7,392
Kubota Tractor B1610 Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota B1610 Tractor
Number of Pages: 399 Pages
Engine 000100 Crank Case
Engine 000200 Oil Pan
Engine 000300 Cylinder Head Cylinder Head
By 16808-04020 Comp.Case Gear,1e051-73030 Assy Pump Water,16871-73430 Gasket Water Pump Note Order
Engine 000500 Head Cover
Engine 000600 Oil Filter Oil Filter
Engine 000700 Dipstick And Guide Dipstick And Guide
Engine 010000 Main Bearing Case Main Bearing Case
Engine 010100 Camshaft And Idle Gear Shaft Camshaft And Idle Gear Shaft
Engine 010202 Piston And Crankshaft
Engine 010300 Flywheel
Engine 010500 Fuel Camshaft And Governor Shaft Fuel Camshaft And Governor
Engine 020000 Idle Apparatus Idle Apparatus
Engine 020200 Injection Pump
Engine 020400 Governor Governor
Engine 020500 Speed Control Plate Speed Control Plate
Engine 020600 Nozzle Holder And Glow Plug Plug
Engine 020701 Nozzle Holder Component Parts Parts S.No.;A 9hz999;B
Engine 020703 Nozzle Holder Component Parts Parts S.No.;B
Engine 030100 Fuel Pump (Mechanical) Fuel Pump (Mechanical)
Engine 050000 Water Flange And Thermostat Thermostat
Engine 050100 Water Pump Water Pump
Engine 060000 Valve And Rocker Arm Valve And Rocker Arm
Engine 060100 Inlet Manifold
Engine 060200 Exhaust Manifold
Engine 060301 Air Cleaner Fr,Uk,G Air Cleaner Fr,Uk,G
Engine 060302 Air Cleaner South Europe,Sp Air Cleaner South Europe,Sp
Engine 060500 Muffler Muffler
Engine A00100 Accelerator Lever
Engine A02000 Accelerator Pedal
Engine A03000 Accelerator Rod Accelerator Rod
Fuel System A10100 Fuel Tank
Fuel System A11000 Fuel Pipe
Fuel System A13000 Fuel Filter Component Parts
Cooling Water System A40100 Fan Fan
Cooling Water System A41000 Water Pipe Water Pipe
Cooling Water System A42000 Radiator Radiator
Cooling Water System A43000 Reserve Tank Reserve Tank
Electrical System A51500 Alternator
Electrical System A52000 Alternator Component Parts
Electrical System A52500 Starter Starter
Electrical System A53000 Starter Component Parts
Electrical System A53500 Battery Battery
Electrical System B10100 Switch Switch
Electrical System B12000 Panel Board Component Parts
Electrical System B30101 Head Light Tail Lamp Except Uk Head Light Tail
Electrical System B30102 Head Light Tail Lamp Uk Head Light Tail
Electrical System B30103 Head Light Tail Lamp Head Light Tail
Electrical System B50100 Electrical Wiring Electrical Wiring
Clutch C10100 Clutch
Clutch C11000 Clutch Rod
Clutch C30100 Clutch Pedal
Clutch C40100 Clutch Housing Clutch Housing
Clutch C41500 Center Frame Center Frame
Transmission C42001 Transmission Case Fr,Uk,G Transmission Case Fr,
Transmission C42002 Transmission Case South Europe,Sp Transmission Case
Transmission C42500 Differential Gear Case Differential Gear Case
Transmission C42700 Rear Axle Case Rear Axle Case
Transmission D00100 Clutch Shaft Output Shaft Clutch Shaft Output
Transmission D00500 Propeller Shaft Propeller Shaft
Transmission D13200 PTO Counter Shaft PTO Drive Shaft PTO Counter Shaft Pto
Transmission D13700 Mid PTO Fr,Uk,G Mid PTO Fr,Uk,G
Rear Differential S.No.;A Fr 71310, Uk 80180, G 60227;B Fr 70809, Uk South Europe 80523, G Sp 60620
Rear Differential S.No.;A Fr 71311, Uk 80181, G 60228;B Fr 70810, Uk South Europe 80524, G Sp 60621
Transmission D14300 Front Wheel Propeller Shaft Front Wheel Propeller
Transmission D14600 Fwd 1st Shaft
Transmission D14900 Fwd 2nd Shaft
Transmission D15200 Fwd 3rd Shaft
Speed Change D20100 Main Gear Shift Fork
Speed Change D21500 Range Gear Shift Fork
