Kubota Tractor B1830DB Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B1830DB Tractor
Number of Pages: 364 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case # # No.S.<=1dhz999 S.No.;<=1dhz999 / S.No.<=1dhz999 S .No.;<=1dhz999
Kit D'accouplements Rapides [Option] / Gear Case # # No.S.>=1dj0001 S.No.;>=1dj0001 / S.No.>=1dj0001 S .No.;>=1dj0001
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Compos Antes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Reservoir Du Radiateu R / Reserve Tank
Contact A Huile Thermometr E / Oil Switch And Thermo Sensor
Solenoide D'arret / Stop S Olenoid
Alternateur Complet / Alte Rnator
Alternateur [Parties Compo Santes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Panel Bo Ard
Tableau De Bord (Pieces Co Mposantes) / Panel Board [Component Parts]
Tableau De Commutateur / P Anel Switch
Phare / Head Light
Phare / Head Light
Feux De Combinaison Avant [Type Rops D'arriere] / Front Combination Lamp [Rea R Rops Type]
Feux De Combinaison Avant [Type Rops D'ventrale] / Front Combination Lamp [Mi D Rops Type]
Feux De Combinaison Arrier E / Rear Combination Lamp
Lamp Et Plaque D'immatricu Lation / License Lamp
Prise De Remorque / Traile R Socket
Faisceau Electrique / Elec Trical Wiring
Embrayage / Clutch
Embrayage / Clutch
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedala D'embrayage / Clutch Pedal
Couvercle De Carter De Embrayage / Clutch Housi Ng Cover
Chassis Second / Sub Frame
Differentiel Avant / Front Differential
Engrenage Conique Gauche / Bevel Gear Lh
Engrenage Conique Droite / Bevel Gear Rh
Carter Engre-Conique / Bevel Gear Case
Carter Reducteur Gauche / Front Axle Cas E Lh
Carter Reducteur Droite / Front Axle Cas E Rh
Essieu Avavt Gauche / Front Axle Lh
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front Driv E Shaft
Couvercle De Carter De Transmission / Transmission Case Cover
Carter De Differentiel / Differential Gear Case
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Propeller Shaf T
Premier Arbre / First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre Principal De Changement / Main G Ear Shaft
Arbre De Changement De Gamme / Range G Ear Shaft
Arbre De Marche Arriere 1 / Reverse Sh Aft 1
Arbre De Marche Arriere 2 / Reverse Sh Aft 2
Arbre Primaire De Pdf / Pto Drive Shaf T
Arbre De Pdf Changement / Pto Gear Shi Ft Shaft
Changement De Gamme / Range Gear
Differentiel Arriere / Rear Differenti Al
Carter De Pont Arriere G. [Type Rops D' Arriere] / Rear Axle Case Lh [Rear Rops Type]
Carter De Pont Arriere G. [Type Rops D' Ventrale] / Rear Axle Case Lh [Mid Rops Type]
Carter De Pont Arriere D. [Type Rops D' Arriere] / Rear Axle Case Rh [Rear Rops Type]
Carter De Pont Arriere D. [Type Rops D' Ventrale] / Rear Axle Case Rh [Mid Rops Type]
Essieu Arriere Gauche / Rear Axle Lh
Essieu Arriere Droite / Rear Axle Rh
Fourchette De Changement De Vi Tesses Principal / Main Gear Shift Fork
Fourchette D'inverseur / Shutt Le Shift Fork
Tige De Inverseur / Shuttle Sh Ift Rod
Fourchette De Changement De Ga Mme / Range Gear Shift Fork
Fourchette De Chengement De Vi Tesse Pdf / Pto Gear Shift Fork
Fourchette De Blocage Differen Tiel / Differential Lock Shift Fork
F Rein Gauche / Brake Lh
F Rein Droite / Brake Rh
T Ige De Frein / Brake Rod
L Evier De Frein De Stationnement / Parking Brake Lev Er
Levier De Changement De Vitesses Pr Incipal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift Lever
Levier De Changement De Gamme / Ran Ge Gear Shift Lever
Levier De Tranission Aux Roues Avan T / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf / Pto Gear Shift Lever
Levier De Position / Position Contr Ol Lever
Levier De Distributeur Auxiliaire / Remote Control Lever
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Different Iel / Differential Lock Pedal
Bras De Demi-Tour Rapide / Bi-Speed Turn Arm
Tige De Virage A 2 Vitesses / Bi-Sp Eed Shift Rod
Arbre De Braquage 2 Vitesses / Bi-Sp Eed Turn Shaft
