Kubota Tractor B1610 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1610 Tractor
Number of Pages: 333 Pages
Artículos De Uso Frecuente / Frequently Used Items
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Bomba De Combustible (Mecanica) / Fuel Pump (Mechanical)
Agua Bomba / Water Pump
Filtro De Aire [Fr,Uk,G] / Air Cleaner [Fr,Uk,G]
Filtro De Aire [Sur Europa,Esp] / Air Cleaner [South Europe,Sp]
Silenciador / Muffler
Acelerador Varilla / Accelerator Rod
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Interruptor Interno Del Cabina / Switch
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Faro Delantero/Piloto Trasero [Excepto Uk] / Head Light/Tail Lamp [Except Uk]
Faro Delantero/Piloto Trasero [Uk] / Head Light/Tail Lamp [Uk]
Culata Luz/Cola Lampara / Head Light/Tail Lamp
Embrague / Clutch
Embrague Varilla / Clutch Rod
Carcasa De Embrague / Clutch Housing
Bastidor/Enganche Delantero / Center Frame
Transmision Caja [Fr,Uk,G] / Transmission Case [Fr,Uk,G]
Transmision Caja [Sur Europa,Esp] / Transmission Case [South Europe,Sp]
Caja De Diferencial / Differential Gear Case
Caja De Eje Delantero / Rear Axle Case
Eje De Embrague/Eje Propulsor / Clutch Shaft/Output Shaft
Helice Eje / Propeller Shaft
Pto Mostrador Eje/Pto Accionar Eje / Pto Counter Shaft/Pto Drive Shaft
Tdf Intermedia [Fr,Uk,G] / Mid Pto [Fr,Uk,G]
Eje De Primero Adelante / Fwd 1st Shaft
Eje De Segundo Adelante / Fwd 2nd Shaft
Eje De Tercero Adelante / Fwd 3rd Shaft
Horquilla De Cambio Principal / Main Gear Shift Fork
Horquilla Cambio Gama Y Cambio Creeper / Range Gear Shift Fork
Pto Cambio Bifurcacion / Pto Gear Shift Fork
Palanca De Cambio Principal / Main Gear Shift Lever
Hidraulico Control Palanca / Hydraulic Control Lever
Eje Trasero / Rear Axle
Trasero Rueda (7-16) / Rear Wheel (7-16)
Trasero Rueda (8-16) / Rear Wheel (8-16)
Trasero Rueda (212/80d-15) / Rear Wheel (212/80d-15)
Freno / Brake
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Pedal De Freno Secundario [G,Esp] / Secondary Brake Pedal [G,Sp]
Adelante Rueda (4.50-10) / Front Wheel (4.50-10)
Adelante Rueda (5-12) / Front Wheel (5-12)
Adelante Rueda (20*8,00*10) / Front Wheel (20*8.00*10)
Adelante Eje / Front Axle
Eje Propulsor De Rueda Delantera / Front Drive Shaft
Mangueta Brazo / Knuckle Arm
Direccion [Sur Europa] / Steering Controller [South Europe]
Direccion [Fr,Uk,G,Esp] / Steering Controller [Fr,Uk,G,Sp]
Distribuidor De Direccion [Componentes] [Sur Europa] / Steering Controller [Component Parts] [South Europe]
Distribuidor De Direccion [Componentes] [Fr,Uk,G,Esp] / Steering Controller [Component Parts] [Fr,Uk,G,Sp]
Tubo Hidraulico (Aspiracion) / Hydraulic Oil Line (Suction)
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Valvula Hidraulica [Componentes] [Excepto G] / Hydraulic Valve [Component Parts] [Except G]
Piston Hidraulico/Brazo De Elevacion / Hydraulic Piston/Lift Arm
Control Valvula [Componentes] / Control Valve [Component Parts]
Tirante De Elevacion / Lift Rod
Bajar Vinculo / Lower Link
Tercer Punto / Top Link
Barra De Remolque [G] / Drawbar [G]
Enganche / Hitch
Adelante Enganche / Front Hitch
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta Bajar / Side Cover Lower
Palanca Guia / Lever Guide
Guardabarros / Fender
Asiento [Uk,Sur Europa] / Seat [Uk,South Europe]
Asiento [Fr,Esp] / Seat [Fr,Sp]
Asiento [G] / Seat [G]
Peldano / Step
Etiquetas / Label
Volante / Flywheel
Ventilador / Fan
Embrague / Clutch
Freno / Brake
Enganche / Hitch
Capo / Bonnet
Peldano / Step
Etiquetas / Label
