Kubota Tractor B2201D Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B2201D Tractor
Number of Pages: 243 Pages
Articles Fréq Uemment Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Filtre D'huile / Oil Filter
Volant / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / Fu El Camshaft And Governor Shaft
Plaque De Vitesse-Controle / Speed Control Plate
Porte-Buse Et Bougie De Préchauffage / Nozzle Holde R And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Hold Er [Component Parts]
Bride D'eau Et Thermostat / Water Flange And Thermo Stat
Pompe À Eau / Water Pump
Vanne Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Jeu De Joints Supérieur / Upper Gasket Kit
Jeu De Joints Inférieur / Lower Gasket Kit
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Composa Ntes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pi Pe
Radiateur / Radiator
Reservoir Du Padiateur / Reserve Tank
Contact A Huile Thermometre / Oil Switch And Thermo Sensor
Solenoide D'arret / Stop So Lenoid
Alternateur [Type Cadre Ant I-Renv. D'arriere] / Alternator [Rear Rops Type]
Alternateur [Paries Composa Ntes] [Type Cadre Anti-Renv. D'arriere] / Alternato R [Component Parts] [Rear Rops Type]
Alternateur [Paries Composa Ntes] [Type Cadre Anti-Renv. D'ventrale] / Alternat Or [Component Parts] [Mid Rops Type]
Demarreur / Starter
Demarreur [Parties Composan Tes] / Starter [Component Parts]
Batterie / Battery
Commutateur [Type Cadre Ant I-Renv. D'arriere] / Switch [Rear Rops Type]
Commutateur [Type Cadre Ant I-Renv. D'ventrale] / Switch [Mid Rops Type]
Relais / Relay
Panneau De Bord / Panel Boa Rd
Tableau De Bord [Parties Co Mposantes] / Panel Board [Component Parts]
Tableau De Commutateur / Pa Nel Switch
Phare Avant [Excepte Uk] / Head Light [Except Uk]
Feux De Combinaison Avant [ Type Cadre Anti-Renv. D'arriere] / Front Combinatio N Lamp [Rear Rops Type]
Feux De Combinaison Avant [ Type Cadre Anti-Renv. D'ventrale] / Front Combinati On Lamp [Mid Rops Type]
Lampe Plaque Immatriculatio N [Type Cadre Anti-Renv. D'arriere] / License Lamp [Rear Rops Type]
Lampe Plaque Immatriculatio N [Type Cadre Anti-Renv. D'ventrale] / License Lamp [Mid Rops Type]
Faisceau Electrique (Corps) [Type Cadre Anti-Renv. D'arriere] / Electrical Wir Ing (Body) [Rear Rops Type]
Faisceau Electrique (Corps) [Type Cadre Anti-Renv. D'ventrale] / Electrical Wi Ring (Body) [Mid Rops Type]
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Chassis Centre / Center Frame
Chassis Second / Sub Frame
Differentiel Avant / Front Differential
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Axle Case Lh
Carter Reducteur Droite / Axle Case Rh
Essieu Avant Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre D'entrainement De Roue Avant / Fron T Wheel Drive Shaft
Carter De Transmission [Type Cadre Anti -Renv. D'arriere] / Transmission Case [Rear Rops Ty Pe]
Carter De Transmission [Type Cadre Anti -Renv. D'ventrale] / Transmission Case [Mid Rops Ty Pe]
Carter De Differentiel / Differential G Ear Case
Carter De Pont Arriere G. [Type Cadre A Nti-Renv. D'arriere] / Rear Axle Case Lh [Rear Rops Type]
Carter De Pont Arriere G. [Type Cadre A Nti-Renv. D'ventrale] / Rear Axle Case Lh [Mid Rops Type]
