Kubota Tractor B2230DC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2230DC Tractor
Number of Pages: 395 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case # # No.S.<=1dhz999 S.No.;<=1dhz999 / S.No.<=1dhz999 S .No.;<=1dhz999
Kit D'accouplements Rapides [Option] / Gear Case # # No.S.>=1dj0001 S.No.;>=1dj0001 / S.No.>=1dj0001 S .No.;>=1dj0001
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Compos Antes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Reservoir Du Radiateu R / Reserve Tank
Contact A Huile Thermometr E / Oil Switch And Thermo Sensor
Solenoide D'arret / Stop S Olenoid
Alternateur Complet / Alte Rnator
Alternateur [Parties Compo Santes] / Alternator [Component Parts]
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Panel Bo Ard
Tableau De Bord (Pieces Co Mposantes) / Panel Board [Component Parts]
Tableau De Commutateur / P Anel Switch
Phare [Uk] / Head Light [U K]
Phare [Ec] / Head Light [E C]
Feux De Combinaison Avant / Front Combination Lamp
Feux De Combinaison Arrier E / Rear Combination Lamp
Lamp Et Plaque D'immatricu Lation [Uk] / License Lamp [Uk]
Lamp Et Plaque D'immatricu Lation [Ec] / License Lamp [Ec]
Prise De Remorque / Traile R Socket
Phare De Travail / Working Light
Panneau De Commande D'air Conditionneur / Air-Con.Control Panel
Cuve De Lavage / Washer Ta Nk
Came / Wiper
Came / Wiper
Faisceau Electrique (Corps ) / Electrical Wiring (Body)
Faisceau Electrique (Cabin E) [Uk] / Electrical Wiring (Cab) [Uk]
Faisceau Electrique (Cabin E) [Ec] / Electrical Wiring (Cab) [Ec]
Embrayage / Clutch
Embrayage / Clutch
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedala D'embrayage / Clutch Pedal
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differential
Embrayage / Clutch
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Front Axle Cas E Lh
Essieu Avavt Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement (Avant) / Drive Sh Aft (Front)
Arbre De Entrainement (Arriere) / Drive Shaft (Rear)
Couvercle De Carter De Transmission / Transmission Case Cover
Carter De Differentiel / Differential Gear Case
Arbre De Transmission / Propeller Shaf T
Arbre Principal De Changement / Main G Ear Shaft
Arbre De Changement De Gamme / Range G Ear Shaft
Arbre De Marche Arriere 1 / Reverse Sh Aft 1
Arbre De Marche Arriere 2 / Reverse Sh Aft 2
Arbre Primaire De Pdf / Pto Drive Shaf T
Arbre De Pdf Changement / Pto Gear Shi Ft Shaft
Pdf Ventrale / Mid Pto
Changement De Gamme / Range Gear
Differentiel Arriere / Rear Differenti Al
Carter De Pont Arriere G. / Rear Axle C Ase Lh
Carter De Pont Arriere D. / Rear Axle C Ase Rh
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Fourchette De Changement De Vi Tesses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shutt Le Shift Fork
Tige De Inverseur / Shuttle Sh Ift Rod
Fourchette De Changement De Ga Mme / Range Gear Shift Fork
Fourchette De Chengement De Vi Tesse Pdf / Pto Gear Shift Fork
Bras De Chengement De Vitesse Pdf / Pto Gear Shift Arm
Fourchette De Blocage Differen Tiel / Differential Lock Shift Fork
F Rein Gauche / Brake Lh
F Rein Droite / Brake Rh
T Ige De Frein / Brake Rod
L Evier De Frein De Stationnement / Parking Brake Lev Er
Levier De Changement De Vitesses Pr Incipal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift Lever
Levier De Changement De Gamme / Ran Ge Gear Shift Lever
Levier De Tranission Aux Roues Avan T / Front Wheel Drive Lever
Levier De Position / Position Contr Ol Lever
Pedale De Verrouillage Du Different Iel / Differential Lock Pedal
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direction / Steering Cylinder
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrau Lique (Direction) / Hydraulic Oil Line (Steering)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bra S De Relevage / Hydraulic Piston/Lift Arm
