Kubota Tractor B1241D-EC-M Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B1241D-EC-M Tractor
Number of Pages: 198 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Piston/Vilebrequin / Piston And Crankshaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Injecteurs Et Bougies Prechauffage / Nozzle Ho Lder And Glow Plug
Bride A Eau Et Thermostat / Water Flange And T Hermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux / Muffler
Levier D'accelerateur / Hand Accelerator Lever
Reservoir A Carburant / Fuel T Ank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant / Fuel Filt Er
Filtre A Carburant [Parties Co Mposantes] / Fuel Filter [Component Parts]
Pompe D'alimentation / Fuel Pu Mp (Mechanical)
Ventilateur / Fan
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Vase De Expansion / Reserve Tank
Contact A Huile Thermo Metre / Oil Switch And Thermo Sensor
Solenoide D'arret / St Op Solenoid
Alternateur / Alternat Or
Alternateur [Parties C Omposantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Parts]
Batterie / Battery
Commutateur / Switch
Relais / Relay
Tableau De Bord / Pane L Board
Tableau De Bord [Parti Es Composantes] / Panel Board [Component Parts]
Tableau De Commutateur / Panel Switch
Phare Avant / Head Lig Ht
Feux De Combinaison Ar Riere / Rear Combination Lamp
Lampe De Clignotant / Winker Lamp
Lampe Plaque Immatricu Lation / License Lamp
Faisceau Electrique (C Orps) / Electrical Wiring (Body)
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Couvercle De Carter De Embrayage / Clutch H Ousing Cover
Chassis Centre / Center Frame
Roue Avant (6-12) / Front Wheel (6-1 2)
Roue Avant (7-12) / Front Wheel (7-1 2)
Roue Avant (5-12) / Front Wheel (5-1 2)
Differentiel Avant / Front Different Ial
Engrenage Conique Gauche / Bevel Gea R Lh
Engrenage Conique Droite / Bevel Gea R Rh
Carter Engre-Conique / Bevel Gear Ca Se
Essieu Avant Droite / Front Axle Rh
Arbre De Entrainement Avant / Front Drive Shaft
Carter De Transmission / Transmiss Ion Case
Carter De Differentiel / Different Ial Gear Case
Carter De Pont Arriere G. / Rear A Xle Case Lh
Carter De Pont Arriere D. / Rear A Xle Case Rh
Arbre De Embrayage / Clutch Shaft
Arbre De Transmission / Front Prop Eller Shaft
Arbre De Avant / Front Shaft
Arbre De Pdf / Pto Shaft
Changement De Gamme / Range Gear
Differentiel Arriere / Differentia L Rear
Arbre D'entrainement Avant / Front Wheel Propeller Shaft
2eme Arbre / 2nd Shaft
3eme Arbre / 3rd Shaft
Fourchette De Changement D E Vitesses Principal / Main Gear Shift Fork
Fourchette De Changement D E Gamme / Range Gear Shift Fork
Fourchette De Chengement D E Vitesse Pdf / Pto Gear Shift Fork
Fourchette De Blocage Diff Erentiel / Differential Lock Shift Fork
Essieu Arriere Droite / Rear Axle R H
Roue Arriere (9.5-16) / Rear Wheel (9.5-16)
Roue Arriere (9.5-18) / Rear Wheel (9.5-18)
Roue Arriere (8-16) / Rear Wheel (8 -16)
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein / Brake Rod
Tige De Changement De Vitesses Principal / Main Gear Shift Lever
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Levier De Chengement De Vitesse Pdf / Pto Gear Shift Lever
Levier De Distributeur / Hydrau Lic Control Lever
Pedale De Frein / Brake Pedal
Pedale De Verrouillage Du Diffe Rentiel / Differential Lock Pedal
Bras De Fusee / Knuckle Arm
Bielle De Direction / Drag Link
Colonne De Direction / Steering Post
Pompe Hydraulique (Direction Assistee) / Hydraulic Pump (Ps)
Pompe Hydraulique (D.A.) [Parties Composantes] / Hydraulic Pump (Ps) [Component Parts]
Pompe Hydraulique / Hydraulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component P Arts]
Circuit D'huile Hy Draulique (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hy Draulique (Refoulement) / Hydraulic Oil Line (Deliv Ery)
Circuit D'huile Hy Draulique (Direction) / Hydraulic Oil Line (Steerin G)
Circuit D'huile Hy Draulique (F/M) / Hydraulic Oil Line (F/M)
Piston Hydraulique /Bras De Relevage / Hydraulic Piston/Lift Arm
Distributeur Contr Ole / Control Valve
Distributeur [Part Ies Composantes] / Control Valve [Component Parts]
Tombent Ajustement Arbre / Fall Adjustment Shaft
Barre De Relevage / Lift Rod
Bras Inferieur / Lower Link
Tirant Superieur / Top Link
Chaine D'arret / Check Chain
Barre D'attelage / Drawbar
Relevage Avant / Front Hitch
Attelage Arriere / Rear Hitch
Protection Pdf / Pto Protector
Calandre Avant / Front Grille
Capot Superieur / Bonnet
Capot Lateral / Side Cover
Piller Centre / Center Pillar
Guide De Levier G. / Lever Guide Lh
Guide De Levier D. / Lever Guide Rh
Aile / Fender
Plancher / Floor Sheet
Aile / Fender
Marchepied / Step
Couvercle Arriere / Tail Cover
Couvercle Arriere / Rear Cover
Cadre Anti-Renversement 1 (Arriere) / Rops 1 (Rear)
Siege / Seat
Siege / Seat
Siege / Seat
Accessoires Et Pieces De Service / Accessories A Nd Service Parts
Eclairage De Travail [Option] / Working Light Kit [Option]
Attelage Avant [Option] / Front Hitch Kit [Opt Ion]
Attelage Arriere [Option] / Rear Hitch Kit [Op Tion]
Barre D'attelage [Option] / Drawbar Kit [Optio N]
Contrepoids Avant [Option] / Front Weight Kit [Option]
Retroviseur [Option] / Rearview Mirror Kit [Op Tion]
Ventilateur / Fan
Demarreur / Starter
Batterie / Battery
Relais / Relay
Embrayage / Clutch
Aile / Fender
Aile / Fender
Marchepied / Step
Siege / Seat
Siege / Seat
Siege / Seat
