Kubota Tractor B1830D Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1830D Tractor
Number of Pages: 557 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz [Uk] / Head Light [Uk]
Culata Luz [Ec] / Head Light [Ec]
Adelante Combinacion Luz / Front Combination Lamp
Lampara De Matricula [Uk] / License Lamp [Uk]
Lampara De Matricula [Ec] / License Lamp [Ec]
Embrague / Clutch
Embrague Varilla / Clutch Rod
Secundario Bastidor / Sub Frame
Eje Delantero Derecha / Front Axle Rh
Accionar Eje (Adelante) / Drive Shaft (Front)
Accionar Eje (Trasero) / Drive Shaft (Rear)
Helice Eje / Propeller Shaft
Principal Engranaje Eje / Main Gear Shaft
Retroceso Eje 1 / Reverse Shaft 1
Retroceso Eje 2 / Reverse Shaft 2
Inversor Eje / Shuttle Shaft
Pto Accionar Eje / Pto Drive Shaft
Pto Engranaje Cambio Eje / Pto Gear Shift Shaft
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Inversor Cambio Varilla / Shuttle Shift Rod
Pto Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Pto Engranaje Cambio Brazo / Pto Gear Shift Arm
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Inversor Cambio Palanca / Shuttle Shift Lever
Coloque La Palanca De Mando / Position Control Lever
Alejado Control Palanca / Remote Control Lever
Freno Pedal / Brake Pedal
Direccion Poste / Steering Post
Direccion Cilindro / Steering Cylinder
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Piston/Ascenso Brazo / Hydraulic Piston/Lift Arm
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Descarga Valvula / Relief Valve
Ascenso Varilla / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Trasero Enganche / Rear Hitch
Pto Protector
Capo / Bonnet (Hood)
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Espejo Retrovisor [Uk] / Rearview Mirror [Uk]
Espejo Retrovisor [Ec] / Rearview Mirror [Ec]
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Asiento (Cobo Sc74/M91) [Excepto Aleman] / Seat (Cobo Sc74/M91) [Except Germany]
Asiento (Grammer Msg83/8) [Aleman] / Seat (Grammer Msg83/8) [Germany]
Asiento (Kab Seating Xh2/P1) [Excepto Aleman] / Seat (Kab Seating Xh2/P1) [Except Germany]
Asiento (Kab Seating 11/P1) [Excepto Aleman] / Seat (Kab Seating 11/P1) [Except Germany]
Asiento (Sears Mcs3000) [Excepto Aleman] / Seat (Sears Mcs3000) [Except Germany]
Peldano / Step
Cola Cubierta / Tail Cover
Rops
Rueda Delantera (6-12b) / Front Wheel (6-12b)
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (22*8,50-12) / Front Wheel (22*8.50-12)
Rueda Delantera (24*8,50-12) / Front Wheel (24*8.50-12)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (9,5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9,5-18) / Rear Wheel (9.5-18)
Rueda Trasera (31*13,5-15) / Rear Wheel (31*13.5-15)
Rueda Trasera (315/75d-15) / Rear Wheel (315/75d-15)
Etiqueta (Adelante) [Excepto Italiano] / Label (Front) [Except Italian]
Etiqueta (Adelante) [Italiano] / Label (Front) [Italian]
Etiqueta (Trasero) [Ingles] [Frances] / Label (Rear) [English] [French]
Etiqueta (Trasero) [Aleman] [Espanol] / Label (Rear) [German] [Spanish]
Etiqueta(Trasero) [Italiano] / Label (Rear) [Italian]
Etiqueta(Trasero) / Label (Rear)
Rueda Intermitente Soporte [Opcion] / Front Winker Stay Kit [Option]
Kit De Faro De Labor[Opcion] / Working Light Kit [Option]
Intermedia Pto (Por Rck54/Rck60-25b-Eu-F Cortacespedes) [Opcion] / Mid Pto Kit (For Rck54/Rck60-25b-Eu-F Mower) [Option]
Cortacespedes Ascenso Cilindro (Ascenso Brazo) [Opcion] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cortacespedes Ascenso Cilindro (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Adelante Peso [Opcion] / Front Weight Kit [Option]
