Kubota Tractor B1830DB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1830DB Tractor
Number of Pages: 583 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Adelante Combinacion Luz [Tipo Trasero Rops] / Front Combination Lamp [Rear Rops Type]
Adelante Combinacion Luz [Tipo Intermedia Rops] / Front Combination Lamp [Mid Rops Type]
Licencia Lampara / License Lamp
Embrague / Clutch
Embrague Varilla / Clutch Rod
Embrague Carcasa Cubierta / Clutch Housing Cover
Secundario Bastidor / Sub Frame
Embrague / Clutch
Adelante Eje Iz / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Adelante Accionar Eje / Front Drive Shaft
Embrague Eje / Clutch Shaft
Helice Eje / Propeller Shaft
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Principal Engranaje Eje / Main Gear Shaft
Retroceso Eje 1 / Reverse Shaft 1
Retroceso Eje 2 / Reverse Shaft 2
Inversor Eje / Shuttle Shaft
Pto Accionar Eje / Pto Drive Shaft
Pto Engranaje Cambio Eje / Pto Gear Shift Shaft
Gama Engranaje / Range Gear
Trasero Eje Caja Izquierdo [Tipo Trasero Rops] / Rear Axle Case Lh [Rear Rops Type]
Embrague / Clutch
Trasero Eje Caja Izquierdo [Tipo Intermedia Rops] / Rear Axle Case Lh [Mid Rops Type]
Trasero Eje Caja Derecho [Tipo Trasero Rops] / Rear Axle Case Rh [Rear Rops Type]
Trasero Eje Caja Derecho [Tipo Intermedia Rops] / Rear Axle Case Rh [Mid Rops Type]
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Inversor Cambio Varilla / Shuttle Shift Rod
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Inversor Cambio Palanca / Shuttle Shift Lever
Coloque La Palanca De Mando / Position Control Lever
Alejado Control Palanca / Remote Control Lever
Freno Pedal / Brake Pedal
Bi-Velocidad Girar Brazo / Bi-Speed Turn Arm
Bi-Velocidad Cambio Varilla / Bi-Speed Shift Rod
Eje De Giro Bi-Speed / Bi-Speed Turn Shaft
Direccion Poste / Steering Post
Direccion Cilindro / Steering Cylinder
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet (Hood)
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento (Cobo Sc74/M91) / Seat (Cobo Sc74/M91)
Asiento (Grammer Msg83/8) / Seat (Grammer Msg83/8)
Asiento (Kab Seating Xh2/P1) / Seat (Kab Seating Xh2/P1)
Asiento (Kab Seating 11/P1) / Seat (Kab Seating 11/P1)
Asiento (Sears Mcs3000) / Seat (Sears Mcs3000)
Peldano / Step
Cola Cubierta / Tail Cover
Arco De Seguridad [Tipo Trasero Rops] / Rops [Rear Rops Type]
Rops 1 (Intermedia) [Tipo Intermedia Rops] / Rops 1 (Center) [Mid Rops Type]
Rops 2 (Trasero) [Tipo Intermedia Rops] / Rops 2 (Rear) [Mid Rops Type]
Rueda Delantera (6-12b) / Front Wheel (6-12b)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Etiqueta (Adelante) [Tipo Trasero Rops] [Ingles] [Espanol] / Label (Front) [Rear Rops Type] [English] [Spanish]
Etiqueta (Adelante) [Tipo Trasero Rops] [Italiano] / Label (Front) [Rear Rops Type] [Italian]
Etiqueta (Adelante) [Tipo Trasero Rops] / Label (Front) [Rear Rops Type]
Etiqueta (Adelante) [Tipo Medio Rops] [Ingles] [Espanol] / Label (Front) [Mid Rops Type] [English] [Spanish]
Etiqueta (Adelante) [Tipo Medio Rops] [Italiano] / Label (Front) [Mid Rops Type] [Italian]
Etiqueta (Adelante) [Tipo Medio Rops] / Label (Front) [Mid Rops Type]
Etiqueta (Trasero) [Tipo Trasero Rops] [Ingles] / Label (Rear) [Rear Rops Type] [English]
Etiqueta (Trasero) [Tipo Trasero Rops] [Espanol] / Label (Rear) [Rear Rops Type] [Spanish]
Etiqueta (Trasero) [Tipo Trasero Rops] [Italiano] / Label (Rear) [Rear Rops Type] [Italian]
Etiqueta (Trasero) [Tipo Trasero Rops] / Label (Rear) [Rear Rops Type]
Etiqueta (Trasero) [Tipo Medio Rops] [Ingles] / Label (Rear) [Mid Rops Type] [English]
Volante / Flywheel
Etiqueta (Trasero) [Tipo Medio Rops] [Espanol] / Label (Rear) [Mid Rops Type] [Spanish]
Etiqueta (Trasero) [Tipo Medio Rops] [Italiano] / Label (Rear) [Mid Rops Type] [Italian]
Etiqueta (Trasero) [Tipo Medio Rops] / Label (Rear) [Mid Rops Type]
Rueda Intermitente Soporte [Opcion] / Front Winker Stay Kit [Option]
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Volante / Flywheel
Speed Control Plate
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Embrague / Clutch
Embrague / Clutch
Embrague / Clutch
Pto Protector
Peldano / Step
Volante / Flywheel
