Kubota Tractor B1241D-EC-F2-S5 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1241D-EC-F2-S5 Tractor
Number of Pages: 334 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Guide
Volante / Flywheel
Volante / Flywheel
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Entrada Tubo / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Palanca Acelerador / Hand Accelerator Lever
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Conmutador/Rele / Relay
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Faro Delantero / Head Light
Intermitente Lampara / Winker Lamp
Luz Matricula / License Lamp
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Embrague / Clutch
Embrague Varilla / Clutch Rod
Embrague Carcasa Cubierta / Clutch Housing Cover
Rueda Delantera (6-12) / Front Wheel (6-12)
Rueda Delantera (7-12) / Front Wheel (7-12)
Rueda Delantera (5-12) / Front Wheel (5-12)
Eje Delantero / Front Axle Lh
Eje Delantero Derecha / Front Axle Rh
Eje Impulsor De La Rueda Delantera / Front Drive Shaft
Embrague Eje / Clutch Shaft
Eje Propulsor / Front Propeller Shaft
Adelante Eje / Front Shaft
Pto Eje / Pto Shaft
Gama Engranaje / Range Gear
Diferencial Trasero / Differential Rear
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Eje De Cuarto Adelante / 4th Shaft
Tdf Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Rueda Trasera (9.5-16) / Rear Wheel (9.5-16)
Rueda Trasera (9.5-18) / Rear Wheel (9.5-18)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla / Brake Rod
Principal Engranaje Cambio Varilla / Main Gear Shift Lever
Control Palanca / Hydraulic Control Lever
Freno Pedal / Brake Pedal
Mangueta Brazo / Knuckle Arm
Vinculo,Arrastre / Drag Link
Atar Varilla / Tie Rod
Direccion Poste / Steering Post
Hidraulico Bomba (Potencia Direccion) / Hydraulic Pump (Ps)
Hidraulico Bomba (Potencia Direccion) [Componente Piezas] / Hydraulic Pump (Ps) [Component Parts]
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (F/M) / Hydraulic Oil Line (F/M)
Hidraulico Cilindro (Ascensor) / Hydraulic Cylinder
Hidraulico Piston/Ascenzo Brazo / Hydraulic Piston/Lift Arm
Distribuidor / Control Valve
3-Punto Varillaje (Ascenso Varilla) / Lift Rod
Bajar Vinculo / Lower Link
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Trasero Enganche / Rear Hitch
Tdf Protector / Pto Protector
Capo / Bonnet
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Centro Montante / Center Pillar
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Peldano / Step
Peldano Soporte / Step Stay
Cola Cubierta / Tail Cover
Trasero Cubierta / Rear Cover
Arco De Seguridad / Rops
Hoja / Seat
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Adelante Enganche Kit[Opcion] / Front Hitch Kit [Option]
Trasero Enganche Kit [Opcion] / Rear Hitch Kit [Option]
Barra De Remolque Kit [Opcion] / Drawbar Kit [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
Kit Espejo Retrovisor [Opcion] / Rearview Mirror Kit [Option]
