Hyundai
86
176,834
Kubota Tractor B2110HDB B2410HDB Parts Catalog
Model: Kubota B2110HDB B2410HDB Tractor
Update: 2020
Number of Pages: 409 Pages
B2110HDB
FREQUENTLY USED ITEMS / FREQUENTLY USED ITEMS
000000 REFERENCIAS MAS FRECUENTES / FREQUENTLY USED ITEMS
MOTOR / ENGINE
000101 BLOQUE MOTOR / CRANKCASE ## No. DE SERIE<=3K1851 [NOTE:ORDER BY Fig.No.000102-010 NEW PART and Fig.No.0007-030] / S.No.<=3K1851 [NOTE:ORDER BY Fig.No.000102-010 NEW PART and Fig.No.0007-030]
000102 BLOQUE MOTOR / CRANKCASE ## No. DE SERIE>=3L0001 [NOTE:ORDER BY REF.No.010 NEW PART and Fig.No.0007 REF.No.030] / S.No.>=3L0001 [NOTE:ORDER BY REF.No.010 NEW PART and Fig.No.0007 REF.No.030]
000200 ACEITE CACEROLA / OIL PAN
000300 CILINDRO CULATA / CYLINDER HEAD
000400 CAJA DE CAMBIO / GEAR CASE ## NOTE:ORDER BY REF.No.010(16252-0402-0) and Fig.No.0501 REF.No.010,060 NEW PART. / NOTE:ORDER BY REF.No.010(16252-0402-0) and Fig.No.0501 REF.No.010,060 NEW PART.
000500 CULATA CUBIERTA / HEAD COVER
000600 ACEITE FILTRO / OIL FILTER
000700 VARILLA DE NIVBL Y GUIA / DIPSTICK AND GUIDE
010000 CAJA DE CAMBIOS PPAL / MAIN BEARING CASE
010100 ARBOL DE LEVAS Y PUNTO MUERTO ENGRANAJE EJE / CAMSHAFT AND IDLE GEAR SHAFT
010200 PISTON Y CIGUEENAL / PISTON AND CRANKSHAFT ## NOTE:ORDER BY REF.No.010 and 020 NEW PART. / NOTE:ORDER BY REF.No.010 and 020 NEW PART.
010300 VOLANTE / FLYWHEEL
010500 COMBUSTIBLE ARBOL DE LEVAS Y REGULADOR EJE / FUEL CAMSHAFT AND GOVERNOR SHAFT
020000 PUNTO MUERTO APARATO / IDLE APPARATUS
020200 INJECTION PUMP / INJECTION PUMP
020401 REGULADOR / GOVERNOR ## No. DE SERIE<=3Y0886 S.No.;<=3Y0886 / S.No.<=3Y0886 S.No.;<=3Y0886
020402 REGULADOR / GOVERNOR ## No. DE SERIE>=4A0001 S.No.;>=4A0001 / S.No.>=4A0001 S.No.;>=4A0001
020500 PLACA CONTROL DE VELOCIDAD / SPEED CONTROL PLATE
020600 INYECTOR Y BUJIA PRECALENT. / NOZZLE HOLDER AND GLOW PLUG
020700 PORTAINYECTOR [COMPONENTES] / NOZZLE HOLDER [COMPONENT PARTS]
030100 COMBUSTIBLE BOMBA(MECANICO) / FUEL PUMP(MECHANICAL)
050000 AGUA BRIDA Y TERMOSTATO / WATER FLANGE AND THERMOSTAT
050100 AGUA BOMBA / WATER PUMP
060000 VALVULAS Y BALANCINES / VALVE AND ROCKER ARM
060100 COLECTOR DE ADMISION / INLET MANIFOLD
060200 ESCAPE COLECTOR / EXHAUST MANIFOLD
060300 AIRE LIMPIADOR / AIR CLEANER
060500 SILENCIADOR / MUFFLER
090000 SUPERIOR JUNTA KIT [OPCION] / UPPER GASKET KIT [OPTION]
090100 BAJAR JUNTA KIT [OPCION] / LOWER GASKET KIT [OPTION]
A00100 PALANCA ACELERADOR / ACCELERATOR LEVER
COMBUSTIBLE SISTEMA / FUEL SYSTEM
A10100 DEPOSITO COMBUSTIBLE / FUEL TANK ## NOTE:ORDER BY REF.No.010 NEW PART and REF.No.070 and Fig.No.A11002 REF.No.220,270,300(K3511-5839-0). / NOTE:ORDER BY REF.No.010 NEW PART and REF.No.070 and Fig.No.A11002 REF.No.220,270,300(K3511-5839-0).