Carter De Pont Arriere D. [Type Cadre A Nti-Renv. D'arriere] / Rear Axle Case Rh [Rear Rops Type]
Carter De Pont Arriere D. [Type Cadre A Nti-Renv. D'ventrale] / Rear Axle Case Rh [Mid Rops Type]
Arbre De Embrayage / Clutch Shaft
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre Principal De Changement / Main Ge Ar Shaft
Arbre De Changement De Gamme [Type Cadr E Anti-Renv. D'arriere] / Range Gear Shaft [Rear Ro Ps Type]
Arbre De Changement De Gamme [Type Cadr E Anti-Renv. D'ventrale] / Range Gear Shaft [Mid Ro Ps Type]
Arbre De Marche Arriere 1 / Reverse Sha Ft 1
Arbre De Marche Arriere 2 [Type Cadre A Nti-Renv. D'arriere] / Reverse Shaft 2 [Rear Rops T Ype]
Arbre De Marche Arriere 2 [Type Cadre A Nti-Renv. D'ventrale] / Reverse Shaft 2 [Mid Rops T Ype]
Arbre Primaire De Pdf [Type Cadre Anti- Renv. D'arriere] / Pto Drive Shaft [Rear Rops Type]
Arbre Primaire De Pdf [Type Cadre Anti- Renv. D'ventrale] / Pto Drive Shaft [Mid Rops Type]
Arbre De Pdf Changement [Type Cadre Ant I-Renv. D'arriere] / Pto Gear Shift Shaft [Rear Rop S Type]
Arbre De Pdf Changement [Type Cadre Ant I-Renv. D'ventrale] / Pto Gear Shift Shaft [Mid Rop S Type]
Pdf Ventrale [Type Cadre Anti-Renv. D'a Rriere] / Mid Pto [Rear Rops Type]
Changement De Gamme / Bevel Gear Shaft
Differentiel Arriere / Rear Differentia L
Fourchette De Changement De Vit Esses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shuttl E Shift Fork
Tige De Inverseur / Shuttle Shi Ft Rod
Fourchette De Changement De Gam Me / Range Gear Shift Fork
Fourchette De Chengement De Vit Esse Pdf / Pto Gear Shift Fork
Bras De Chengement De Vitesse P Df [Type Cadre Anti-Renv. D'arriere] / Pto Gear Shi Ft Arm [Rear Rops Type]
Fourchette De Blocage Different Iel / Differential Lock Shift Fork
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Fr Ein Gauche / Brake Lh
Fr Ein Droite / Brake Rh
Ti Ge De Frein / Brake Rod
Le Vier De Frein De Stationnement / Parking Brake Leve R
Tige De Changement De Vitesses Princ Ipal / Main Gear Shift Rod
Levier De Changement De Gamme / Rang E Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'arriere] / Pto Gear Shift Lever [Rear Rops Type]
Levier De Chengement De Vitesse Pdf [Type Cadre Anti-Renv. D'ventrale] / Pto Gear Shift Lever [Mid Rops Type]
Levier Du Controle De Position / Pos Ition Control Lever
Levier De Distributeur Auxiliaire / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Differenti El / Differential Lock Pedal
Colonne De Direction / Steering Column
Pompe Hydraulique / Hyd Raulic Pump
Pompe Hydraulique [Part Ies Composantes] / Hydraulic Pump [Component Parts]
Circuit D'huile Hydraul Ique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydraul Ique (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hydraul Ique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydraul Ique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bras De Relevage / Hydraulic Piston/Lift Arm
Levier De Revenue / Fee D Back Lever
Distributeur Controle / Control Valve
Distributeur [Parties C Omposantes] / Control Valve [Component Parts]
Valve Auxiliaire / Auxi Liary Control Valve
Controle Des Valves Aux .[Parties Composantes] / Remote Control Valve [Comp Onent Parts]
Tombent Ajustement Arbr E / Fall Adjustment Shaft
Soupape De Surete / Rel Ief Valve
