cab
Cylindre De Relevage (Cylindre) [Option] / Mower Lift Cylinder Kit (Cylinder) [Option]
Cabine / Cab
Contrepoids Avant [Option] / Front Weight Kit [O Ption]
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Batterie / Battery
Relais / Relay
Came / Wiper
Hst / Hst
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Cabine / Cab
Marchepied / Step
Aile / Fender
Aile / Fender
Tapis / Floor Mat
Ventilateur / Fan
Cabine / Cab
Cabine / Cab