Levier De Controle De Position / Feed Back Lever
Distributeur Hydrauliq Ue / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Controle Des Valves Au Xiliaire / Remote Control Valve
Controle Des Valves Au X. [Parties Composantes] / Remote Control Valve [Co Mponent Parts]
Tombent Ajustement Arb Re / Fall Adjustment Shaft
Soupape De Surete / Re Lief Valve
Barre De Relevage / Li Ft Rod
Tirant Inferieu R / Lower Link
Tirant Superieu R / Top Link
Chaine D'arret / Check Chain
Barre D'attelag E / Drawbar
Attelage / Fron T Hitch
Attelage Arrier E / Rear Hitch
Protection Pdf / Pto Protector
Avertisseur De Recul / Bonnet (Hood)
Capot Lateral / Side Cover
Piller Centre / Center Pillar
Ca Bine / Cab
Ca Bine / Cab
Co Uvercle De Panneau / Panel Cover
Ma Rchepied / Step
Co Uvercle Inferieur / Seat Under Cover
Co Uvercle De Aile / Fender Cover
Ai Le / Fender
Ai Le / Fender
Ai Le / Fender
Co Uvercle Arriere / Tail Cover
Po Rte Gauche / Door Lh
Po Rte Droite / Door Rh
Se Rrure Porte Gauche / Door Lock Lh
Se Rrure De Portiere Droite / Door Lock Rh
To It Interne / Inner Roof
To It Externe / Outer Roof
Su Pport De Cabine Avant / Cab Bracket Front
Su Pport De Cabine Arriere / Cab Bracket Rear
Ta Pis / Floor Mat
Ta Pis / Floor Mat
Mo Dification Insonore Avant / Sound Absorber Front
Mo Dification Insonore Arriere / Sound Absorber Rear
Ab Ri Interieur / Interior Cover
Gu Ide De Levier G. / Lever Guide Lh
Gu Ide De Levier D. / Lever Guide Rh
Su Pport De Siege / Seat Support
Si Ege (Cobo Sc74/M91) [Excepte Allemand] / Seat (Cobo Sc74/M91) [Except Germany]
Si Ege (Grammer Msg83/8) [Allemand] / Seat (Grammer Ms G83/8) [Germany]
Si Ege (Kab Seating Xh2/P1) [Excepte Allemand] / Seat (Kab Seating Xh2/P1) [Except Germany]
Si Ege (Kab Seating 11/P1) [Excepte Allemand] / Seat ( Kab Seating 11/P1) [Except Germany]
Si Ege (Sears Mcs3000) [Excepte Allemand] / Seat (Sear S Mcs3000) [Except Germany]
Gl Ace Avant / Front Glass
Gl Ace Lateral / Side Glass
Gl Ace De Arriere / Hatch Back Glass
Pe Nture De Glace Arriere / Hatch Back Glass Hinge
Re Troviseur / Rearview Mirror
Air Conditionneur / Air Condit Ioner
Cable De Air Conditionneur / A Ir Conditioner Cable
Tuyau De Drainage (Air Conditi Onneur) / Drain Hose (Air Conditioner)
Condensateur / Condenser
Tuyau De Air Conditionneur / A Ir Conditioner Pipe
Tuyau De Chauffage / Heater Ho Se
Compresseur / Compressor
Conduit De Climatiseur / Air-C Onditioner Duct
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6.00-1 2)
Roue Avant (22*8,50-12) / Front Wheel (22* 8.50-12)
Roue Avant (24*8,50-12) / Front Wheel (24* 8.50-12)
Roue Avant (6-12b) / Front Wheel (6-12b)
Roue Arriere (9,5-16) / Rear Wheel (9.5-1 6)
Roue Arriere (9,5-18) / Rear Wheel (9.5-1 8)
Roue Arriere (31*13,5-15) / Rear Wheel (3 1*13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel (3 15/75d-15)
Roue Arriere (8-16) / Rear Wheel (8-16)
Etiquette (Avant) [Excepte Italien] / Label (F Ront) [Except Italian]
Etiquette (Avant) [Italien] / Label (Front) [I Talian]
Etiquette (Arriere) [Anglais] [Francais] / Lab El (Rear) [English] [French]
Etiquette (Arriere) [Allemand] [Espagnol] / La Bel (Rear) [German] [Spanish]
Etiquette (Arriere) [Italien] / Label (Rear) [ Italian]
A Ccessories Et Piece De Service / Accessories And Se Rvice Parts
Alternateur [Option] / Alternator Kit [Option]
Alternateur [Parties Composantes] [Option] / Alter Nator [Component Parts] [Option]
Essuie-Glace [Option] / Rear Wiper Kit [Option]
Cd-Radio [Uk] [Option] / Cd-Radio Kit [Uk] [Option ]
Pdf Ventrale (Pour Rck54/Rck60-25b-Eu-F Tonduse) [ Option] / Mid Pto Kit (For Rck54/Rck60-25b-Eu-F Mow Er) [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower L Ift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Opt Ion]