Bras Inferieur [Type Cadre Anti-Renv. D'arriere] / Link,Lower [Rear Rops Type]
Bras Inferieur [Type Cadre Anti-Renv. D'ventrale] / Lower Link [Mid Rops Type]
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Attelage Arriere [Type Cadre Anti-Renv. D'arriere ] / Rear Hitch [Rear Rops Type]
Attelage Arriere [Type Cadre Anti-Renv. D'ventral E] / Rear Hitch [Mid Rops Type]
Calandre Avant / Front Grille
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. [Type Cadre Anti-Renv. D'arr Iere] / Lever Guide Lh [Rear Rops Type]
Guide De Levier G. [Type Cadre Anti-Renv. D'ven Trale] / Lever Guide Lh [Mid Rops Type]
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Siege (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Siege (Grammer Msg93/511) / Seat (Grammer Msg93 /511)
Siege (Sears 807) / Seat (Sears 807)
Marchepied / Step
Couvercle Arriere / Tail Cover
Boite Dutils / Tool Box
Couvercle Arriere [Type Cadre Anti-Renv. D'arri Ere] / Rear Cover [Rear Rops Type]
Couvercle Arriere [Type Cadre Anti-Renv. D'vent Rale] / Rear Cover [Mid Rops Type]
Cadre Anti-Renversement 1 (Ventrale) / Rops 1 ( Mid)
Cadre Anti-Renversement 2 (Arriere) [Type Cadre Anti-Renv. D'arriere] / Rops 2 (Rear) [Rear Rops T Ype]
Cadre Anti-Renversement 2 (Arriere) [Type Cadre Anti-Renv. D'ventrale] / Rops 2 (Rear) [Mid Rops T Ype]
Roue Avant (5-12) / Front Wheel (5-12)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (6,00-12) / Front Wheel (6.00-1 2)
Roue Avant (22*8,50-12) / Front Wheel (22* 8.50-12)
Roue Avant (24*8,50-12) / Front Wheel (24* 8.50-12)
Roue Arriere (8-16) / Rear Wheel (8-16)
Roue Arriere (9,5-16) / Rear Wheel (9.5-1 6)
Roue Arriere (9,5-18) / Rear Wheel (9.5-1 8)
Roue Arriere (31*13,5-15) / Rear Wheel (3 1*13.5-15)
Roue Arriere (315/75d-15) / Rear Wheel (3 15/75d-15)
Etiquette (Avant) [Type Cadre Anti-Renv. D'arri Ere] / Label (Front) [Rear Rops Type]
Etiquette (Avant) [Type Cadre Anti-Renv. D'vent Rale] / Label (Front) [Mid Rops Type]
Etiquette (Arriere) [Type Cadre Anti-Renv. D'ar Riere] / Label (Rear) [Rear Rops Type]
Etiquette (Arriere) [Type Cadre Anti-Renv. D've Ntrale] / Label (Rear) [Mid Rops Type]
Ac Cessoires Et Pieces De Service / Accessories And Se Rvice Parts
Chargeur Frontal Controle De La Valve Avant (Valve) [Option] / Front Loader Control Valve Kit (Valve) [Option]
Chargeur Frontal Controle De La Valve Avant [Partie S Composantes] [Option] / Front Loader Control Valv E Kit [Component Parts] [Option]
Chargeur Frontal Controle De La Valve Avant (Levier ) [Option] / Front Loader Control Valve Kit (Lever) [Option]
Chargeur Frontal Controle De La Valve Avant (Bielle Te) [Option] / Front Loader Control Valve Kit (Link ) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuyau 1) [Option] / Front Loader Control Valve Kit (Pipe 1) [Option]
Chargeur Frontal Controle De La Valve Avant (Tuyau 2) [Option] / Front Loader Control Valve Kit (Pipe 2) [Option]
Eclairage De Travail [Type Cadre Anti-Renv. D'arrie Re] [Option] / Working Light Kit [Rear Rops Type] [ Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower Li Ft Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Opti On]
Equipement Du Debouche Hydraulique Avant [Option] / Front Hydraulic Outlet Kit [Option]