A11001 COMBUSTIBLE TUBO / FUEL PIPE ## No. DE SERIE<=80090 S.No.;<=80090 / S.No.<=80090 S.No.;<=80090
A11002 COMBUSTIBLE TUBO / FUEL PIPE ## No. DE SERIE>=80091 S.No.;>=80091 / S.No.>=80091 S.No.;>=80091
A13000 FILTRO DE COMBUSTIBLE [COMPONENTES] / FUEL FILTER [COMPONENT PARTS]
REFRIGERACION AGUA SISTEMA / COOLING WATER SYSTEM
A40100 VENTILADOR / FAN
A41000 AGUA TUBO / WATER PIPE
A42000 RADIADOR / RADIATOR
A43000 DEPOSITO DE RESERVA / RESERVE TANK
ELECTRICO SISTEMA / ELECTRICAL SYSTEM
A51000 PARAR SOLENOIDE / STOP SOLENOID
A51500 ALTERNADOR / ALTERNATOR
A52000 ALTERNADOR [COMPONENTES] / ALTERNATOR [COMPONENT PARTS]
A52500 MOTOR DE ARRANQUE / STARTER
A53000 MOTOR DE ARRANQUE [COMPONENTES] / STARTER [COMPONENT PARTS]
A53500 BATERIA / BATTERY
B10100 CONMUTADOR / SWITCH
B11500 TABLERO DE INSTRUMENTOS / PANEL BOARD
B12000 TABLERO DE INSTRUMENTOS [COMPONENTES] / PANEL BOARD [COMPONENT PARTS]
B30100 CULATA LUZ/COLA LAMPARA / HEAD LIGHT/TAIL LAMP
B50100 INSTALACION ELECTRICA / ELECTRICAL WIRING
EMBRAGUE / CLUTCH
C10100 EMBRAGUE / CLUTCH
C11000 EMBRAGUE VARILLA / CLUTCH ROD
C30100 PEDAL EMBRAGUE / CLUTCH PEDAL
C40100 EMBRAGUE CARCASA / CLUTCH HOUSING
C41500 CENTRO BASTIDOR / CENTER FRAME
TRANSMISION / TRANSMISSION
C42000 CAJATRANSMISION / TRANSMISSION CASE
C42500 DIFERENCIAL ENGRANAJE CAJA / DIFFERENTIAL GEAR CASE
C42700 TRASERO EJE CAJA / REAR AXLE CASE
D00100 EMBRAGUE EJE / CLUTCH SHAFT
D00500 EJE PROPULSOR / PROPELLER SHAFT
D01000 HST / HST
D01600 HST[COMPONENTE PIEZAS]1 / HST [COMPONENT PARTS] 1
D01700 HST[COMPONENTE PIEZAS]2 / HST [COMPONENT PARTS] 2
D01800 HST[COMPONENTE PIEZAS]3 / HST [COMPONENT PARTS] 3
D10300 ADELANTE EJE / FRONT SHAFT
D13500 PTO EJE / PTO SHAFT
D13700 TDF INTERMEDIA / MID PTO
D14000 DIFERENCIAL TRASERO / REAR DIFFERENTIAL
D14300 ADELANTE RUEDA HELICE EJE / FRONT WHEEL PROPELLER SHAFT
D14900 SEGUNDO EJE / 2ND SHAFT
D15200 TERCERO EJE / 3RD SHAFT
D15500 EJE DE CUARTO ADELANTE / 4TH SHAFT
VELOCIDAD CAMBIO / SPEED CHANGE
D21700 GAMA ENGRANAJE CAMBIO BIFURCACION / RANGE GEAR SHIFT FORK
D22000 PTO ENGRANAJE CAMBIO BIFURCACION / PTO GEAR SHIFT FORK
D22500 DIFERENCIAL CERRADURA CAMBIO BIFURCACION / DIFFERENTIAL LOCK SHIFT FORK
F03000 VELOCIDAD JUEGO PALANCA / SPEED SET LEVER
F10700 PUNTO MUERTO SOPORTE VINCULO / NEUTRAL HOLDER LINK
F10800 VELOCIDAD CONTROL PEDAL / SPEED CONTROL PEDAL
F11000 GAMA ENGRANAJE CAMBIO PALANCA / RANGE GEAR SHIFT LEVER
F11300 PALANCA ACCIONAMIENTO RUEDA DELANTERA / FRONT WHEEL DRIVE LEVER
F12500 PALANCA DE CAMBIO DE TDF / PTO GEAR SHIFT LEVER
