Kubota Tractor B2110HDB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B2110HDB Tractor
Number of Pages: 409 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Caja De Cambios Ppal / Main Bearing Case
Volante / Flywheel
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Agua Bomba / Water Pump
Valvulas Y Balancines / Valve And Rocker Arm
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Combustible Tubo / Fuel Pipe
Filtro De Combustible [Componentes] / Fuel Filter [Component Parts]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Alternador [Componentes] / Alternator [Component Parts]
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Conmutador / Switch
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz/Cola Lampara / Head Light/Tail Lamp
Instalacion Electrica / Electrical Wiring
Embrague / Clutch
Embrague Varilla / Clutch Rod
Pedal Embrague / Clutch Pedal
Trasero Eje Caja / Rear Axle Case
Embrague Eje / Clutch Shaft
Hst
Hst[Componente Piezas]1 / Hst [Component Parts] 1
Hst[Componente Piezas]2 / Hst [Component Parts] 2
Hst[Componente Piezas]3 / Hst [Component Parts] 3
Adelante Eje / Front Shaft
Pto Eje / Pto Shaft
Tdf Intermedia / Mid Pto
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Eje De Cuarto Adelante / 4th Shaft
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Velocidad Juego Palanca / Speed Set Lever
Punto Muerto Soporte Vinculo / Neutral Holder Link
Velocidad Control Pedal / Speed Control Pedal
Bi-Velocidad Girar Palanca / Bi-Speed Turn Lever
Eje Trasero / Rear Axle
Freno / Brake
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Alejado Control Palanca / Remote Control Lever
Hidraulico Control Palanca / Hydraulic Control Lever
Bomba Hidraulica [Componentes] / Hydraulic Pump [Component Parts]
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line(Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line(Delivery)
Hidraulico Aceite Linea(Direccion) / Hydraulic Oil Line(Steering)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line (Hst)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea(F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Palanca Alimentacion Trasera / Feed Back Lever
Distribuidor / Control Valve
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula[Componente Piezas] / Remote Control Valve [Component Parts]
Diferencial Eje Del Engranaje / Differential Gear Shaft
Bi-Velocidad Girar Embrague / Bi-Speed Turn Clutch
Adelante Accionar Eje / Front Drive Shaft
Bi-Velocidad Girar Engranaje Caja / Bi-Speed Turn Gear Case
Bi-Velocidad Girar Caja / Bi-Speed Turn Case
Bi-Velocidad Girar Cambio Palanca / Bi-Speed Turn Shift Lever
Mangueta Brazo / Knuckle Arm
Arrastre Vinculo / Drag Link
Atar Varilla / Tie Rod
Maneta Direccion / Steering Handle
Direccion Poste / Steering Post
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump(Ps)
Hidraulico Bomba(Potencia Direccion)[Componente Piezas] / Hydraulic Pump(Ps) [Component Parts]
Varillaje 2 Tercer Punto (Tirante) / 3-Point Linkage 2(Lift Rod)
Bajar Vinculo / Lower Link
3-Punto Varillaje 1(Parte Superior Vinculo) / 3-Point Linkage 1(Top Link)
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Parrilla Frontal / Front Grille
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Espejo Retrovisor[Fr][G] / Rearview Mirror [Fr] [G]
Espejo Retrovisor[Uk] / Rearview Mirror [Uk]
Palanca Guia / Lever Guide
Guardabarros / Fender
Extension Guardabarros / Extension Fender
Guardabarros Soporte / Fender Stay
Hoja De Piso / Floor Sheet
Asiento[Fr][Uk] / Seat [Fr] [Uk]
Asiento[G] / Seat [G]
Peldano / Step
Arco De Seguridad / Rops
Rueda Delantera(6-12b) / Front Wheel (6-12b)
Rueda Delantera(6-12) / Front Wheel (6-12)
Rueda Delantera(6,00-12) / Front Wheel (6.00-12)
Rueda Delantera(22*8.50-12) / Front Wheel (22*8.50-12)
Rueda Delantera(24*8.50-12) / Front Wheel (24*8.50-12)
Rueda Trasera(8-16) / Rear Wheel (8-16)
Rueda Trasera(9.5-16) / Rear Wheel (9.5-16)
Rueda Trasera(9.5-18) / Rear Wheel (9.5-18)
Rueda Trasera(31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (31*13,5-15) / Rear Wheel (3.15/75d-15)
Etiqueta[Frances] / Label [French]
Etiqueta / Label [German]
Etiqueta[Ingles] / Label [English]
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Potencia Direccion Manguito Kit[Opcion] / Power Steering Hose Kit [Option]
Adelante Pto[Opcion] / Front Pto [Option]
Cortacespedes Ascenso Cilindro(Ascenso Brazo)[Opcion] / Mower Lift Cylinder Kit [Option]