D22000 PTO Gear Shift Fork PTO Gear Shift Fork Note Order By Ref.No.020 And Ref.No.060 New Parts Set
Speed Change D22500 Differential Lock Shift Fork Differential Lock Shift
Speed Change F10100 Main Gear Shift Lever
Speed Change F11000 Range Gear Shift Lever
Speed Change F11300 Front Wheel Drive Lever
Speed Change F12500 PTO Gear Shift Lever
Speed Change F14300 Hydraulic Control Lever
Rear Axle D30100 Rear Axle
D31001 Rear Wheel (7-16) Rear Wheel (7-16) Note Order By Ref.No.160 & Ref.No.170 New Parts Set Note
D31002 Rear Wheel (8-16) Rear Wheel (8-16) Note Order By Ref.No.160 & Ref.No.170 New Parts Set Note
Rear Wheel (212 80d-15) Rear Wheel (212 80d-15) Note Order By Ref.No.160 & Ref.No.170 New Parts Set
Rear Axle F20500 Differential Lock Pedal Differential Lock Pedal
Brake Brake E00100 Brake Brake
Brake Brake E00500 Brake Rod
Brake Brake E01500 Parking Brake Lever
Brake Brake F20100 Brake Pedal
Brake Brake F20300 Secondary Brake Pedal G,Sp
Front Axle G00101 Front Wheel (4.50-10) Front Wheel (4.50-10)
Front Axle G00102 Front Wheel (5-12) Front Wheel (5-12)
Front Axle G00103 Front Wheel (20 8.00 10) Front Wheel (20 8.00 10)
Front Axle G10100 Front Axle Frame
Front Axle G10500 Front Axle Case Case
Front Axle G11500 Front Differential Front Differential
Front Axle G12300 Bevel Gear Case Bevel Gear Case
Front Axle G12400 Front Axle
Front Drive Shaft Note Order By Ref.No.010 6c080-5766-5 Ref.No.060 04811-50550 Ref.No.150 09318-89066 Set
Steering H00100 Knuckle Arm Knuckle Arm
Steering H11001 Steering Controller South Europe
Steering H11002 Steering Controller Fr,Uk,G,Sp Steering Controller Fr,
Steering H11501 Steering Controller Component Parts South Europe Steering Controller
Steering H11502 Steering Controller Component Parts Fr,Uk,G,Sp Steering Controller
Pump Motor System J12000 Hydraulic Pump Hydraulic Pump
Pump Motor System J12500 Hydraulic Pump Component Parts Hydraulic Pump
Pump Motor System J20100 Hydraulic Oil Line (Suction) Hydraulic Oil
Pump Motor System J21000 Hydraulic Oil Line (Delivery) Hydraulic Oil
Pump Motor System J30100 Hydraulic Cylinder Hydraulic Cylinder
Parts Except G Hydraulic Valve Component Parts Except G S.No.;A Fr 75452, Uk 80464;B Fr 72476,
Parts Except G Hydraulic Valve Component Parts Except G S.No.;A Fr 75453, Uk 80465;B Fr 72477,
Pump Motor System J31000 Hydraulic Piston Lift Arm Hydraulic Piston
Pump Motor System J40500 Control Valve Control Valve
Control Valve Component Parts S.No.;A Fr 75452, Uk 80464 G 62498;B Fr 72476, Uk South
Control Valve Component Parts S.No.;A Fr 75453, Uk 80465 G 62499;B Fr 72477, Uk South
Top Link Bracket PTO Protector K10100 Lift
Top Link Bracket PTO Protector K11500 Lower
Top Link Bracket PTO Protector K12000 Top
Top Link Bracket PTO Protector K12500 Check
Top Link Bracket PTO Protector L10500 Drawbar
Top Link Bracket PTO Protector L11501
Top Link Bracket PTO Protector L11502 Front
M10100 Front Grille Front Grille Note Order By Ref.No.020,Ref.No.030 & Ref.No.040 New Parts Set Note
Hood Bonnet M10500 Bonnet Bonnet Note Order By Ref.No.020 New Part Note Order
Hood Bonnet M11300 Panel Cover Panel Cover
Hood Bonnet M11500 Side Cover Lower
Hood Bonnet M20500 Rearview Mirror
Hood Bonnet M20700 Lever Guide
Hood Bonnet M21000 Fender Fender
Hood Bonnet M21700 Seat Support Seat
Hood Bonnet M22001 Seat Uk,South Europe
Hood Bonnet M22002 Seat Fr,Sp
Hood Bonnet M22003 Seat G Seat G
Hood Bonnet M22500 Step Step
Labels S10100 Label Label
Accessories T10500 Accessories And Service Parts