F13500 BI-VELOCIDAD GIRAR PALANCA / BI-SPEED TURN LEVER
TRASERO AXLE / REAR AXLE
D30100 EJE TRASERO / REAR AXLE
F20500 DIFERENCIAL CERRADURA PEDAL / DIFFERENTIAL LOCK PEDAL
FRENO / BRAKE
E00100 FRENO / BRAKE
E00500 FRENO VARILLA / BRAKE ROD
E01500 ESTACIONAMIENTO FRENO PALANCA / PARKING BRAKE LEVER
F20100 FRENO PEDAL / BRAKE PEDAL
BOMBA/MOTOR SISTEMA / PUMP/MOTOR SYSTEM
F14200 ALEJADO CONTROL PALANCA / REMOTE CONTROL LEVER
F14300 HIDRAULICO CONTROL PALANCA / HYDRAULIC CONTROL LEVER
J12000 HIDRAULICA BOMBA / HYDRAULIC PUMP
J12500 BOMBA HIDRAULICA [COMPONENTES] / HYDRAULIC PUMP [COMPONENT PARTS]
J20100 HIDRAULICO ACEITE LINEA(ASPIRACION) / HYDRAULIC OIL LINE(SUCTION)
J21000 LINEA DE ACEITE HIDRAULICO (IMPULSION) / HYDRAULIC OIL LINE(DELIVERY)
J21500 HIDRAULICO ACEITE LINEA(DIRECCION) / HYDRAULIC OIL LINE(STEERING)
J23500 HIDRAULICO ACEITE LINEA(HST) / HYDRAULIC OIL LINE (HST)
J24000 HIDRAULICO ACEITE LINEA(ACEITE REFRIGERADOR) / HYDRAULIC OIL LINE (OIL COOLER)
J24500 HIDRAULICO ACEITE LINEA(F/M) / HYDRAULIC OIL LINE (F/M)
J30100 CILINDRO HIDRAULICO / HYDRAULIC CYLINDER
J31000 HIDRAULICO PISTON/ASCENSO BRAZO / HYDRAULIC PISTON/LIFT ARM
J33000 PALANCA ALIMENTACION TRASERA / FEED BACK LEVER
J40500 DISTRIBUIDOR / CONTROL VALVE
J41000 CONTROL VALVULA[COMPONENTE PIEZAS] / CONTROL VALVE [COMPONENT PARTS]
J41200 ALEJADO CONTROL VALVULA / REMOTE CONTROL VALVE
J41300 ALEJADO CONTROL VALVULA[COMPONENTE PIEZAS] / REMOTE CONTROL VALVE [COMPONENT PARTS] ## No. DE SERIE>=80614 S.No.;>=80614 / S.No.>=80614 S.No.;>=80614
ADELANTE EJE / FRONT AXLE
G10100 BASTIDOR EJE DELANTERO / FRONT AXLE FRAME
G10500 CARCASA EJE DELANTERO / FRONT AXLE CASE
G11500 DIFERENCIAL DELANTERO / FRONT DIFFERENTIAL
G12000 DIFERENCIAL EJE DEL ENGRANAJE / DIFFERENTIAL GEAR SHAFT
G12300 BISEL ENGRANAJE CAJA / BEVEL GEAR CASE
G12500 CAJA DE EJE DELANTERO / FRONT AXLE CASE
G13000 EJE DELANTERO / FRONT AXLE
G13300 BI-VELOCIDAD GIRAR EMBRAGUE / BI-SPEED TURN CLUTCH
G13500 ADELANTE ACCIONAR EJE / FRONT DRIVE SHAFT
G20100 BI-VELOCIDAD GIRAR ENGRANAJE CAJA / BI-SPEED TURN GEAR CASE
G20500 BI-VELOCIDAD GIRAR CAJA / BI-SPEED TURN CASE
G21000 BI-VELOCIDAD GIRAR CAMBIO PALANCA / BI-SPEED TURN SHIFT LEVER
DIRECCION / STEERING
H00100 MANGUETA BRAZO / KNUCKLE ARM
H00300 ARRASTRE VINCULO / DRAG LINK
H00500 ATAR VARILLA / TIE ROD
H10100 MANETA DIRECCION / STEERING HANDLE
H10500 DIRECCION POSTE / STEERING POST
J10100 HIDRAULICO BOMBA(POTENCIA DIRECCION) / HYDRAULIC PUMP(PS)
J10500 HIDRAULICO BOMBA(POTENCIA DIRECCION)[COMPONENTE PIEZAS] / HYDRAULIC PUMP(PS) [COMPONENT PARTS]
