Kubota Tractor B2230D Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2230D Tractor
Number of Pages: 352 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / Fu El Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur [Parties Composantes] / Nozzle Hold Er [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Composa Ntes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water Pi Pe
Radiateur / Radiator # # No.S.<=30513 S.No.;<=30513 / S.No.<=30513 S.No.;< =30513
Radiateur / Radiator # # No.S.>=30514 S.No.;>=30514 / S.No.>=30514 S.No.;> =30514
Reservoir Du Radiateur / Reserve Tank
Contact A Huile Thermometre / Oil Switch And Thermo Sensor
Solenoide D'arret / Stop So Lenoid
Alternateur Complet / Alter Nator
Alternateur [Parties Compos Antes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composan Tes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Relais / Relay
Tableau De Bord / Panel Boa Rd
Tableau De Bord (Pieces Com Posantes) / Panel Board [Component Parts]
Tableau De Commutateur / Pa Nel Switch
Phare [Uk] / Head Light [Uk ]
Phare [Ec] / Head Light [Ec ]
Feux De Combinaison Avant / Front Combination Lamp
Feux De Combinaison Arriere / Rear Combination Lamp
Lamp Et Plaque D'immatricul Ation [Uk] / License Lamp [Uk]
Lamp Et Plaque D'immatricul Ation [Ec] / License Lamp [Ec]
Faisceau Electrique / Elect Rical Wiring
Embrayage / Clutch
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedala D'embrayage / Clutch Pedal
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differential
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Essieu Avavt Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement (Avant) / Drive Sha Ft (Front)
Arbre De Entrainement (Arriere) / Drive S Haft (Rear)
Carter De Transmission / Transmission C Ase
Couvercle De Carter De Transmission / T Ransmission Case Cover
Carter De Differentiel / Differential G Ear Case
Carter De Pont Arriere G. / Rear Axle C Ase Lh
Carter De Pont Arriere D. / Rear Axle C Ase Rh
Arbre De Embrayage / Clutch Shaft
Arbre Principal De Changement / Main Ge Ar Shaft
Arbre De Changement De Gamme / Range Ge Ar Shaft
Arbre De Marche Arriere 1 / Reverse Sha Ft 1
Arbre De Marche Arriere 2 / Reverse Sha Ft 2
Arbre Primaire De Pdf / Pto Drive Shaft
Arbre De Pdf Changement / Pto Gear Shif T Shaft
Pdf Ventrale / Mid Pto
Changement De Gamme / Range Gear
Differentiel Arriere / Rear Differentia L
Fourchette De Changement De Vit Esses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shuttl E Shift Fork
Tige De Inverseur / Shuttle Shi Ft Rod
Fourchette De Changement De Gam Me / Range Gear Shift Fork
Fourchette De Chengement De Vit Esse Pdf / Pto Gear Shift Fork
Bras De Chengement De Vitesse P Df / Pto Gear Shift Arm
Fourchette De Blocage Different Iel / Differential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Fr Ein Gauche / Brake Lh
Fr Ein Droite / Brake Rh
Ti Ge De Frein / Brake Rod
Le Vier De Frein De Stationnement / Parking Brake Leve R
Levier De Changement De Vitesses Pri Ncipal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift L Ever
Levier De Changement De Gamme / Rang E Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf / Pto Gear Shift Lever
Levier De Position / Position Contro L Lever
Levier De Distributeur Auxiliaire / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Differenti El / Differential Lock Pedal
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direction / Steering Cylinder
Support Avant Droit / H Ydraulic Pump
Pompe Hydraulique [Part Ies Composantes] / Hydraulic Pump [Component Parts]
Circuit D'huile Hydraul Ique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraul Ique (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydraul Ique (Direction) / Hydraulic Oil Line (Steering)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bras De Relevage / Hydraulic Piston/Lift Arm
Levier De Controle De P Osition / Feed Back Lever
Distributeur Hydrauliqu E / Control Valve
Distributeur [Parties C Omposantes] / Control Valve [Component Parts]
Controle Des Valves Aux Iliaire / Remote Control Valve
Controle Des Valves Aux . [Parties Composantes] / Remote Control Valve [Com Ponent Parts]
Tombent Ajustement Arbr E / Fall Adjustment Shaft
Soupape De Surete / Rel Ief Valve
Barre De Relevage / Lif T Rod
Tirant Inferieur / Lower Link
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Attelage / Front Hitch
Attelage Arriere / Rear Hitch
Protection Pdf / Pto Protector
Avertisseur De Recul / Bonnet (Hood)
Capot Lateral / Side Cover
Retroviseur [Uk] / Rearview Mirror [Uk]
Retroviseur [Ec] / Rearview Mirror [Ec]
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Aile / Fender
Plancher / Floor Sheet
Siege (Cobo Sc74/M91) [Excepte Allemand] / Seat (Cobo Sc74/M91) [Except Germany]
Siege (Grammer Msg83/8) [Allemand] / Seat (Gram Mer Msg83/8) [Germany]
Siege (Kab Seating Xh2/P1) [Excepte Allemand] / Seat (Kab Seating Xh2/P1) [Except Germany]
Siege (Kab Seating 11/P1) [Excepte Allemand] / Seat (Kab Seating 11/P1) [Except Germany]
Siege (Sears Mcs3000) [Excepte Allemand] / Seat (Sears Mcs3000) [Except Germany]
Marchepied / Step
Marchepied / Step
Couvercle Arriere / Tail Cover
Cadre Anti-Renversement / Rops
Roue Avant (6-12b) / Front Wheel (6-12b)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6.00-12 )
Roue Avant (22*8,50-12) / Front Wheel (22*8 .50-12)
Roue Avant (24*8,50-12) / Front Wheel (24*8 .50-12)
Roue Arriere (8-16) / Rear Wheel (8-16)
Roue Arriere (9,5-16) / Rear Wheel (9.5-16 )
Roue Arriere (9,5-18) / Rear Wheel (9.5-18 )
Roue Arriere (31*13,5-15) / Rear Wheel (31 *13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel (31 5/75d-15)
Etiquette (Avant) [Excepte Italien] / Label (Fr Ont) [Except Italian]
Etiquette (Avant) [Italien] / Label (Front) [It Alian]
Etiquette (Arriere) [Anglais] [Francais] / Labe L (Rear) [English] [French]
Etiquette (Arriere) [Allemand] [Espagnol] / Lab El (Rear) [German] [Spanish]
Etiquette (Arriere) [Italien] / Label (Rear) [I Talian]
Ac Cessories Et Piece De Service / Accessories And Ser Vice Parts
Support Du Clignotant Avant [Option] / Front Winker Stay Kit [Option]
Eclairage De Travail [Option] / Working Light Kit [ Option]
Pdf Ventrale (Pour Rck54/Rck60-25b-Eu-F Tondeuse) [ Option] / Mid Pto Kit (For Rck54/Rck60-25b-Eu-F Mow Er) [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower Li Ft Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Opti On]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Batterie / Battery
Batterie / Battery
Relais / Relay
Relais / Relay
Embrayage / Clutch
Embrayage / Clutch
Aile / Fender
Aile / Fender
Marchepied / Step
Marchepied / Step
