Kubota Tractor B1220D Spare Parts Catalog EN FR
Language: French, English
Model: Kubota B1220D Tractor
Number of Pages: 188 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Arbre A Cames Et Arbre De Pignon Intermediaire / Ca Mshaft And Idle Gear Shaft
Piston Et Vilebrequin / Piston And Crank Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / Fu El Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur [Parties Composantes] / Nozzle Hold Er [Component Parts]
Pompe D'alimentation (Mechanique) / Fuel Pump (Mech Anical)
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Collecter D'echappement / Exhaust Manifold
Filter A Air / Air Cleaner
Silencieux / Muffler
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Composa Ntes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pi Pe
Radiateur / Radiator
Reservoir Du Radiateur / Reserve Tank
Solenoide D'arret / Stop So Lenoid
Dynamo / Dynamo
Dynamo [Parties Composantes ] / Dynamo [Component Parts]
Lanceur / Starter
Demarreur [Parties Composan Tes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Tableau De Bord Et Commutat Eur / Panel Board And Switch
Tableau De Bord (Pieces Com Posantes) / Panel Board [Component Parts]
Faisceau Electrique (Corps) / Electrical Wiring(Body)
Embrayage / Clutch
Tige D'embrayage / Clutch Rod
Pedala D'embrayage / Clutch Pedal
Chassis Avant / Front Frame
Chassis Centre / Center Frame
Carter De Transmission / Transmission C Ase
Carter De Differentiel / Differential G Ear Case
Arbre D'embrayage / Clutch Shaft
Arbre De Transmission / Front Propeller Shaft
Arbre De Pdf / Pto Shaft
Arbre D'engre-Conique/Changement De Gam Me / Bevel Gear Shaft/Range Gear
Differentiel Arriere / Differential Rea R
Arbre D'entrainement Avant / Front Whee L Propeller Shaft
1eme Arbre / 1st Shaft
2eme Arbre / 2nd Shaft
3eme Arbre/4eme Arbre / 3rd Shaft/4th S Haft
Fourchette De Changement De Vit Esses / Main Gear Shift Fork
Fourchette De Changement De Vit Esses / Range Gear Shift Fork
Fourchtte De Pdf / Pto Shift Fo Rk
Fourchette De Blocage Different Iel / Rear Differential Lock Shift Fork
Levier De Cahngement De Vitesse S Principal / Main Gear Shift Lever
Levier De Changement De Vitesse S / Range Gear Shift Lever
Levier De Vitesses Pdf / Pto Ge Ar Shift Lever
Axe Arriere / Rear Axle
Pedale De Verrouillage Du Differentiel / Differential Lock Pedal
Roue Arriere(7-16) / Rear Wheel(7-16)
Roue Arriere(8-16) / Rear Wheel(8-16)
Roue Arriere(9.5-16) / Rear Wheel(9.5-16)
Roue Arriere(212/80d-15) / Rear Wheel(212 /80d-15)
Roue Arriere(29*12.00-15) / Rear Wheel(29 *12.00-15)
Fr Ein / Brake
Fr Ein / Brake
Ti Ge De Frein / Brake Rod
Le Vier De Frein De Stationnement / Parking Brake Leve R
Pe Dale De Frien / Brake Pedal
Levier De Distributeur / Hyd Raulic Control Lever
Support Avant Droit / Hydrau Lic Pump
Pompe Hydraulique [Parties C Omposantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydraulique (Aspiration) / Hydraulic Pipe (Suction)
Circuit D'huile Hydraulique (Refoulement) / Hydraulic Oil Line (Delivery)
Cylindre Hydraulique / Hydra Ulic Cylinder
Soupape De Variatio [Parties Composantes] [Option] / Change Valve [Component Pa Rts] [Option]
Bras De Relevage / Hydraulic Lift Arm
Distributeur Hydraulique / C Ontrol Valve
Soupape De Controle [Parties Composantes] / Control Valve [Component Parts]
Roue Avant(4.5-10) / Front Wheel(4.5-10)
Roue Avant(5-12) / Front Wheel(5-12)
Roue Avant(6-12b) / Front Wheel(6-12b)
Roue Avant(20*8.00*10) / Front Wheel(20*8. 00*10)
Roue Avant(20.5*8.00*10) / Front Wheel(20. 5*8.00*10)
Differentiel Avant / Front Differential
Carter Engrenage Conique / Bevel Gear Case
Pont Avant / Front Axle
Arbre De Entrainement Avant / Front Drive Sh Aft
Bras De Fusee / Knuckle Arm
Bielle De Direction / Drag Link
Volant De Direction / Steering Hand Le
Timoner De Direction / Steering
Barre De Relevage / Lift Rod
Bras Inferieurs / Lower Link
Tirant Superieur / Top Link
Chaine De Arret / Check Chain
Attelage Arriere / Rear Hitch
Capot Superieur / Hood (Bonnet)
Couverle De Panneau / Panel Cover
Couvercle Lateral / Side Cover
Guide De Levier D. / Lever Guide Lh
Guide De Levier G. / Lever Guide Rh
Aile / Fender
Siege / Seat
Siege / Seat
Marchepied / Step
Marchepied / Step
Couvercle Arriere / Tail Cover
Etiquette(Avant) / Label(Front)
Etiquette(Arriere) / Label(Rear)
Ac Cessories Et Piece De Service / Accessories And Ser Vice Parts
Attelage Avant [Option] / Front Hitch Kit [Option]
Kit De L'orifice Hydraulique [Option] / Hydraulic P Ort Kit [Option]
Ventilateur / Fan
Dynamo / Dynamo
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Embrayage / Clutch
Fr Ein / Brake
Fr Ein / Brake
Aile / Fender
Siege / Seat
Siege / Seat
Marchepied / Step
Marchepied / Step
