Kubota Tractor B2230HDB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2230HDB Tractor
Number of Pages: 575 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Filtro De Aire) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Faro Delantero [Uk] / Head Light [Uk]
Faro Delantero [Ec] / Head Light [Ec]
Adelante Combinacion Luz / Front Combination Lamp
Lampara De Matricula [Uk] / License Lamp [Uk]
Lampara De Matricula [Ec] / License Lamp [Ec]
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Adelante Eje Caja Iz / Front Axle Case Lh
Adelante Eje Caja Dr / Front Axle Case Rh
Adelante Eje Iz / Front Axle Lh
Adelante Eje Dr / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Hst
Hst (Bloque De Cilindros) [Componente Piezas] 1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Puerto Cubierta Del Bloque) [Componente Piezas] 2 / Hst (Port Block Cover) [Component Parts] 2
Hst (Junta) [Componente Piezas] 3 / Hst (Gasket) [Component Parts] 3
Hst (Soporte Neutral) [Componente Piezas] 4 / Hst (Neutral Holder) [Component Parts] 4
Pto Accionar Eje / Pto Drive Shaft
Pto Embrague Eje / Pto Clutch Shaft
Tdf Embrague / Pto Clutch
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Primero Eje / 1st Shaft
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Pto Engranaje Cambio Brazo / Pto Gear Shift Arm
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno / Brake Rod
Vara De Liberación De Velocidad / Cruise Release Rod
Hst Desbloquear Brazo / Hst Release Arm
Coloque La Palanca De Mando / Position Control Lever
Alejado Control Palanca / Remote Control Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Direccion Poste / Steering Post
Direccion Cilindro / Steering Cylinder
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Pto Valvula / Pto Valve
Pto Valvula [Componente Piezas] / Pto Valve [Component Parts]
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Espejo Retrovisor [Uk] / Rearview Mirror [Uk]
Espejo Retrovisor [Ec] / Rearview Mirror [Ec]
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento (Cobo Sc74/M91) [Excepto Aleman] / Seat (Cobo Sc74/M91) [Except Germany]
Asiento (Grammer Msg83/8) [Aleman] / Seat (Grammer Msg83/8) [Germany]
Asiento (Kab Seating Xh2/P1) [Excepto Aleman] / Seat (Kab Seating Xh2/P1) [Except Germany]
Asiento (Kab Seating 11/P1) [Excepto Aleman] / Seat (Kab Seating 11/P1) [Except Germany]
Asiento (Sears Mcs3000) [Excepto Aleman] / Seat (Sears Mcs3000) [Except Germany]
Peldano / Step
Cola Cubierta / Tail Cover
Rops
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (6,00-12) [Opcion] / Front Wheel (6.00-12) [Option]
Rueda Delantera (6-12b) [Opcion] / Front Wheel (6-12b) [Option]
Rueda Delantera (24*8,50-12) [Opcion] / Front Wheel (24*8.50-12) [Option]
Rueda Posterior (9,5-16) / Rear Wheel (9.5-16)
Rueda Posterior (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Posterior (9,5-18) [Opcion] / Rear Wheel (9.5-18) [Option]
Rueda Posterior (8-16) [Opcion] / Rear Wheel (8-16) [Option]
Rueda Posterior (315/75d-15) [Opcion] / Rear Wheel (315/75d-15) [Option]
Etiqueta (Adelante) [Excepto Italiano] / Label (Front) [Except Italian]
Etiqueta (Adelante) [Italiano] / Label (Front) [Italian]
Etiqueta (Trasero) [Ingles] [Frances] / Label (Rear) [English] [French]
Etiqueta (Trasero) [Aleman] [Espanol] / Label (Rear) [German] [Spanish]
Etiqueta(Trasero) [Italiano] / Label(Rear) [Italian]
Etiqueta(Trasero) / Label (Rear)
Delantera Intermitente Soporte [Opcion] / Front Winker Stay Kit [Option]
Intermedia Pto (Por Rck54/Rck60-25b-Eu-F Cortacespedes) [Opcion] / Mid Pto Kit (For Rck54/Rck60-25b-Eu-F Mower) [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Peso Delantera [Opcion] / Front Weight Kit [Option]