PARTE SUPERIOR/PARTE SUPERIOR VINCULO SOPORTE/PTO PROTECTOR / TOP LINK/TOP LINK BRACKET/PTO PROTECTOR
K10100 VARILLAJE 2 TERCER PUNTO (TIRANTE) / 3-POINT LINKAGE 2(LIFT ROD)
K11500 BAJAR VINCULO / LOWER LINK
K12000 3-PUNTO VARILLAJE 1(PARTE SUPERIOR VINCULO) / 3-POINT LINKAGE 1(TOP LINK)
K12500 COMPROBAR CADENA / CHECK CHAIN
L10500 BARRA DE REMOLQUE / DRAWBAR
L11500 ENGANCHE DELANTERO / FRONT HITCH
L11600 TRASERO ENGANCHE / REAR HITCH
L12500 PTO PROTECTOR / PTO PROTECTOR
CAPO / HOOD/BONNET
M10100 PARRILLA FRONTAL / FRONT GRILLE
M10500 CAPO / BONNET
M11300 PANEL CUBIERTA / PANEL COVER
M12000 LADO CUBIERTA / SIDE COVER
M13000 OBTURADOR PLACA / SHUTTER PLATE
M20501 ESPEJO RETROVISOR[FR][G] / REARVIEW MIRROR [FR] [G]
M20502 ESPEJO RETROVISOR[UK] / REARVIEW MIRROR [UK]
M20700 PALANCA GUIA / LEVER GUIDE
M21000 GUARDABARROS / FENDER
M21100 EXTENSION GUARDABARROS / EXTENSION FENDER
M21200 GUARDABARROS SOPORTE / FENDER STAY
M21500 HOJA DE PISO / FLOOR SHEET
M22001 ASIENTO[FR][UK] / SEAT [FR] [UK]
M22002 ASIENTO[G] / SEAT [G]
M22500 PELDANO / STEP
M30100 ARCO DE SEGURIDAD / ROPS
ADELANTE NEUMATICO / FRONT TIRE
R10101 RUEDA DELANTERA(6-12B) / FRONT WHEEL (6-12B)
R10102 RUEDA DELANTERA(6-12) / FRONT WHEEL (6-12)
R10103 RUEDA DELANTERA(6,00-12) / FRONT WHEEL (6.00-12)
R10104 RUEDA DELANTERA(22*8.50-12) / FRONT WHEEL (22*8.50-12)
R10105 RUEDA DELANTERA(24*8.50-12) / FRONT WHEEL (24*8.50-12)
RUEDA TRASERA (31*13,5-15) / REAR TIRE
R11001 RUEDA TRASERA(8-16) / REAR WHEEL (8-16)
R11002 RUEDA TRASERA(9.5-16) / REAR WHEEL (9.5-16)
R11003 RUEDA TRASERA(9.5-18) / REAR WHEEL (9.5-18)
R11004 RUEDA TRASERA(31*13,5-15) / REAR WHEEL (31*13.5-15)
R11005 RUEDA TRASERA (31*13,5-15) / REAR WHEEL (3.15/75D-15)
ETIQUETA / LABELS
S10101 ETIQUETA[FRANCES] / LABEL [FRENCH]
S10102 ETIQUETA / LABEL [GERMAN]
S10103 ETIQUETA[INGLES] / LABEL [ENGLISH]
ACCESORIOS Y SERVICIO PIEZAS / ACCESSORIES AND SERVICE PARTS
T10500 ACCESORIOS Y SERVICIO PIEZAS / ACCESSORIES AND SERVICE PARTS
OPCION / OPTION
U80501 FUNCIONAMIENTO LUZ KIT[OPCION] / WORKING LIGHT KIT [OPTION] ## No. DE SERIE<=81003 S.No.;<=81003 / S.No.<=81003 S.No.;<=81003
U80502 FUNCIONAMIENTO LUZ KIT[OPCION] / WORKING LIGHT KIT [OPTION] ## No. DE SERIE>=81004 S.No.;>=81004 / S.No.>=81004 S.No.;>=81004
U83600 POTENCIA DIRECCION MANGUITO KIT[OPCION] / POWER STEERING HOSE KIT [OPTION] ## No. DE SERIE<=80288 S.No.;<=80288 / S.No.<=80288 S.No.;<=80288
U83700 ADELANTE PTO[OPCION] / FRONT PTO [OPTION]
U89200 CORTACESPEDES ASCENSO CILINDRO(ASCENSO BRAZO)[OPCION] / MOWER LIFT CYLINDER KIT [OPTION]