Colonne De Direction / Steering Post
Barrd De Accouplement/Cylindre De Direction / Steering Cylinder
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrau Lique (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydrau Lique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrau Lique (F/M) / Hydraulic Oil Line (F/M)
Cylindre Hydraulique / Hydraulic Cylinder
Piston Hydraulique/Bra S De Relevage / Hydraulic Piston/Lift Arm
Levier De Controle De Position / Feed Back Lever
Distributeur Hydrauliq Ue / Control Valve
Distributeur [Parties Composantes] / Control Valve [Component Parts]
Controle Des Valves Au Xiliaire / Remote Control Valve
Controle Des Valves Au X. [Parties Composantes] / Remote Control Valve [Co Mponent Parts]
Tombent Ajustement Arb Re / Fall Adjustment Shaft
Soupape De Surete / Re Lief Valve
Barre De Relevage / Li Ft Rod
Tirant Inferieu R / Lower Link
Tirant Superieu R / Top Link
Chaine D'arret / Check Chain
Barre D'attelag E / Drawbar
Attelage / Fron T Hitch
Attelage Arrier E / Rear Hitch
Protection Pdf / Pto Protector
Avertisseur De Recul / Bonnet (Hood)
Capot Lateral / Side Cover
Retroviseur / Rearview Mirror
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Aile / Fender
Aile / Fender
Plancher / Floor Sheet
Siege (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Siege (Kab Seating Xh2/P1) / Seat (Kab Seating Xh2/P1)
Siege (Kab Seating 11/P1) / Seat (Kab Seating 11/P1)
Siege (Sears Mcs3000) / Seat (Sears Mcs3000)
Marchepied / Step
Marchepied / Step
Couvercle Arriere / Tail Cover
Cadre Anti-Renversement [Type Rops D'arriere] / Rops [Rear Rops Type]
Cadre Anti-Renversement 1 (Centre) [Type Rops D'ventrale] / Rops 1 (Center) [Mid Rops Type]
Roue Avant (6-12b) / Front Wheel (6-12b)
Roue Avant (6,00-12) / Front Wheel (6.00-1 2)
Roue Avant (22*8,50-12) / Front Wheel (22* 8.50-12)
Roue Avant (24*8,50-12) / Front Wheel (24* 8.50-12)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Arriere (8-16) / Rear Wheel (8-16)
Roue Arriere (9,5-18) / Rear Wheel (9.5-1 8)
Ventilateur / Fan
Roue Arriere (9,5-16) / Rear Wheel (9.5-1 6)
Etiquette (Avant) [Type Rops D'arriere] [Angla Is] [Espagnol] / Label (Front) [Rear Rops Type] [En Glish] [Spanish]
Etiquette (Avant) [Type Rops D'arriere] [Itali En] / Label (Front) [Rear Rops Type] [Italian]
Etiquette (Avant) [Type Rops D'arriere] / Labe L (Front) [Rear Rops Type]
Etiquette (Avant) [Type Rops D'ventrale] [Angl Ais] [Espagnol] / Label (Front) [Mid Rops Type] [En Glish] [Spanish]
Etiquette (Avant) [Type Rops D'ventrale] [Ital Ien] / Label (Front) [Mid Rops Type] [Italian]
Etiquette (Avant) [Type Rops D'ventrale] / Lab El (Front) [Mid Rops Type]
Etiquette (Arriere) [Type Rops D'arriere] [Ang Lais] / Label (Rear) [Rear Rops Type] [English]
Etiquette (Arriere) [Type Rops D'arriere] [Esp Agnol] / Label (Rear) [Rear Rops Type] [Spanish]
Etiquette (Arriere) [Type Rops D'arriere] [Ita Lien] / Label (Rear) [Rear Rops Type] [Italian]
Etiquette (Arriere) [Type Rops D'ventrale] [An Glais] / Label (Rear) [Mid Rops Type] [English]
Etiquette (Arriere) [Type Rops D'ventrale] [Es Pagnol] / Label (Rear) [Mid Rops Type] [Spanish]
Etiquette (Arriere) [Type Rops D'ventrale] [It Alien] / Label (Rear) [Mid Rops Type] [Italian]
A Ccessories Et Piece De Service / Accessories And Se Rvice Parts
Support Du Clignotant Avant [Option] / Front Winke R Stay Kit [Option]
Eclairage De Travail [Option] / Working Light Kit [Option]
Cylindre De Relevage (Bras De Relevage) [Option] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cylindre De Relevage (Cylindre) [Option] / Mower L Ift Cylinder Kit (Cylinder) [Option]
Contrepoids Avant [Option] / Front Weight Kit [Opt Ion]
Ventilateur / Fan
Ventilateur / Fan
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Batterie / Battery
Relais / Relay
Phare / Head Light
Phare / Head Light
Embrayage / Clutch
Embrayage / Clutch
Embrayage / Clutch
Aile / Fender
Aile / Fender
Aile / Fender
Marchepied / Step
Marchepied / Step
Ventilateur / Fan
